08-11-2015, 05:55 PM
TRD Pro rear springs???
I promise I searched before posting this. Maybe I'm not submitting the correct query but I have been unable to find an answer to my question.
Does the TRD Pro use different rear springs than the SR5 or Trail? Reason I ask is I see the TRD Pro "full suspension kit" for sale quite often. I've never seen it listed with rear springs until yesterday. Person selling the kit says they use different rear springs than non-TRD Pro vehicles.
I have a TRD Pro kit from TRDshop.com sitting in my basement but it does not have rear springs. I'm worried about installing it and having reverse take.
Can anyone confirm for me one way or the other if the rear springs are different or not? Thank you in advance.
08-11-2015, 06:00 PM
Pro rear springs are same as the Trail Edition. you should be fine.
10 TE - salsa, KDSS+JBL+Nav
ICON XT COs (+IVD) & tubular UCAs • ICON rear coils & 2.5 remote reservoirs + shin guards • Shrockworks • FN Five Star + 285/70 Mickey Thompson MTZ • TRD CAI + aFe Pro Dry S • Magnaflow • ARB diff breather • rack delete + Thule • H9 lo, 9011 hi, selective Y fog • FJ shifter • ScanGauge
06 SE, galactic gray V8: sold // 93 SR5, lots of rust, salt, & mods: R.I.P. // 71 FJ40, never should've let it go
08-11-2015, 06:06 PM
I have an SR5. Still okay?
08-11-2015, 06:13 PM
Real Name: Will
Real Name: Will
same thing
i'm pretty sure there's no difference between the rear springs on the SR5 and Trail. not 100% sure, but confident that it won't create any difference in ride height/reverse rake. the factory rake is pretty much 2" higher in the back... Pro front springs only provide 1" front lift... think you should be fine.
08-11-2015, 07:05 PM
Great, thank you all. Much appreciated.
08-11-2015, 09:10 PM
As Marshal and Sandcrawler said, the rear springs on the Pro are exactly the same springs. 100% sure.
2015 Super White TRD Pro
08-11-2015, 09:37 PM
Awesome, thanks again all.
08-11-2015, 10:03 PM
10-4 ^^ looked it up on camelback same parts no !
2011 SR5 Mgm 4x4 alpharex pro headlights & depo black tail lights level 8 trackers wheels & p285/70/17 cooper at3s, 6112s all around set 2.5 rear rancho spacer 11/4, FJ coils TRD intake.w/afe-dry filter Urd y-pipe flowmaster super70ii TE roofrails! 2014 Sr5 Superwhite Bils 6112s/eibach 2.5 /1 "rear springs 285s Cooper at3 ms on fj pc-d satin black, Urd y-pipe/Flow delta 50 muffler/all interior led lights & low beams sealights h7 led with laminx yellow fogs & oldreds puddle harness w/2010-13 mirrors
09-23-2020, 05:02 PM
For those of you that have done the TRD Pro kit, are rear springs required/suggested to be done at the same time or are they typically good for a while? My 2010 Limited has 150k on them.
09-23-2020, 05:58 PM
Limited color code = purple/orange, below. SR5/Trail/OffRoad/Pro have Pink/Orange. I looked again, corrected to pink/orange for non limited.
2015 4runner Limited - URD Y-pipe
2008 V6 Sport Edition
1999 4runner
TRD Air Filter. Airaid MIT. O ring mod. TRD Exhaust. Front Discos. TrueTrac
09-24-2020, 07:28 PM
Real Name: Tom
Real Name: Tom
Same spring unless you have a Limited. I installed the Bilstein Pro kit on my other halves 2017 SR5 and works just fine. The front spring is a TRD tuned spring though.
1978 FJ40. Mostly stock, reverse shackle 3 inch lift.
2019 Pro Voodoo Blue
09-24-2020, 09:54 PM
I installed the ‘18 trd pro Bilstein suspension on my ‘16 limited. When I compared the rear springs, they were identical in height, number of coils and colored markings.
Both my limited and pro has purple and orange springs.
09-25-2020, 05:47 AM
Does the TRD Fox suspension kit - 4RUN Suskit Se - Toyota (PTR61-89210) fit an 18 Off Road Premium using the stock Off Road Wheels?
I thought I had read somewhere it will only work w TRD PRO wheels. Id like to keep my Off Road wheels.
