10-07-2020, 12:05 AM
UCA's
I tried googling this but couldn't find exactly what I wanted. I am about to throw in an Eibach pro kit on my 2017 5th gen SR5P. I am currently trying to decide on UCA's. I was going to go with JBA's however their site says you cannot run 285's with stock TRD-Pro wheels with their UCA. So my question is what UCA's are those of you using with the stock TRD-Pro wheels?
10-07-2020, 09:04 AM
I’ve got a JBA upper, with stock TRDP rims and 285’s, no problem at all... I am not sure why they saying can’t run this setup.
10-07-2020, 09:16 AM
Whats your caster and tire size/offset?
Rub? BMC?
10-07-2020, 09:33 AM
I am running the SPC UCA's with no issues at all. That could be another option for you.
10-07-2020, 09:36 AM
Rub? BMC?
285/70/17 M/T F/Wildpack’s, 0 offset TRD pro rims, No rubbing, no BMC
My last alignment, like month ego, camber and caster are locked, working on toe.
10-07-2020, 09:37 AM
10-07-2020, 09:42 AM
SR5 P with Falkin M/Ts 285/70/17 on the black pro wheels, fender trim, bmc.
2017 Silver SR5 Premium
Vietnam 67-68
Greed and corruption are rampant.
10-07-2020, 09:52 AM
Did you got with their HD ones? The site says the wheel needs to be 0 offset I thought TRD-PRo wheels were 4mm offset?
10-07-2020, 10:03 AM
No. Those UCA’s standard. As for Wheels offset from what I know it 0 but never made sure, could be wrong, either way it will fits with no issues 100%
10-07-2020, 10:37 AM
Just googled offset on TRDP wheels and they are 4mm, you’re right. Probably JBA recommendation for 0mm offset , just for playing safe avoid the rubbing between uca and tire . I guess
10-07-2020, 11:13 AM
I don't understand the fascination with the JBA UCA's. This topic of what is going to work or not work with them seems to come up quite regularly. Why not just pay the extra $100 and get a set of Dirt King UCA's and never have to worry about the situation? They're a better product anyway.
And besides all that if you change tires or rims in the future do you really want to be limited by what is compatible with your UCA'?
10-07-2020, 11:38 AM
That makes sense, any other advocates for DK UCA's? How about squeaking?
2015 TRDPRO SUPER WHITE ~ ROOF RACK DELETE ~ REAR SEAT DELETE ~ LED ANYTIME FOGS ~ DRL DISABLE ~ DOMETIC CFX-28 ~ BORLA CAT BACK ~ SPRINT BOOSTER V2 ~ aFe MOMENTUM GT INTAKE ~ OTHER JUNK N STUFF
10-07-2020, 11:51 AM
For most people
Ball joints > uniballs
Rubber bushings > Poly bushings
JBA uses ball joints and rubber bushings. For me that's the primary reason to go with JBA. IMO the Ironman arms visually appear to be the best current UCA for most users, but I have not personally owned a set, so I don't know.
EDIT: also - JBA should re-design it's arm to clear with stock wheel offsets for all OEM wheels. It would not take a major change to do that. It's just a few mm of material that needs to be removed from one part of the flat plate to clear any of the normal OEM wheel/tire combos.
10-07-2020, 12:11 PM
Originally Posted by Jetboy
For most people
I understand completely what you're saying. However, for me the uncertainty of if a part will be compatible long term to me is a deal breaker. According to SPC their bushings are a rubber compound and ball joint as well.
Edit: I agree the re design would be easy and do away with all the questions of fitment which then would make them a no brainier. But until then...
10-07-2020, 02:59 PM
Ok just installed my JBA high caster and my truck feels so solid I wish I did it when I installed my BP51 would have saved me money :redbrick but the whole truck feels like it was cut from steel perfect
Mike
