01-21-2016, 12:31 PM
#61
Banned
Banned
Originally Posted by Wingsuit
They told me to expect closer to 10 weeks. Direct from Gobi.
expect closer to 12 lol
01-23-2016, 06:56 PM
#62
Real Name: John
Real Name: John
This post is SPOT ON!!
With these photos, the write-up and the Gobi instructions you can install this rack in a couple of hours. It took me all of an hour to install the ladder and "feet" today. Tomorrow I get help to lift the rack on, and it shouldn't take more than an hour to put in and tighten a bunch of nuts.
2013 4Runner Trail Edition | Classic Silver Metallic | KDSS | Demello Offroad Hybrid Sliders | RCI Metalworks Skid Plates | GOBI Stealth Rack | Bilstein 5100 F/R | Stealth Satoshi Mod
02-11-2016, 11:41 AM
#63
Thanks! Yeah the only time consuming part is thoroughly cleaning out the troughs and waterproofing. Easy but time consuming to do it the correct way.
**To date I have not had a leak....and the 4runner sits outside all the time. We've had some serious rain here on the coast over the past 6 months. Still dry. Like I said...if you go overboard with waterproofing the bolt threads along with the surrounding area and gaskets/bushings, you wont have any problems.
* 2011 Silver SR5 4x4: |Toytec Ultimate 3" w/ Light Racing UCAs|Allpro Sliders|SOcalTRAIL Mesh Hidden Light Bracket| Roof Rack Delete| Gobi Stealth Rack/Ladder Install|3rd row|20% tint|K&N panelfilter|285/70/17 Goodyear Duratec MTs|
* 1969 Dodge Charger R/T
* 1969 Plymouth Roadrunner
* Previous: |1971 Land Rover|1971 Toyota FJ40|1971 Ford Bronco|1968 Chevy Impala|1981 Delorean|1993 VW Corrado SLC|
02-11-2016, 11:55 AM
#64
Originally Posted by DreadPirateMoyer
@ W8kbrder
Would you be able to snap a picture of your final front feet placement? Curious to see how far you located them from the rain gutter wall in visual.
Sorry been away for awhile. I'll snap a few pics today.
Update: pics snapped
02-14-2016, 03:34 PM
#65
Real Name: David
Real Name: David
I'll echo the many thanks already posted here, I'm doing my install tomorrow and will no doubt be referencing the sh*t out of this thread! A couple questions for you:
On the plastidip, how much of a section did you put down, i.e. did you try to contour it to exactly under the wind fairing or just do a rectangle to match the rough length/width of the fairing?
Also, I was planning on giving the roof one final wax before install. How do you clean under the rack now, just wash and dry? I realize you're in NC where you get plenty of rain so it's probably not a huge deal, but I'm curious what sort of access you can get under the rack (a hand, a towel on a stick, an army of trained chinchillas covered in McGuiars...?)
Thanks, I know this has been addressed anecdotally elsewhere but figured I'd ask you anyway!
2014 SR5, My wife calls it "The Mistress"
02-14-2016, 04:34 PM
#66
people attach a microfiber to a Swiffer and its apparently a perfect fit. I think there are pictures of someone using the Swiffer earlier in this thread.
2015 TEP Nautical Blue
Build thread here
02-14-2016, 08:00 PM
#67
Real Name: Bill
Real Name: Bill
If it arrives this week will be 16 weeks.
2012 Limited. ARB front and rear lockers, Nitro 4.56 gears, OME suspension, Nitto TG 285-75-R17 tires, ARB front bumper, Warn winch, Shrockworks sliders, CBI rear bumper, CBI skid plates, C4 Fab Fuel skid plate, Gobi rack, CVT MT. Shasta Summit RTT, Rigid LEDs. ICOM and Yaesu radios. KK6RMP
02-14-2016, 09:03 PM
#68
Has anyone found any good "theft prevention" techniques for mounting a light bar on these Gobi's?
02-16-2016, 04:29 PM
#69
Tamper proof torx button head bolts are probably the best in terms of a bolt. Other than that, buy the Chinese light bar. Or drill a hole in the cooling fins and run an aircraft cable through it and then to the rack.
My Build Thread
www.AnytimeBackupCamera.com
2011 4Runner Trail loaded w/KDSS
1992 Land Cruiser
02-25-2016, 03:37 PM
#70
Real Name: Paul
Real Name: Paul
Thank you for the write up. Can't wait till I get my Gobi in which will be a while lol. Definitely going to use this as a reference when I do my install .
2016 SRFIVE
instagram: t4rwarrior
02-25-2016, 04:30 PM
#71
Two things on the install: my fairing came with a hollow rubber-like pad on its bottom side, I don't see where plasti dip would even go. I did put a strip of paddle board rail tape on the paint where this rubber strip makes contact. Rail tape is similar to clear bra car protectant, a heavy clear tape. Also, on the ladder install, there is a pressure plate that takes the stress off the inside of the bottom of the lift gate so the clamp bolts won't hurt the paint under there. For the two set screws at the top of the tail gate, they are intended (apparently) to screw right into or against the paint at the top inside of the gate. I wasn't comfortable with that, so I took two dimes, put double sticky tape on them, and used them as a sort of pressure plate so the set screws could bite into them instead of the top of the tail gate. Cost me 20 cents though ...
02-25-2016, 06:46 PM
#72
Not sure where to post this and this seems like a fairly active thread.
Kind of a specific question, but does anyone know if you could mount something like the Thule Portage 819 on the rack and it would provide enough rise to get a canoe over the raised front? Or would it be necessary to just order the rack as no rise?
It's not something I'd need to do all the time, but more than just once in a blue moon.
02-25-2016, 08:44 PM
#73
This is just speculation but I don't think that specific Thule mount will give u the clearance required. Those look too low profile to give you the guesstimated 3" (someone can give an accurate measurement) u need to clear the rise. While that particular one may not work you could probably find an option that sit a little higher.
2015 Trail Premium
SCS/BFG, King/Dobinsons/JBA, Icon/Sonoran Steel, Hefty Fabworks, Shrockworks, RCI, XD HID, Gobi, FJ Toyman, GZila, Dog-Proofed
02-25-2016, 10:53 PM
#74
I have the Thule portage, and the rise is under one inch. The rise to the Gobi Stealth front bar is 2 inches. if your primary thing to carry is a longer boat I would get the no rise. You could always use some of those foam blocks to get your canoe high enough to clear the front bar of you went with the standard Gobi
02-25-2016, 11:04 PM
#75
Thanks for the responses. Know of some pictures of a no rise Stealth rack with a 40" light bar? Trying to figure out how that would work out--figure if you go no rise you either do light bar or fairing, but wouldn't be able to do both. Perhaps a grill mounted bar would have to do.
