09-14-2015, 09:44 PM
#31
Originally Posted by TotalAutomotiveLV
I did
Your a Bad MOFO
09-15-2015, 09:34 AM
#32
Real Name: Martin
Real Name: Martin
Thank you
01-07-2016, 05:33 PM
#33
Thank you for the continued orders and support T4R! We have a ton of lighting options in stock and are here to help you select the best options for your needs. Let us know how we can help - Info@TotalAutoParts.net
01-21-2016, 04:50 PM
#34
Real Name: Josh
Real Name: Josh
Just purchased a set of these, any idea on how to prevent theft on the lights?
04-14-2016, 04:49 PM
#35
Rigid makes a few security kits that we offer that will work, or check out our friends at losspreventionfasteners.com they have some crazy options that will make stealing your lights such a pain in the ass!
04-15-2016, 05:05 PM
#36
I'm planning on putting a set of ditch lights on my TE. I'm going to use them more for throwing light forward than to the ditches. I'm torn between the Rigid D2 spots and hyper spots. Can any one give me an idea of the beam difference? Google has not been helpful in finding a picture to compare them.
2015 TE, custom LED mount behind grill, N-Fab steps
2008 SR5, grocery getter
04-15-2016, 08:50 PM
#37
Wow, these ditch lights are cool… guess that's another item to add to my shopping list!
BTW, years ago when I first got into off-roading, CA law said you had to have covers on your off-road lights when on the road. Is that still true?
Ghost towns, mines, and more: www.raydunakin.com
2016 silver Trail Edition w/KDSS; BudBuilt sliders w/full tread plate; upgraded rear hatch lift struts;
BFG KO2 265/70/17; Gobi "no-rise" Stealth rack w/ladder; MetalTech front bumper;
King coil overs, upgraded springs, ~1.5" lift; RCI skid plates.
Megaweapon's build/adventure thread
04-18-2016, 06:32 PM
#38
I believe so. We do offer a full line of light covers for every Rigid Industries LED light we offer.
04-18-2016, 06:53 PM
#39
There is only the Rigid D2 Driving, Wide and Hyperspot. There is a Rigid Dually Spot tho. Here is the lux chart. For any forward facing light above the roof line, we highly recommend the tightest beam pattern you can find like the HYPERSPOT to minimize hood reflection.
Here is a lux chart showing the different beam patterns of the dually light series. Let us know if we can answer any questions!
04-18-2016, 08:25 PM
#40
This is my setup with Super Duty Headquarters ditch light brackets and Baja Designs XL lights.
@bajadesigns
2018 4 Runner TRD Offroad Premium
IG: @06HAOLE
04-18-2016, 08:28 PM
#41
Real Name: Josh
Real Name: Josh
I have a set of the brackets + AOB switch for them for sale. Going a different direction with my front end lighting.
2015 TEP W/KDSS. 285/70 KO2's, OPOR Sliders, GOBI rack, King 2.5 ext. travel w/adj, Weathertech Mats, Vision X front lighting, Spacers until time for new tires, ARB OBA, RCI Skids, Ellis Precision FJ Style shifter.
04-20-2016, 03:17 PM
#42
Looking good!
04-20-2016, 05:10 PM
#43
Real Name: CHRIS
Real Name: CHRIS
This is great info! Thanks for the write up. I am leaning towards the 4.5" Vision X Light Cannons with the ditch brackets. Probably won't be able to pull the trigger for a little bit but I will be sure to check out Total Automotive!
'15 TEP-Nautical Blue-KDSS- and some goodies
'05 Sport Edition Black - sold
'99 SR5 Autumn Blaze (my first ride) - sold
IG: @chrisewalden
04-20-2016, 07:05 PM
#44
One of the most popular lighting upgrades we get requests for are ditch lights, or lights that mount near the front A Pillar in the lower corners of the windshield. Weve put together a list of the most popular ditch light options that we get requests for, as well as a few new ideas you may not have seen. We highly recommend the CBI Offroad line of products, including their ditch light mounts that we offer for $49 with the purchase of any light set.
A traditional ditch light would mount with around a 45 degree outward angle and feature some type of flood light to, well light up ditches. Most of our customers are using them with a forward facing light - for this application we recommend tighter spot & extreme spot lights for maximum effectiveness at this mounting height, as well as to avoid light splash onto the hood.
CBI Ditch Light Bracket for 2010+ 4Runner
Without a doubt our most popular combination is the Vision X 4.5" Light Cannon set Only $330 delivered! We will beat any price on VX ( CTL-CPZ110KIT) on a set of CBI Ditch Brackets (5th Gen PN - GEN54Runner). The round light look is clean.
From member
@ mikey's2010SR5
Build.
If you like the round light look but would like something a little larger, or want a throwback look, be sure to check out the new 40w KC Hilites Pro-Sport Gravity 6" LED lights ( KC Part Number 643 - Spot Pair) with included oldschool KC light guards.
Speaking of KC Hilites, we saw their new FLEX LED system setup as a ditch-light on their Raptor. This new pair of dual 10w spot leds puts out a ton of light for the size and has a look like nothing else on the market. The anodized light bezels come in a variety of colors for a custom look. Youll need 2x Part Number KC 271, to get this look.
There isnt an LED light thread out there that doesnt mention the Rigid Industries brand and they have an array of options that work great in this position. If you like the size of the standard 2x2 dually, check out Rigids new Dually D2 Hyperspot which has a super tight, 5 degree beam for maximum distance in the ditch light position. Part number 50741 gets you a pair of the Rigid Hyperspot
Rigid Industries recently upped the LED cube game by releasing the bigger, badder brother to the Dually, the new Dually XL! Rigid 32241 is a pair of the above mentioned Hyperspot optic in a more powerful housing that is the optimum size for this location.
Leading the game in lighting technology in addition to Rigid is another US manufacturer based in San Diego - Baja Designs! These guys have been around for awhile now and are the number one choice among top offroad racers, sponsored or not! These are the most durable and longest lasting lights we offer - rated at IP69K with IK10 impact testing, used by the military / US Customs with ratings far exceeding the MIL-STD810G mil spec requirements.
Their smaller option for the 4runner a pillar mounts would be the 3x3 Squadron Sport SPOT Pair (PN 55-7801) @ 1800 lumens (Equal to a standard dually, but with much better optics that rival the Rigid hyperspot) or the Squadron Pro which pumps out an insane 4300 lumens (Pair Part Number 49-7801)
To get even more light down range, Baja Designs offers the XL Sport ( Spot Pair PN 56-7801) / XL-R Sport ( Spot Pair PN 57-7801) & XL Pro ( HS Spot Pair PN 50-7801) / XL-R Pro ( HS Spot PN 53-7809) models. The XL or XL-R (Round face) put out the light of an 8" HID with the smooth spread of an LED. With 4900 lumens per light, this is the brightest offroad LED light system this size on the market by far.
XL-R Pro
PN 56-7801 XL Sport Pair
Hella is a name that is well known in the racing and rally world. Their new Rallye 4000x 40w LED System is a super compact package pumping out a decent amount of light for the size. Its got a little wide of a pattern but has a pretty nice beam. Youll need 2x 012206021
Hopefully this gives you all some ideas as to what options are out there for this popular light mounting location. We are here to answer any questions you may have! Shoot us an email at Info@TotalAutoParts.net or PM us.
Remember, we offer a steep discount on all lighting products to T4R forum members. Because of pricing restrictions we cant post the discount code here, but please contact us with any method above and we will get you set up!!
TotalAutomotivePerformance.net
702.979.1577
We would love to see your installs & hear any tech tips you may have. Post up here and lets get this thread kicked off!
Forget the ditch lights, how about roof mounts for an LED light bar above the windshield that are low profile? Doesn't seem to be anyone that makes them. I'm wanting to get a 50" curved single bar but i want it mounted as close to "flush" as possible with the roof/upper windshield. I think you'd get some buy in from those of us who aren't running safari racks.
2021 JGC Trailhawk (waiting for the 6th Gen 4R
2015 Silver TE: (SOLD) KDSS, ICON stg 2, Magnuson, Victory Blitz sliders, Fuel Blitz DDT 18x9 w/ -12o/s, 275/65/18 Nitto TGG2, ARB skids, Spidertrax spacers, Alpharex Luxx, Rigid 40” Stealth LED bar & 360 fogs, Switch Pro 9100 w/ Mount Tray, KC Flex Dual Ditch Lights, KC Cyclone Rock Lights, LED interior, SSS hybrid winch bumper, 30" Rough Country single row LED, Alpine ILX-F308/R line speakers, 8" Alpine Powered Sub. Prinsu Full no-drill roof rack.
09-08-2016, 08:27 PM
#45
I know this is a 5th gen thread but curious if you have any fitment info for 3rd gens?
I'm concerned about fitment issues with the power antenna. I think the duallys from rigid fit fine, but I don't know about the other brands. I know the MRT equivalent of Vision X's light cannons rub on the whip antenna. This is something I don't want. Reference this thread:
MRT Spot Lights on 3rd Gen CBI Brackets Review w/ lots of Pics
1997 4runner. Sr5. 5speed. 191k.
