06-04-2015, 09:50 AM
Real Name: John
Real Name: John
Front Bump Stop Removal
So what's the easy way to remove the front OEM bump stops to install some new Superbumps from Wheelers besides buying an extra large pipe or crescent wrench? From what I measure they are abou 3" from flat to flat to grab onto.
2013 SR5 3rd Row, Radflo 2.5 W/Resi Coilovers, 2.0 Rear Radflo with 2" Radflo Springs, Metal Tech offset rear links upper and lower, Skyjacker Sway Bar FJ Links, Body Mount Chop, XD Hoss 20X9 -12, 275/65/20 BFG TA/KO (34"), OPOR Sliders, Bud Build Hidden Winch Plate with Warn M8000S, Factor 55 Flatlink, Factor 55 hitchlink, Rigid Industries Upper Grill w/SR20, Rigid Industries D2 flood custom reverse lights, Rigid Industries SRM2 Driving Lights as ditch lights, 2-10mm Rear driver side OME trim spacer, TRD cold air, Borla Cat Back exhaust, Spidertrax, trail edition rack, group 34 agm interstate battery, blue sea dual battery setup, arb 2500 awning, arb compressor, hi -ift extreme, 2 - 4gal Rotopax, Thule force XL when needed.
06-04-2015, 10:06 AM
Real Name: Dave
Real Name: Dave
I installed the wheelers not too long ago, what I did was jack the front end up took the front wheels off and let the suspension droop as low as possible. I used a large adjustable channel locks and they came off easy. To install this is where it can get tricky, the Allen wrench they provide is a tad too long, so what I did was took some gorilla glue and put some on the bolt head, so I could thread the wheelers on like the stock one. Worked like a charm. I do believe that you could prob do it without jacking the vehicle or removing the wheels, but I was installing new sway bar end links so I needed to have my wheels off anyway for more room to work.
•2014 4-Runner SR5P• FOX/ICON Suspension♦WKO Bumpout Sliders♦ICON Shock Skids ♦RCI Skids Front to Back♦
♦Baja Rack♦GOBI Ladder♦LED Interior Swap♦Weather Techs♦ 17x8.5 Level 8 Wheels/BFG TA/KO's♦ALL Pro Sway Bar End Links♦Wheelers Superbumps
06-04-2015, 10:10 AM
Real Name: John
Real Name: John
Thanks, the biggest Channel's I had last night barely fit and I couldn't get any leverage on them but I had the wheel on still too. Looks like bigger badder channel locks are the answer.
06-04-2015, 11:36 AM
There is some white thread locker type stuff on them, so they are a bit stubborn. I used a very large channel lock.
