Originally Posted by 4Running22
What's a good jacking points for rotating your tires? Let's say if I start at the driver's side can I just jack it up in the center of the driver's side frame and place two jack stands and both sides? Will it damage the vehicle if I jack it in the center of the frame?
+1 would like clarification on this also. Have scoured the web and only have found one or two videos of Taco owners jacking from the center of the frame and placing 2 jack stands on one side. (to do the front to back tire rotation)
The only other info for the 4r I found was someone mentioned jack from the front center Toyota suggested point, place one jack stand (ie on the pass side) and lower jack.
Then jack from rear pumpkin (Toyota recommended) and place one jack same side under the diff axle (Toyota suggested)
Wondering if there's too much twisting doing this as your jacking the rear up with only one side of the front on a stand. I guess I could just get 4 jack stands and lift it all up evenly. Thought having one side on ground feels safer though.
