05-27-2015, 03:50 PM
Real Name: Ron
Real Name: Ron
A morning in the sand in a stock SR5
150527-4R Trek 275 Exploring a new faint trail “Ron’s Loop”
Yesterday I got the oil and filters changed at Dolan Toyota; plus they washed her all up. Can’t leave it clean can I? So this morning I took her across the highway into the Hot Springs Range. Not much dust as we’ve had intermittent rain for the past ten days, which even firmed up the sand a bit.
I got out on the pole line trail a few miles and found a faint trail I had missed before. So let’s see where it goes. It ran across the flats for a half mile and then started climbing up to an old tufa outcropping. From there the trail seemed to disappear. I walked around a bit and found a very faint two track in the brush that seemed to go up a wash and then into a little valley that broadened out. The trail kept getting fainter and fainter; “when in doubt follow the wash”. Every time I followed where a trail would logically go it would appear again. It was sometimes just a bit greener brush, sometimes a tire rut.
The ride and stops were quite peaceful and pleasant. Sometimes I would encounter some deeper sand and the A-Track would engage and pull me on through. The trail was mostly accomplished in 4LO; 2nd gear and A-track ON.
After about 8 miles of this I arrived at a familiar trail and then looped back to the flats. At one point I tried a hill climb in deep sand with a pitch of about 40 degrees. In the past I could never get more than about 30 yards up it. This time I went about 100 yards. Nearly to the top before all four wheels just dug down to the hubs. Then I just put it into reverse and backed slowly down. That rear view camera is great! Did you know that the Decent Control does not work in reverse?
Just truned 40,000 miles
The new trail
wild flowers blooming
heading north
Parked amongst some tufa
the trail fades
Carson Sink behind me
the little valley broades
surrounded by basalt mesas
Very peaceful here
Totally stock 2013 SR5 4WD. Have added Toyo Open Country M/T LT 265/70-R17 (E) tires the first week I owned it. Added second set of Toyo M/Ts at 86900 miles.Added RCI OFF-ROAD Rock Slidersat 84000 miles. Added RCI OFF-ROAD front skid plate at 90,000 miles. Daily driver and so far spending about 30% of time/mileage off-road. Previous truck 2004 Land Rover Discovery that also spent about a third of it's life off-road. I HANG AROUND HERE "THE T4R FASHION FORUM" JUST FOR LAUGHS.
Perfect vehicle as it stands for northern Nevada terrain. Keep it stock - it'll go most anywhere as is.
05-27-2015, 03:56 PM
Real Name: Ron
Real Name: Ron
There is a hole in the rock
The sandy climb that I just could not do. I got to within spitting distance of the top.
No: Rear lockers, LED lights, X-Reas, KDSS, a 3 inch lift, bigger tires, steel bumpers, racing stripes, plasti-dip, would not have helped - - -
05-27-2015, 04:29 PM
Real Name: Um, Phil?
Nice thread.
A TRD Pro woulda made it no sweat.
2010 Blizzard Pearl SR5/P - traded
2018 Superwhite SR5/P ... IS350 retrofit.
05-27-2015, 04:41 PM
Banned
Banned
trd pro would. man i wish i could even wheel that. im sick of only red clay and mud. cool thread
05-27-2015, 05:14 PM
Moderator
Real Name: Greg
Moderator
Real Name: Greg
Nice trip Ron and I hope you don't mind a brief hijack:
"The TRD Pro would have made it in 2WD while missing three tires, engine not running and one hand tied behind it's back." Next?
05-27-2015, 05:49 PM
Great pics - Just curious, I thought the descent control was exclusive to the trail editions? Does the SR5 have it? I'm asking because I thought that it DOES work in reverse as well (have to check my manual).
2019 Limited
05-27-2015, 06:41 PM
Real Name: BobH
Real Name: BobH
Great set of photos, looks like a trip I would like to make.
Surprised you did not make it to the top. OEM tires or Toyo MTs as in your signature? Did you air down or try it without ATRAC?
05-27-2015, 06:50 PM
Banned
Banned
wow well if you put it that way.... mt. Everest, here i come
05-27-2015, 08:32 PM
Crawl Control is only on the Trail Edition and it works in reverse. Descent Control is on the SR5 and Limited trims.
2010 4Runner Trail Edition
05-27-2015, 10:08 PM
Real Name: Dave
Real Name: Dave
Sounds like a perfect day in the desert. Thanks for sharing the pictures.
2013 Black TE. Roof rack delete. Rear seats removed. Sleeping Platform. Power Tank OBA. RCI Aluminum skids. OPOR Sliders. KO2's.
05-27-2015, 10:38 PM
Real Name: Ron
Real Name: Ron
It's always a fun day in the dirt. 11th off road trek in the 4Runner since I bought it December 10th. I'm liking it at least 95% as much as I did the LR Discovery - Will be 100% when I get around to trimming some of that low hanging plastic (when the wife isn't looking).
If the descent was working when backing down I couldn't tell - Going forward it makes so much noise you couldn't miss it. I didn't really need it though - Lots of sand drag.
Yes I was aired down - didn't add anything as the tires were buried to the inside of the rims - Can't get much more contact patch then that. It just sat there with all four wheels evenly slowly spinning and digging in. I woulda' got a picture but no-way do I get out of a truck hanging on a 45 degree slope.
Backing down with a rear view camera is the cats meow.
05-27-2015, 11:42 PM
Don't have much experience in sand in my truck, but I have hit a many sand obstacles in trials. Momentum and more throttle than usual is key. You have to float on top. Any sort of slow down and you sink/game over. Climbs are especially challenging. Lots of HP required (very different than rock/trail crawls)
The hill does work for you in the recovery scenario... I would hate to be stuck in sand on flat ground and have to dig out.
05-28-2015, 10:33 AM
Real Name: Ron
Real Name: Ron
Momentum only carries you so far - That ridge was about 100 yards long. After it slowed and came to a stop I was still able to get about another five yards before it just wouldn't move.
Have done some sand digging on flat ground - but it has been years. A-Track (=LR ETC) is wonderful.
05-28-2015, 10:56 AM
I can't believe you did all that without changing the interior lights to LEDs. Awesome.
05-28-2015, 06:40 PM
I would think that a sustained 45 degree slope would be beyond the limits of what the 4Runner is capable of especially on low traction situations. Getting into terrain like that always appears steeper than it is.
