Old 04-15-2015, 02:47 PM #1
2010-Runner-Trail's Avatar
2010-Runner-Trail 2010-Runner-Trail is offline
2010-Runner-Trail is on a distinguished road
Rubbing / Spinning Noise
Hey Y'all,
I recently went wheeling, everything was fine on the trail and the way home (about 45 miles). The next day I hit the carwash. After washing I noticed a very weird noise I am having trouble identifying. The sound comes from the front driverside area. It sounds as if there is a rubbing mixed with a very subtle clunk. This occurs in neutral while coasting, as well as in drive (both 2wd and 4wd)... It is directly dependent on speed (the faster you go, the more frequent), however, it IS NOT directly tied to the rate of wheel spin. Seems like its cyclic in nature close to every 20-25 rotations of the tire.... if that makes sense. It is not a fast noise like it happens every rotation. I see no indication of rubbing. I have not been able to get it in the air and spin the tire manually yet, I will not have a chance until Sunday..... Just wondering if this sounds like anything someone has ran into in the past.
Thanks!
2010-Runner-Trail is offline   Reply With QuoteReply With Quote
Old 04-15-2015, 04:52 PM #2
Boyds4Runner's Avatar
Boyds4Runner Boyds4Runner is offline
Real Name: Victor
Boyds4Runner is on a distinguished road
Real Name: Victor
Not that I have run into the same on any of my 4Runner's but on my Blazer I would sometimes get a small rock stuck in a gap in the brake caliper that would clink around until it bounced out or I could pull it out...maybe something similar is "floating" around between the inside Brake shield and the brake rotor?
2015 Black 4Runner TRD Pro
Mild add-ons - Toytec 2" TRD lift kit w/SAW 1.5" rear spring, Nitto Ridge Grappler 285/70/17 C, 1/4" Aluminum RCI Metalworks Skids - All but the TRD Pro skid. FJToyman lower Rear shock mount skids. C4 Fab sliders. axle & eLocker breathers to ARB under hood, tinted front two windows, BajaRack Stealth with Spylight Sytem, Extreme LED 40" single row light-bar, Blacked out chrome on tailgate. Weathertech in-channel window vent visors and rear cargo mat, Paracord Headrest Grab Handles. H11 LED fogs and XenonDepot headlight kit. Interior LED swap.
Boyds4Runner is offline   Reply With QuoteReply With Quote
Old 04-23-2015, 09:48 AM #3
So it turned out to be the front driver wheel bearing. So I changed out the Hub assembly, $80.00 from Napa, then $40.00 to have the old bearing pressed out and the new one in. $120.00 and about 3.5 hours. (About 45 mins actual wrench time). Took care of the noise I was concerned about as well as a vibration rattle in the dash that has been driving me crazy!
driver side , front , noise , rubbing
wheel lug stud spinning and spinning 4gin007 4th Gen T4Rs 24 12-01-2014 09:17 AM
Spinning noise whenever cluntch is pressed dbg 3rd gen T4Rs 6 11-30-2008 07:43 PM
clicking noise while spinning on ice Cubfan 3rd gen T4Rs 4 12-09-2007 07:37 PM
Front end rubbing noise WFB Problems & Warranty Issues 1 10-28-2007 10:43 AM
Weird rubbing noise?? Zerokool Problems & Warranty Issues 0 02-01-2004 03:26 PM
