04-15-2016, 11:33 PM
#62
April 15, 2016
Aux Electrical Circuit Mod
I decided I would try a project to have dedicated fused power all in one place via a Blue Sea 5025 6 Circuit w/ ground bus & Cooper Bussmann Resettable Circuit Breaker CB285-100, instead of individual leads running to the battery for power.
TEASER:
I have something in mind to keep it virtually water-resistant/waterproof. I’ll see if it works out.
***Will add photos as items arrive or get installed.
Below are the items I am connecting:
• 12V Circuit for Trailer Back-up Lights
• LED Light Bar
• Engine Compartment LED Light Mod
Seems like there is something else…. I’ll find out when I start unhooking connections!
Started fabricating my support bracket out of a piece of 3/16” plexiglass for the Aux Electrical Circuit Mod
Best Regards,
Saker
04-16-2016, 02:03 AM
#63
Originally Posted by Saker
April 15, 2016
TEASER:
• LED Light Bar
Can't wait to see the results!!
You can see on mine where the plate covers the relays and is almost a little too big due to the harness near the brake booster.
IG @go.xplre
04-16-2016, 02:20 AM
#64
@ weeeee
The cutout in the upper right corner of the photo is for a pair of relays currently mounted on the inner fender.
The cutout in the lower left corner of the photo is for the brake booster harness to bypass the bracket.
Best Regards,
Saker
04-16-2016, 02:34 AM
#65
@ weeeee
That's pretty awesome. If you decide to make these I'm sure I'd shell out some $$ for a cleaner plate. I think
@ RedStripeRanger
was looking for a good solution in that area too.
IG @go.xplre
04-16-2016, 08:18 PM
#67
Looks good. What did you use to make the clean cuts and how easy was it to bend the plexi?
Sold 2015 Canadian TE Magnetic Grey-Toytec BOSS, 285 70 17 Duratracs, Blue Sea fuse block, Gobi Stealth, Morimoto LED fogs, FN Pro(x) Wheels
Sold 1996 4runner Limited Natural White w/ Silver Cloud trim. 265 75 16
2013 Limited Blizzard Pear 3rd rowl - 2.5" Elka 2.0 Coils 650# Springs/0-2" Elka REAR /Dobinson C59-325 Rear Coils/Greenlane Diff Drop/ SPC UCA's
04-16-2016, 08:34 PM
#68
Thanks
@ 2chains
This was a piece of scrap golf cart upper windshield that had the 90° bend already.
Used a band saw to cut the bracket to my needed dimensions and a file to clean up the edges.
I like the fact that it's clear and non conductive.
I wish I had access to a lot more of this material for obvious reasons.
Best Regards,
Saker
04-26-2016, 02:47 AM
#69
April 26, 2016
AUX CIRCUIT MOD
Here is the mock-up of my AUX CIRCUIT. The Pelican 1020 Box idea didn't work out as envisioned. Not quite enough space, so I scrapped that idea.
I think this will be fine as is, not as waterproof as a busman though....
Second photo is the AUX CIRCUIT Close-up installed.
Third photo is the AUX CIRCUIT completely finished and operating as designed
Best Regards,
Saker
04-29-2016, 04:00 AM
#70
Looks really clean! I'll be watching this closely for ideas...
IG @go.xplre
05-20-2016, 02:08 PM
#71
Sliders
Thanks Kevin, will be in contact as discussed!
Love the build. Clean!
Can you shoot me over some contact information for the place that you got your sliders from? Even a part number for them? They were strictly bolt on, correct?
05-20-2016, 02:13 PM
#72
Great build! Very well thought out and practical.
05-20-2016, 04:43 PM
#73
Thank you, sir!
Sent you a PM
Best Regards,
Saker
05-23-2016, 01:31 PM
#75
The sliders in that pic was a one off....but we will be adding bolt on sliders for the 4Runner to our website within a week. Please check the website next week. www.southernstyleoffroad.com
