06-06-2015, 11:15 PM
#31
Originally Posted by FattyHunter
Nice build man! i ordered a skid plate like yours and toytec lift kit, do you know if the skid plate will work with a diff drop kit? thanks
Thanks!
I do not know the answer to your diff drop question. Sorry
Best Regards,
Saker
06-06-2015, 11:24 PM
#32
Real Name: Reid
Real Name: Reid
I just installed Shrockworks skids and they were not compatible with the Toytec Diff Drop, it needed to be removed. Shrockworks said they partnered with Toytec and since the spacers were are only installed on one side, it only lowered it ⅜ of an inch, it's not that much of a difference.
2011 SR5 - Trail hood - Method NV wheels, 285,70-17 Duratracs - Toytec Boss lift - Shrockworks dimple sliders/trail trim/battery, ACR & Switch mounts/skids - Weathertech mats - LED bulbs - 18% tint - Gobi Stealth, cargo slider, ARB dual twin compressor with 1.5 gal tank, Retrofit head lights (MORIMOTO FX-R Stage III, XB 55, DS2 XB 5500k, XB LED Fogs, DDM LED high beams) Bussman box, Switchpros, Bluesea ACR, Odyssey second battery.
(Have but need to install: Seat heaters)
07-07-2015, 12:58 AM
#33
Real Name: Scott
Real Name: Scott
Nice work on the truck!
2017 Silver TRD Offroad - Full build details here: gearproject.co/gp/AJCONE/583
07-08-2015, 12:50 AM
#35
Real Name: Steve Fry
Originally Posted by TotalAutomotiveLV
Those look great, how is the output?
I put mine on the rack yet also want some lower especially since my upper lights are blocked by the hatch fairing. It would help to have them when backing up my boat especially, I am really imressed by the SRQ and SRM great little lights and are resonable for a rigid product!
15 TRD Pro Build Thread - OIF 09-10 - Combat Disabled Army Veteran - Purple Heart - Combat Medical Badge
Note: Dont get all butthurt because my grammar is terrible. See above and consider this before you stick your foot in your mouth. Also, I do post from an i-Device so words tend to get garbled and misspelled. I cant believe I have to out this here.
08-22-2015, 02:13 PM
#36
That is an awesome 4Runner.
I want to install a TRD skid plate on my 2015 4Runner SR5 and need some help.
I have seen on the 4runner forum that the PT398-00140 TRD skid plate has been installed and the original Lower Cover Radiator Support Air Deflector was kept in place with some trimming because the new skid plate interferes with the Deflector. What I can see on the pictures is on both sides of the Deflector has been trimmed and also in the center section. Is the Air Deflector cut in half behind the skid plate and only 3 bolts are holding/connecting it to the original connecting ears on the bumper. Or the portion behind the skid plate is not cut off and the Air Deflector is attached in the original place with the original 2 bolts and 1 push-type-retainer to the cross member under the radiator. I would like to install it soon.
08-22-2015, 06:12 PM
#37
Thanks you sir!
The answer is "the Air Deflector cut in half behind the skid plate and only 3 bolts are holding/connecting it to the original connecting ears on the bumper".
Best Regards,
Saker
08-23-2015, 09:09 PM
#38
Could you give us your impressions on the Morimoto H11 Elite HID after having them for over one year? They seem to match the fogs pretty nicely!
Sold 2015 Canadian TE Magnetic Grey-Toytec BOSS, 285 70 17 Duratracs, Blue Sea fuse block, Gobi Stealth, Morimoto LED fogs, FN Pro(x) Wheels
Sold 1996 4runner Limited Natural White w/ Silver Cloud trim. 265 75 16
2013 Limited Blizzard Pear 3rd rowl - 2.5" Elka 2.0 Coils 650# Springs/0-2" Elka REAR /Dobinson C59-325 Rear Coils/Greenlane Diff Drop/ SPC UCA's
08-23-2015, 10:59 PM
#39
Yes they match the Morimoto LED fogs fairly close.
I am very pleased with the quality, color and output of the Morimoto H11's.
I have not had the first issue with them since they were installed.
I am running the 50W ballasts and some people said they would damage the projector lenses, but this is absolutely false.
Before purchasing them, I inquired and TRS had a test T4R headlight and never experienced and adverse projector issues with the higher wattage HID.
So, buy quality parts and get good results.... just sayin'
Best Regards,
Saker
12-08-2015, 06:16 PM
#40
Real Name: 2016 Black TEP w/KDSS
Any chance you could post some "plain" side pictures?
Saker,
I've looked at your build about 3,000 times in the months that I've been waiting for my T4R to come in (and then the additional week for the 5160s to arrive). I'm really trying to decide which circlip I'm going to use on the 6112s. I've looked at Borfoo3's (and a thousand others) a bunch, too. I'm thinking third Circlip on the front (with 6112s), and then my 1" spacer with stock springs and 5160s in the back for a very slight rake (my front and rear measurements differ by 1.57"s, and if i extrapolate others' experiences, I think I'll have about 3/4" difference after the 6112/5160/1"spacer install.
You have a TON of photos, but I'll be darned if I could find one from the side on flat ground. Would you have a chance to do that?
Thanks, and nice rig!!!
12-09-2015, 07:01 AM
#41
Originally Posted by MRAD.338
Saker,
@ MRAD.338
Thanks for the Kudo's!
BTW, Like the handle...MRAD + .338 (as in Lapua?)
See if these photos will help.
Best Regards,
Saker
12-09-2015, 03:15 PM
#42
Fantastic, Thanks! Just what I was looking for.
(You're right on with my handle, too).
12-10-2015, 03:10 PM
#43
Real Name: Shawn
Real Name: Shawn
Nice ride, has the plastidip held up well on the front skid plate?
12-10-2015, 04:42 PM
#44
It held up for about 1 year, that is until I started making it peel from one of the corners with the car pressure washer!
So my next task was to remove all platidip and then I painted it w/ Duplicolor Self-Etching Primer, then sprayed it with Duplicolor Semi Gloss Black.
Best Regards,
Saker
01-01-2016, 09:40 PM
#45
December 28, 2015
SprintBooster Install
Received my SprintBooster and installed it (set to green setting).
Never thought it would make such a difference.....Toyota should have done this!
A very large improvement on the response!
Best Regards,
Saker
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
