Adventures of 4RnR Grl (and build)
I ordered a set this morning from Camelback Toyota. I think it was $52 with shipping.
It'll fit with trimming per that "rocker trim" thread linked above. You'll only have one fastener, mine has held just fine though. What I found is taking a little more off versus less fit better, just used some snips.
To your comment about Moab 2017 elsewhere, caravan out with [MENTION=65614]Antman[/MENTION] and I'll go out there with you. Pretty sure my wife is going to say no until 2017 with all my travels lately anyway!
Awesome.
Yes, I want to make it out there. That's my goal. I wanted to go next year (2016), but.... puppies will take up a good part of next year.
:thumb3:
Many thanks to [MENTION=120209]tigger[/MENTION] [MENTION=122753]bane[/MENTION] and [MENTION=91899]Jhalko[/MENTION].
A box arrived from Arizona today.
No it was not an oil filter. My front rocker caps came. Took me all of two minutes to install them, in my three step process.
Remove the pink clip with some pliers.
Line up the new yellow clips with the existing holes.
Push on the new rocker cap.
Done.
Total for the two caps and part numbers.
Edit: The rocker caps should have a screw put through them. If not... you WILL lose them on the trail (as me how I know). Fortunately I recovered them but I will be screwing them on. With no trail use no need for a screw.
I just looked at the total on the recipe, but didn't enlarge the pic. At first I thought it said $855!! Thankfully my eyes were wrong haha.
Seems like if you wanted to run with no rocker trim below the doors, these would still clean up the fender line enough to keep things looking pretty good. What do you think?
I agree. But there is still a seam under the door that's visible without any rockers. It has an unfinished look. I did go for awhile without any rockers and decided to pick up the used trail rockers from another member on here. I'm really happy with it now.
stc6306
