Old 09-28-2017, 03:41 PM #1
e60ral e60ral is offline
Banned
e60ral will become famous soon enough
Banned
Fuse for front power outlet?
My front power outlet (the one beside the USB/AUX) died, however the outlet in the center arm rest storage and the 2 behind the arm rest are still working.
The 15A power outlet fuse is fine, so far I haven't found another blown fuse.
Is the front power outlet on a different fuse? If not any other ideas?
Sent from my SM-G930V using Tapatalk
e60ral is offline   Reply With QuoteReply With Quote
Old 09-29-2017, 08:30 AM #2
Banned
Banned
anyone? bueller?
Old 09-29-2017, 10:41 AM #3
4Reak Show's Avatar
4Reak Show's Avatar
Originally Posted by e60ral View Post
anyone? bueller?
Diagram I have shows one fuse for all outlets. "P/outlets" fuse, 15Amp on driver side junction block.
With a voltmeter or test light connected to ground on the other end carefully see if you have power in the center of the outlet. The outter ring should be ground. Check both.
If one is missing, go from there. If both present consider the device/adapter you're using to have a contact issue.
Good luck
4Reak
Old 09-29-2017, 11:44 AM #4
Banned
Banned
Good luck
4Reak
that's the fuse that i said is fine, and all the other power outlets work fine. I checked other fuses but so far haven't found one that is blown. There is 0.0V at the front power outlet
it's also not the device because they all work fine on the other outlet (and the 0 voltage was verified with a meter)
does the front power outlet use a different fuse?
Old 09-29-2017, 11:53 AM #5
4Reak Show's Avatar
4Reak Show's Avatar
Gotta take something apart to further investigate.
Old 04-17-2021, 01:15 PM #6
okcrich okcrich is offline
okcrich is on a distinguished road
My front two power outlets are dead - fuse OK
Did you ever find out what caused the problem? I was returning from a road trip. My poweroutlet in the glove box is powering a dashcam. The power outlet on the front control panel is powering a GPS. They both died at the same time. My 15 amp fuse is OK.
What else did you check?
okcrich is offline   Reply With QuoteReply With Quote
Old 04-17-2021, 02:08 PM #7
flyrv9's Avatar
flyrv9 flyrv9 is offline
flyrv9's Avatar
Did you check your OK fuse with a meter? You might want to also unplug everything from all outlets and check them with a meter. Be sure to have the vehicle running as some outlets won't work on ACC. If you don't get any answers from that - then it's time to get a drawing for your make, model & year of 4Runner. There are drawings in the stickies provided by Nashman but they are from 2010.
2000 4Runner: Accessory Power outlet fuse?? lopatoj Maintenance/Detailing 6 02-20-2021 11:33 PM
Where to tap the fuse block for new power outlet john123drury Engines / Suspension / Wheels / Tires / Audio / Accessories 2 10-09-2014 10:58 AM
Rear power outlet fuse? ARC 3rd gen T4Rs 9 09-21-2014 01:30 AM
Power outlet blown fuse LL21 4th Gen T4Rs 1 04-19-2009 01:52 PM
Why did the 4th Gen lose the second 12V power outlet in the front JP4RNR 4th Gen T4Rs 4 11-22-2006 03:08 PM
