09-08-2016, 08:55 PM
#46
Real Name: 3 guesses..........
Originally Posted by Paragon1
Forget the ditch lights, how about roof mounts for an LED light bar above the windshield that are low profile? Doesn't seem to be anyone that makes them. I'm wanting to get a 50" curved single bar but i want it mounted as close to "flush" as possible with the roof/upper windshield. I think you'd get some buy in from those of us who aren't running safari racks.
https://www.bajadesigns.com/products...-light-bar.asp
or if you have deeper pockets
'12 SR5, Blizzard Pearl * Factory (style) Fog Light Switch-Fits knock-out! * 30" BD Stealth LED Light Bar, Upper Grill '12 SR5 * Reverse Light Mod-SR5 Factory Bumper * FN f(x) Pro Wheels - Custom Coating * LLumar Paint Protection/Tint, Flowmaster Cat-Back, Bilstein 6112/5160, LR UCA's, AirLift w/Load Control, 285/70/17 Nitto TG, LW's D2S 4.0 HID low beam mod, V-LED Interior/Reverse/LMZ High Beam/Turn Signals/V-6 DRL Lights (all 5000K), Kappa Dash/Doors/Hatch Speakers, CompuStar Remote Start, B&M Trans Cooler, Devil Horn Emblems, XB LED Fogs, Dongle Mod, TRD CAI, DC 270-XP Alt
09-22-2016, 12:52 PM
#47
Real Name: Travis
Real Name: Travis
For the guys that have the CBI brackets. What do you prefer on optics, flood or spot? Just curious how flood looks with glare from the hood vs how spot would look. If any has pictures from the inside with them on would be awesome!
09-22-2016, 05:13 PM
#48
Install / Hood Gap Question
Do these brackets require modification or trimmer of either the vehicle's under-hood plastic or the bracket to remedy the hood gap issue discussed on this forum, or does this product solve for that?
tl;dr: can I just bolt 'em on or is some work required?
09-22-2016, 06:07 PM
#49
A tight spot like Vision X Light Cannon, MRT LuxMaster, Rigid Hyperspot or Baja Designs Hi-Speed Spot. The tighter beams will reduce hood glare. The new Rigid Side Shooters are excellent if you want a true ditch light with light off to the side.
What year runner?
09-22-2016, 07:49 PM
#50
What year runner?
It is a '15
#51
It is a '15
09-26-2016, 02:54 PM
#52
Real Name: Matthew
Real Name: Matthew
It is a '15
Yes, you have to trim your plastic cowl slightly. If you go to CBI's website and click "Install Instructions" it shows you step-by-step what you'll need to do.
[2016 TRD Pro 4runner | Super-White | Yakima Cross Bars |Solimar Adventure Co. RTT |King 2.5 F&R Suspension w. Adjusters| Icon Overland Rear HD Springs|Falken Wildpeak M/T 33"| Rigid D2 Amber Fogs | CBI Dual Swing Out Rear Bumper | Double Jerry Can / HiLift ] [ 2018 Toyota Tundra TRD4x4 Off-Road | Cement Grey | Bilstein 2.5" Front Lift | Method NV Wheels] [1967 Toyota FJ40 Landcruiser OME 3" Lift, 327 SBC]
09-26-2016, 04:02 PM
#53
Originally Posted by madbomber08
I know this is a 5th gen thread but curious if you have any fitment info for 3rd gens?
I'm concerned about fitment issues with the power antenna. I think the duallys from rigid fit fine, but I don't know about the other brands. I know the MRT equivalent of Vision X's light cannons rub on the whip antenna. This is something I don't want. Reference this thread:
MRT Spot Lights on 3rd Gen CBI Brackets Review w/ lots of Pics
i had them with Piaa's. The antenna rubbed the cover.I have then still if you want to buy a set.
10-17-2016, 02:38 PM
#54
TotalAutomotiveLV, a couple of questions before I purchase,
To get even more light down range, Baja Designs offers the XL Sport (Spot Pair PN 56-7801) / XL-R Sport (Spot Pair PN 57-7801) & XL Pro (HS Spot Pair PN 50-7801) / XL-R Pro (HS Spot PN 53-7809) models. The XL or XL-R (Round face) put out the light of an 8" HID with the smooth spread of an LED. With 4900 lumens per light, this is the brightest offroad LED light system this size on the market by far.
Is it both XL Pro and XL sport that produce 4900 Lumens?
Also do you sell the XL80? is it the same size with 9500 Lumens?
Reason: another question
10-26-2016, 02:10 PM
#55
The XL80 is the same size housing as the XL Pro & Sport models.
XL Sport - 1,800 Utilizing 4 Cree XP-G2 LEDs @ 20w
XL Pro - 4,900 Utilizing 4 Cree XP-L LEDs @ 40w
XL Racer - 4,300 Utilizing 4 High Intensity Unnamed LEDs @ 40w
XL80 - 9,500 Utilizing 4 Cree Unnamed LEDs @ 80w
Remember, Lumens are not a very good judge of useable light output and are a theoretical number most of the time. Example, the racer makes 600 less lumens than the XL Pro but throws light an average of 40% further than the XL Pro.
12-29-2016, 02:09 AM
#56
Does anyone know what the weight capacity of these brackets are? Didn't seem to see that info anywhere...
pjo
02-15-2017, 04:29 PM
#57
Weve fit 6.7" cannons at 5lbs and the Baja Designs XLs on them with no problems.
11-02-2017, 09:21 AM
#58
Real Name: Chris
Real Name: Chris
Just put some ditch brackets and lights on my 06. I put auxbeam pods in and they are awesome and shine forever!
11-21-2017, 06:53 PM
#59
Black Friday and Cyber Monday Specials - Click Here
_
02-12-2018, 06:09 PM
#60
Real Name: Luke
Real Name: Luke
Dragging this back from the dead.
Has anyone done an install where you have a 3 way selector switch? I want a toggle to turn on Left Only - Both - Right Only in addition to an On/Off switch. I haven't seen anything like this yet. I'm guessing this will be a pair of switches on the low voltage side of a pair of relays?
