05-31-2015, 10:18 AM
Real Name: David
Real Name: David
Rusting Hefty Fabworks Dual Swingout Rear Bumper
Unfortunately, this winter my rear bumper started rusting...a lot!
I'm not quite sure why, but my guess is that the cold temperature we experience up here (-40 degrees Celsius sometimes) cause microcracks in the powder coat. Water gets underneath the coating, steel starts rusting and coating starts to flake off. The water jug holder is definitely the worst. I used a flapper wheel to remove the rust on the bumper and a power washer on the jug holder. I then did a light coat of flat black paint, which blends in seamlessly and some JB Weld as a filler (instead of bondo). Once it sets, i'll sand it smooth and paint with Rustoleum Textured Black (which according to Hefty matches perfectly with their powder coat).
Any of you experience serious rusting of your bumpers? I almost wonder if the the flat textured powder coat is more susceptible because my front bumper has zero sign of rust and it is has more of a gloss finish.
2010 Toyota 4runner Trail Edition w/ KDSS. Dual Battery w/ ARB Sidewinder Monitor. Radflo Coilovers / OW Lift Kit. Light Racing UCAs. Front Bumper. Dual Swing Out Rear Bumper by Hefty Fab Works. Budbuilt Full Skid Plates. Shrockworks rock sliders. Magnaflow Exhaust. 170 Striker HID. 9.5XP-S Warn Winch w/ wireless remote. Procomp Wheels. Cooper Disc STT tires. Baja Full Length Rack. Maxtrax Traction Aids. HiLift Jack. Yeti Tundra Cooler. Swag Offroad Action Packer Baja Bin. ROTOPAX gas and storage containers. Powertank C02.
05-31-2015, 11:13 AM
Ah the Canadian Winters just love to destroy things, between rust, rockchips and shitty roads...(I'm 50/50 Edmonton/Fort Mac)...I got no real contribution to the thread otherwise lol. Good luck with the fix!
05-31-2015, 12:51 PM
That's weird, I thought powdercoating was flexible enough to move with metal expansion?
05-31-2015, 01:21 PM
Real Name: David
Real Name: David
To be honest, I think there were some manufacturing shortfalls. Some areas I could see no cracking at all...its almost as if they powder coated over rusty or oily metal.
05-31-2015, 02:00 PM
they should stand behind their product. you obviously have enough pictures that show there is an issue with their finish work. I would continue hounding them until it was resolved.
Car History from 1st to Present: -1997 Mustang V6 (Sold); -1999 Chevrolet Blazer (Sold); -2001 Chevrolet Silverado Z71 (Sold); -1999 Chevrolet Z28 Camaro (Sold ); 1982 Jeep CJ-7; 2014 Trail 4Runner
The creator of the "TRAIL" badge
http://www.toyota-4runner.org/5th-ge...blem-made.html
05-31-2015, 02:01 PM
Real Name: Dave
Real Name: Dave
You definitely have some rust happening there. Rust Happens.
It doesn't get that cold here in So Cal that we need to use road salts or gravel. Isn't some of this rust due to road salts?
Looking at your prep work I can't see how much you ground, sanded or primed. I think you need to remove all of the loose paint and rust. I see edges of paint next to the bodywork that you can not get off if it's still on the car. You may need to take the bumper off so you can do some aggressive scraping, grinding and sanding. Once all of the loose paint, rust, oils and salts are removed, then primer and paint. Good luck.
2015 T4R Trail Edition w/KDSS. Baja Rack flat utility rack, Baja Rack ladder, WeatherTech floor mats, Demello rock sliders. RCI skid plates, Falken AT3W LT285/70R17 tires, ICON Stage 7 tubular 2" extended travel lift, ICON Rebound 17x8.5" 0 offset alloy wheels, Baxter Performance remote oil filter adapter. Side exit exhaust, 2nd recovery hook on rear frame corner, DIY wheel well liners with 1/4" neoprene rubber.
05-31-2015, 02:34 PM
shipping from Northern Alberta to Colorado Springs to have it repaired and back would cost nearly as much as the bumper itself did when it was new. best bet is to do the best job you can to repair the rust yourself, as he has done.
it gets cold enough here in the winter that they generally don't use salt, since it isn't effective below a certain temp.
2012 Magnetic Grey Metalic SR5 w/ upgrade pkg (Canada)
pretty much bone stock
Instagram: ab4runnin
Reason: typo
05-31-2015, 02:59 PM
Real Name: David
Real Name: David
I'm not going to go crazy...just touch up the bad spots and monitor. The flat paint blends in absolutely seamlessly so frequent touchups will be no big deal until it becomes unmanageable.
We live in a very dry climate so this rust is extremely odd. Not much salt use here, more sand because of the cold.
05-31-2015, 10:20 PM
Might also want to try some POR 15 I use this on one of my other trucks that has a replacement bumper and the stuff is tough.
Current Pack of 4x4 yotas...
2022 TRD LWB 4x4 Taco
2012 DC LT Baja Taco 4x4
2014 4Runner 4x4
06-01-2015, 08:57 AM
Real Name: David
Real Name: David
Done. Lets see how it holds up!
06-01-2015, 10:15 AM
Looks like you did a nice job refinishing it. Hope it holds up for you!
03-17-2016, 10:02 PM
any updates?
sorry to revive an old thread, but I'm on the precipice of ordering a hefty rear
08-28-2016, 09:37 AM
Any updates
Originally Posted by Jono.ful
any updates?
same thing here, would love to hear an update since I am seriously considering hefty
2011 4Runner limited- Shoreline Blue
Icon stage 2 (Tubular)
Cooper AT3 265/70/17
Fuel Wheels (17x8.5)
08-28-2016, 03:24 PM
Be prepared for a ridiculous wait, ordered mine Mar 19 and still nothing. Can't even get an answer from them about a new eta as "12-16 weeks" has long since passed
08-28-2016, 04:13 PM
That is ridiculous....A couple of weeks... even a few months. But 6 months is just silly.
