Old 05-28-2015, 10:48 PM #1
FlaskTL FlaskTL is offline
FlaskTL is on a distinguished road
Exclamation Brake fluid/dash light situation/ fluid level
A few weeks ago I experienced a situation where I started up the Yota and experienced my ABS light, parking brake light, and maintenance light up. The parking break light and ABS light would blink intermittently before going off for a bit but would then come back on......
So I researched and found that this is a sign for low break fluid.....so I popped the hood and my fluid level was barely above the MIN line.....again it was above not below. So I added some break fluid and the lights went off and I haven't had a problem again....but here is my concern.....
What caused the loss of break fluid?? I don't think its my pads being low as I looked and had a friend at a shop look. He thinks I easily have another 20k mikes before I need new pads. Currently have 35k miles. I havent found any fluid on my garage floor to signify a break fluid leak either.
2 days ago I checked my brake fluid level again....when I first added fluid I filled it to full and let the system cycle and it took it down below full. I called it good and shut the hood.....now its back all the way to mid way between Min and Max....which I know is acceptable, but where is the fluid going??
Your help is greatly appreciated and my concussed brain will thank you when I finally figure this out.
FlaskTL is offline   Reply With QuoteReply With Quote
Old 05-29-2015, 12:17 AM #2
BlackWorksInc's Avatar
BlackWorksInc BlackWorksInc is offline
BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold
Well it will drop low when the pads are pretty worn, but that sounds a bit excessive to me...
BlackWorksInc is offline   Reply With QuoteReply With Quote
Old 05-29-2015, 12:29 AM #3
96r50 96r50 is offline
96r50 is on a distinguished road
Have you had any work done on the brake system at all? I'm with @BlackWorksInc , that's too much fluid loss to just be pad wear.
2010 4Runner Trail Edition
96r50 is offline   Reply With QuoteReply With Quote
Old 05-29-2015, 01:44 AM #4
No I haven't touched the brakes at all. I had a rotate balance and alignment done this past Sunday and they said the brakes are good to go and shouldn't have to worry about new pads for another 20k miles. The pads and rotors are the original ones that were on the vehicle when purchased new.
This is really bothering me only because I can't figure out what caused this. I'm not panicked about it as the vehicle is stopping fine other than the nose dive that we all experience if we have to lock em up. All has been normal since I topped it off a few weeks ago...except for noticing how far the brake fluid has dropped.
Again...I can't find a leak anywhere either....am I missing something?
Old 05-29-2015, 08:14 AM #5
philsey's Avatar
philsey philsey is offline
Real Name: Um, Phil?
philsey has a spectacular aura about philsey has a spectacular aura about
philsey's Avatar
I suppose it's remotely possible that it's always been low - that's a stretch tho.
Have you had it on a lift to get a good look around underneath?
2010 Blizzard Pearl SR5/P - traded
2018 Superwhite SR5/P ... IS350 retrofit.
philsey is offline   Reply With QuoteReply With Quote
Old 05-29-2015, 12:50 PM #6
So if I understand this right a few weeks ago the lights came on and you filled the reservoir from Min to Max, and now (two days ago) it's significantly lower than Max again? I think you must be missing something somewhere. That volume of fluid doesn't just disappear, especially not that fast. Have you traced all the brake lines inch by inch to ensure there are no leaks, as well as looking around by the master cylinder and brake booster?
Old 05-29-2015, 04:58 PM #7
Lester Lugnut's Avatar
Lester Lugnut Lester Lugnut is offline
Lester Lugnut has a spectacular aura about Lester Lugnut has a spectacular aura about
One more question. Is the brake pedal spongy?
2015 2WD Toyota Tacoma Prerunner V6 SR5 1GR-FE 236HP VVT-i
2014 2WD Toyota 4Runner SR5 1GR-FE 254 HP Dual VVT-i
2006 Toyota Avalon 3.5l automatic 2GR-RE Dual VVT-i
1991 Mercedes-Benz 300-SEL M103
1975 Kawasaki 900 Z1-B
Lester Lugnut is offline   Reply With QuoteReply With Quote
Old 05-30-2015, 11:44 PM #8
No I haven't fully traced each line yet....thats my next step.
Old 05-30-2015, 11:45 PM #9
Its always been spongey per say....makes the noise that most of us all hear when we hit the break pedal but when i need it to stop and stop quick it does it every time and the vehicle stops very fast.
Old 05-31-2015, 10:16 AM #10
1000MPH's Avatar
1000MPH 1000MPH is offline
1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all
1000MPH's Avatar
Is your ABS still working?
1000MPH is offline   Reply With QuoteReply With Quote
Old 06-02-2015, 11:37 PM #11
Yeah its working.
I think I found the source of the problem. Crawled under the vehicle tonight since we haven't had rain in several days and the front driver's side caliper is covered in fluid. I thought brake line might be loose coming into the caliper so I grabbed an open end wrench and tried to tighten it up....it moved a hair and thats it.....so I think the caliper seal is the problem. I cleaned the whole thing off with break cleaner and I'm going to check it each day for the next few days to see if I can replicate the caliper being covered in fluid. Tried to upload pics with my phone but the site keeps kicking me out when I try to do that.
Old 06-02-2015, 11:56 PM #12
Yeah its working.
So the brake line and bleeder screws are tight? Is the rotor covered in fluid and/or shows signs of overheating/slipping? I'm curious where it's leaking from. If you can get us some good pictures that'd be nice; I'd try to take a look when the wheel is off if you can.
Old 06-03-2015, 03:02 PM #13
Here are the two photos that I was able to take last night rather quickly.
Brake fluid/dash light situation/ fluid level-caliper-1-jpg  Brake fluid/dash light situation/ fluid level-caliper-2-jpg
Old 06-03-2015, 04:18 PM #14
Being quoted $455.18 for the driver front caliper....thats just the part.
A1 Cardone refab is $47 from CarID
Beck Arnley refab is $75 from Car ID.
Thoughts??
Old 06-03-2015, 04:30 PM #15
Thoughts??
Are you sure it's the caliper that's leaking? From the photos I'd guess the leak was more likely to be coming from the compression nut on the hardline.
Front/rear differential fluid, trans fluid and transfer case fluid change 88 Kel Varnsen Classic T4Rs 1 05-20-2012 03:26 AM
parking break light ON when brake fluid low? T?@\7 Classic T4Rs 17 03-15-2012 04:51 AM
brake fluid or differential fluid? RiverRat37 3rd gen T4Rs 11 09-27-2011 09:00 AM
E-Brake Light ! No Fluid ? skinnadoor Classic T4Rs 8 12-13-2008 01:04 AM
Brake fluid, transmission fluid, and rear differential fluid NViejeP 4th Gen T4Rs 12 03-31-2007 03:43 PM
