Originally Posted by WakeDreams
Update here, blew the dang fuse again when putting my boat in the water. Apparently this is just something I am going to have to deal with. I would just not plug the connector in to the hitch, but then I would have to strap the reverse pin in place which is next to impossible to get it to stay in correctly.
If you only want to connect the
'Brake-light' pins (HOT/GND), pick up a trailer hitch extension kit ($6.00) from AutoZone, cut the other wires that are
Un-needed; leaving only the brake lights functional. Cap off the unused wires and plug in the extension.
"...I can't find anywhere that water is getting in to exposed wires....this is frustrating to say the very least..."
Water is probably NOT causing a dead short across the hitch plug, as a
30A current draw would be hard to imagine at 12V through water...
...I would look for something else that may be shorting to Gnd.
Best to you!
