Old 07-09-2015, 01:43 PM #1
PitbullRescuer's Avatar
PitbullRescuer PitbullRescuer is offline
PitbullRescuer is on a distinguished road
17x7 vs. 17x8.5 Wheels
Bought a 2015 SR5P last night. Love the truck, hate the factory wheels and the Dunlops. Considering TRD Pro wheels (17x7) or SCS wheels (17x8.5)
Anyone running 17x7's and wish they went wider? Anyone running 17x8.5's and wish they went narrower? I like the style of both wheels and will be sticking with 265/70/17's. Just looking for some input about how wide to go with the wheels. TIA
'98 SR5 4x4, cheap DD http://www.toyota-4runner.org/3rd-ge...im-addict.html '99 SR5 Highlander 4x4/5 Speed... http://www.toyota-4runner.org/3rd-ge...eed-build.html '97 SR5 4x4/5 speed, another new project... http://www.toyota-4runner.org/3rd-ge...new-build.html '00 SR5 4x4, new project, stay tuned... http://www.toyota-4runner.org/3rd-ge...ld-thread.html '97 Limited 4x4, freshened up quite a bit... http://www.toyota-4runner.org/3rd-ge...d-3rd-gen.html '99 SR5 Highlander 4x4... http://www.toyota-4runner.org/3rd-ge...ce-thread.html
PitbullRescuer is offline   Reply With QuoteReply With Quote
Old 07-09-2015, 02:05 PM #2
2014 Warthog's Avatar
2014 Warthog 2014 Warthog is offline
2014 Warthog will become famous soon enough 2014 Warthog will become famous soon enough
I got 8.5s because the tire I got specced 8-9.5 inch wheel.
However, I do munch the rim of the wheel a lot. 7 inch rims would have helped prevent that more. Course, maybe in those cases the wheel rim actually helped prevent me from popping a bead if more pressure had been put on the tire in that spot instead.
In reality I do not know if there are any actual negative consequences from putting a tire that says 8-9.5 on a 7 inch rim and a lot of people here seem to do it.
I think the main issue is the load ratings on the tire probably change a bit with the rim sucked in further than recomended. Might need a tad bit more air to maintain wall integrity than an 8.5 rim but... Just speculation.
The Warthog
Too many mods to list See my build thread ---\/
http://www.toyota-4runner.org/5th-ge...re-thread.html
2014 Warthog is offline   Reply With QuoteReply With Quote
Old 07-09-2015, 02:29 PM #3
DesertCanyons's Avatar
DesertCanyons DesertCanyons is offline
Real Name: Dave
DesertCanyons will become famous soon enough
Real Name: Dave
Stock sized tires on wide rims
Yea, the P-rated stock Dung Loops the car comes with are not good for off-road. You need a LT tire.
If you're sticking with the stock tire size there isn't much reason to go with a wider wheel rim. The SR5 has 7" rims. The Trail Edition comes with 7.5" wheels. We all want better tires for off-road. Go figure.
http://www.toyota-4runner.org/5th-ge...ent-guide.html
2015 T4R Trail Edition w/KDSS. Baja Rack flat utility rack, Baja Rack ladder, WeatherTech floor mats, Demello rock sliders. RCI skid plates, Falken AT3W LT285/70R17 tires, ICON Stage 7 tubular 2" extended travel lift, ICON Rebound 17x8.5" 0 offset alloy wheels, Baxter Performance remote oil filter adapter. Side exit exhaust, 2nd recovery hook on rear frame corner, DIY wheel well liners with 1/4" neoprene rubber.
DesertCanyons is offline   Reply With QuoteReply With Quote
Old 07-09-2015, 02:33 PM #4
WTERUNNER WTERUNNER is offline
WTERUNNER is on a distinguished road
I'm getting my SCS Stealth 6 wheels installed this Saturday. I'm also staying with the stock sized tire 265/70R17. If your not lifted the stock size is as large as you can go with the width and offset of the SCS wheels. Even so some of the more aggressive AT tires may rub a little and require a little trimming.
I say go with the SCS wheels. The quality of the wheels is second to none.
WTERUNNER is offline   Reply With QuoteReply With Quote
Old 07-09-2015, 02:38 PM #5
I'm definitely a Mall Crawler, no shame in saying it. LOL I think I'm going to do 5100's up front set at .85 but really just for looks. I've had them on other 4Runners I've owned and like them a lot. Don't want to loose too much camber and sacrifice ride quality.
As for tires, I'm leaning toward TerraGrapplers. I've also been quite fond of the Firestone Destination A/T's that I've had on a few 4Runners in the past. Either will do the job for my needs.
Old 07-09-2015, 02:44 PM #6
Mall Crawler here too. Get the SCS wheels, they give you a little wider stance which looks awesome. Out of the two tires I'd go with the Firestones. Had them on my FJ and loved them.
Old 07-09-2015, 04:04 PM #7
FattyHunter FattyHunter is offline
FattyHunter is on a distinguished road
I have TRD pro wheels and I do wish I went wider sometimes. Then I realize once the tires stick further out the fenders, itll throw a bunch of crap on the side of your truck like dirt, rocks and such. I also have 285 and no rubbing with 17x7 even though its not "recommended" for 285. Ultimately I just wish to run 16 inch wheels, cheaper tires and more options, but no go for 5th gens. Here's a picture of how the 265 tires look on 9 inch wheel, not on a 4runner but just a reference. Tacoma I had.
FattyHunter is offline   Reply With QuoteReply With Quote
Old 07-09-2015, 04:18 PM #8
From the pictures I've seen the SCS wheels with the stock 265/70R17 tire sit just about flush with the fender. If they do stick out it's not by much. The other thing to keep in mind is the type of tire you run. A BFG KO2 or mud tire will stick out a lot more than a Firestone Destination AT.
Old 07-09-2015, 04:29 PM #9
Forgot to mention that the two vehicles will look different with same wheel width. Like on a Tacoma, it only needed 7.5 inch width to be flushed with fender whereas the 5th gen 4runner, its not close to flush at all.
Old 07-09-2015, 04:40 PM #10
ccapman670 ccapman670 is offline
Real Name: Chad
ccapman670 is on a distinguished road
Real Name: Chad
Sorry not trying to derail thread, but what's advantage of SCS over TRD? Just width and looks? For us Mall crawlers.. I bought a SR5 2015 this past weekend and wanted to change the rims while keeping the same stock tires.
ccapman670 is offline   Reply With QuoteReply With Quote
Old 07-09-2015, 04:52 PM #11
I believe just width and looks unless you go 285 because they have a recommended wheel width of 7.5-9 inches. Search a few pages back and there's a thread about TRD pro wheels.
Old 07-09-2015, 04:52 PM #12
tristero's Avatar
tristero tristero is offline
Real Name: Justin
tristero will become famous soon enough tristero will become famous soon enough
tristero's Avatar
Real Name: Justin
Originally Posted by ccapman670 View Post
Sorry not trying to derail thread, but what's advantage of SCS over TRD? For us Mall crawlers.. I bought a SR5 2015 this past weekend and wanted to change the rims while keeping the same stock tires.
The SCS wheels are wider width for larger tires. They weigh slightly less than the TRD product
PTR20-35110 is 17x7" at 25lbs vs the SCS Stealth 6 is 17x8.5" at 24lbs
The F5 will be released in a few weeks with the same specs except will only weigh 22lbs.
Info on these TRD wheels
2010 4Runner SR5 Magnetic Gray: Radflo / Icon + Metaltech / Total Chaos / Dirt King / SCS Stealth 6 / BAMF Sliders + Pelfreybilt Bumper / PRINSU / Indel B / 2014+ IS 350 Retrofit
2012 GX460 Premium Black Onyx: Stock af
tristero is offline   Reply With QuoteReply With Quote
Old 07-09-2015, 04:58 PM #13
For me it was just personal preference. Both are very nice wheels and great companies to work with. I wanted some thing a little different than the standard black or gunmetal finishes that everyone was getting and SCS had just the wheel. I got the Stealth 6 in the matte gunmetal and machined finish. It looks great in pictures but in person it's amazing!
Old 07-09-2015, 05:00 PM #14
Real Name: Chad
Real Name: Chad
Do you happen to have a photo of yours on your T4R? Thanks
Old 07-09-2015, 05:05 PM #15
They get installed on Saturday but here is a pic Vin from SCS sent me.
17x7 vs. 17x8.5 Wheels-image-jpg
Fs 5 trail edition wheels 17x7.5 Boltz13 For Sale: Suspension/Wheels/Tires 0 07-05-2013 11:19 PM
(5) 4thGen 17x7.5" SR5 Wheels w/ almost new LTX MS2's jwild For Sale: Suspension/Wheels/Tires 18 02-03-2013 05:16 PM
FS: 17x7.5 Sequoia/Tundra Wheels. Set of 5! adio3x For Sale: Suspension/Wheels/Tires 12 07-23-2012 08:37 AM
WTB: OEM 17x7.5 or 18" set of four 4runner wheels sabre364 Want to Buy/Trade 1 07-31-2009 12:05 AM
