Old 08-10-2015, 11:56 PM #1
RedStripeRanger's Avatar
RedStripeRanger RedStripeRanger is offline
Real Name: Reed
RedStripeRanger is on a distinguished road
Real Name: Reed
Wiring Diagram for Light Bar, Rear Lights, and D2s
Would like some input about how I am going to wire up my lights. I dont have any experience doing any type of electrical work, so hoping someone could tell me if Im totally off. Ive looked over threads and think I have it right but Im not sure.
I am going to use:
- Rigid SR 40"
- 2 Rigid SR 6"
- 2 Rigid D2s
- Cooper Bussmann Off Road Relay Fuse Box
- AOB switches
Need to make sure this is correct:
- 16ga wires for connecting accessories
- 12ga wires for AOB switches
- Is it ok to wire the negative wires in both diagrams like that?
- Is it ok to wire the ignition and dash wires like that (second pic)?
- Suggestions on connectors?
- What weatherproof plug does Rigid use?
If there is anything else that is screaming dont do that, please let me know. Last thing I want is to cause something to overheat or catch fire.
Wiring Diagram for Light Bar, Rear Lights, and D2s-image1-jpg  Wiring Diagram for Light Bar, Rear Lights, and D2s-image3-jpg
2014 TEP Magnetic Grey with KDSS // GooseGear Icebox and Drawers // Icon Stage-2 // Black Rock Type D Wheels // Toyo Open Country ATII LT285/70R17 // Gobi // Rigid Lights // Canvasback Max4 Camo // Rotopax // Maxtrax
RedStripeRanger is offline   Reply With QuoteReply With Quote
Old 08-11-2015, 01:58 AM #2
rigtec's Avatar
rigtec rigtec is offline
Real Name: Greg
rigtec is just really nice rigtec is just really nice rigtec is just really nice rigtec is just really nice
rigtec's Avatar
Real Name: Greg
I am going to use:
- Rigid SR 40"
- 2 Rigid SR 6"
- 2 Rigid D2s
- AOB switches
Hi RedStripe,
Maybe I missed something but... Are you using 16ga wire to the Loads/Lights but 12ga wire to your switches? That seems backwards. The 16ga wire is much smaller than the 12ga and much more current will flow through those wires to the lights/accessories than to the AOB switches (which are only used to trigger the relays using low current). Also, you'll need to run a heavier line from the battery POS and NEG (roughly 100A (MAX)/4ga "short distance") to the Rly box; the Winch will draw quite a few amps alone, and then add the lighting... Just a thought...Rgds!
2012 Limited (in bliz) Black leather interior.
Commercial hvac diagnostics/electrical specialist (Steamfitters Journeyman Local 475)
rigtec is offline   Reply With QuoteReply With Quote
Old 08-11-2015, 10:14 AM #3
Real Name: Reed
Real Name: Reed
Originally Posted by rigtec View Post
Hi RedStripe,
Maybe I missed something but... Are you using 16ga wire to the Loads/Lights but 12ga wire to your switches? That seems backwards. The 16ga wire is much smaller than the 12ga and much more current will flow through those wires to the lights/accessories than to the AOB switches (which are only used to trigger the relays using low current). Also, you'll need to run a heaver line from the battery POS and NEG (roughly 100A (MAX)/4ga "short distance") to the Rly box; the Winch will draw quite a few amps alone, and then add the lighting... Just a thought...Rgds!
Thanks for the help, I had the wires mixed up. This is the fuse box I am going to use:Universal Relay Fuse Auxiliary Distribution Box Jeep Cooper Bussmann Off Road | eBay. And I am not going to be adding the Winch for some time, but want wire up the switches now.
Old 08-11-2015, 12:44 PM #4
rigtec's Avatar
Real Name: Greg
rigtec's Avatar
Real Name: Greg
"Thanks for the help, I had the wires mixed up... ...And I am not going to be adding the Winch for some time, but want wire up the switches now."
This will be great project, and since you're just becoming familiar with auto electrical systems, a great opportunity to develop your skills!
PS: I hope you'll share this project (including pictures) with the rest of us; many will benefit!
Cheers
Old 10-15-2015, 10:14 PM #5
Real Name: Reed
Real Name: Reed
(Havent started this project, life happened but getting to it this weekend)
Another question came up, noticed the wires from the rigid lights are 14ga and the relay wires are 12ga.
Is it ok to connect these together? Planning on connecting via butt connectors and waterproofing them with marine heat shrink, probably 2 layers.
Old 10-15-2015, 11:32 PM #6
rigtec's Avatar
Real Name: Greg
rigtec's Avatar
Real Name: Greg
Another question came up, noticed the wires from the rigid lights are 14ga and the relay wires are 12ga. Is it ok to connect these together? Planning on connecting via butt connectors and waterproofing them with marine heat shrink, probably 2 layers.
Hi RedStripeRanger,
Yes! Both 'Ridge and cooper-Bussman' will have sized their product's wiring based on it's 'Full load' current capability; just be sure to use a properly sized in-line fuse in your accessory's harnesses no more than six to eight inches from the battery! Best
Old 10-16-2015, 10:53 AM #7
Real Name: Reed
Real Name: Reed
Hi RedStripeRanger,
Thanks for the help! Do I need to do that even with the relay box? I have put the right fuses from the original harnesses (ie some are 10s and 15s) in the relay box.
Old 10-16-2015, 11:55 AM #8
mtomaro's Avatar
mtomaro mtomaro is offline
mtomaro is on a distinguished road
mtomaro's Avatar
Need vs Should
Go pick up an 80A in line from a car audio shop. You can probably even find one at Walmart. They're pretty inexpensive at ~$10 with fuse and housing.
2015 4Runner Trail Premium
2008 Subaru Legacy Spec. B
mtomaro is offline   Reply With QuoteReply With Quote
Old 10-16-2015, 12:58 PM #9
rigtec's Avatar
Real Name: Greg
rigtec's Avatar
Real Name: Greg
Yes every fuse box, even in your home, has a 'Main Fuse' to protect the line that feeds it! So do be sure to include an in-line fuse holder/fuse no more than 8 inches from the battery! If the main supply line is 8ga then the fuse needs to be 60A max. If the line is 4ga then the fuse needs to be 100A max...etc.
Rgds
Old 10-16-2015, 01:06 PM #10
Real Name: Reed
Real Name: Reed
Rgds
Sounds good and actually added a 80amp Bussman circuit break between the battery and relay box.
Thanks again for all your help, really appreciate it
Old 10-16-2015, 01:15 PM #11
rigtec's Avatar
Real Name: Greg
rigtec's Avatar
Real Name: Greg
"Sounds good and actually added a 80amp Bussman circuit break between the battery and relay box..."
What size is the added electrical main wire and what's your anticipated 'full-load' current consumption from the sub-panel?
Old 10-16-2015, 02:03 PM #12
jrandom's Avatar
jrandom jrandom is offline
jrandom is a name known to all jrandom is a name known to all jrandom is a name known to all jrandom is a name known to all jrandom is a name known to all jrandom is a name known to all
jrandom's Avatar
Rigid uses Deutsch msd 8181 connectors
2013 TE w/ KDSS Nav
=-> Get yer Custom "Trail" Edition Emblem/Badge 3d Print here! or maybe you just want to go "Pro"
jrandom is offline   Reply With QuoteReply With Quote
Old 10-17-2015, 02:49 AM #13
Real Name: Reed
Real Name: Reed
I found rigid extension plugs on amazon for about $5 each, thank you for letting me know. Couldnt find the exact kind when I was originally looking.
@rigtec Anticipated main load with all the lights will be 20.2 amps with all 5 lights on at once. Will be adding a 2m radio to the mix down the road. Each set of lights has its own relay. This is the relay box I got if that helps: http://www.ebay.com/itm/321764858213...%3AMEBIDX%3AIT
Old 10-17-2015, 02:36 PM #14
jrandom's Avatar
jrandom's Avatar
No problem, they are a common plug apperently, I had never used them before I had installed my rigid lights. They are nice connectors.
I bought two single E2 four inch driving lights that each came with a single harness. I picked up a relayed light bar harness, a single too, oddly enough (they didn't make a double ended at the time) and sacrificed one of the original singles and spliced it in. What I am getting at I just bought new pins and was able to reuse everything else. Other connectors I have used in the past haven't ever been reusable, well without carefully dissecting them anyway.
2013 TE w/ KDSS Nav
Old 10-22-2015, 09:54 PM #15
Real Name: Reed
Real Name: Reed
So ran into a problem wiring everything up... Cant decide on how to get all the wires to the engine bay. I am running the lightbar and rear light wiring down each side of the windshield.
Is there a different route I should go (rear hatch) or should I drill/cut a hole in the plastic where the hood meets the body?
2005 4runner running board light wiring diagram Greenbean80 4th Gen T4Rs 2 04-11-2015 10:40 PM
Stock Rear Fog Light Switch Wiring Diagram cpguy33 Engines / Suspension / Wheels / Tires / Audio / Accessories 18 11-11-2006 07:43 PM
Need 91 wiring diagram for reverse lights Fo by Fo 3rd gen T4Rs 1 05-29-2006 01:49 PM
HELP!! Need Rear wiper wiring diagram / schematic FlyingDutchMan Engines / Suspension / Wheels / Tires / Audio / Accessories 3 12-13-2004 11:06 PM
