08-18-2015, 11:22 AM
Those of you with air bags...
I have a set of air lifts that I'm ready to install. However, I was curious that since these have to run a minimum of 10 psi all the time, does that increase the rear ride height when empty?
The truck has the normal rear high rake to it now, which is fine. However, if it gets any higher, I'm going to bite the bullet and install some 5100's up front to level it out.
Thanks,
Grant
2014 Trail Premium (TRD "Faux"): Bilstein 5100's front and rear, Air Lift airbags, TRD Pro appearance conversion.
08-18-2015, 11:48 AM
Yes. If you leave them at 10psi it will increase your empty ride height - and you will notice an increased spring rate as well.
I had them in my last 4runner and usually left them at around 5psi, and that gave maybe 1 inch of lift on a 3rd gen, but the 3rd gen tended to sag a bit, so it was a welcome improvement.
08-18-2015, 11:53 AM
I went with a different install and made it so I can hook up straight to my compressor with a built-in pressure valve and gauge. At 10 psi there is little to no lift, just firmness in the rear suspension. Mine starts to lift (if unloaded) past 10 psi. You'll be glad you put in airbags if you carry much weight. I just spent two weeks on the road with a few hundred pounds of gear inside my 4Runner and a 3800lb boat in tow. My mpg dropped to 10-12, but at least my ass wasn't dragging. The airbags make the vehicle much more stable when loaded and help it retain a comfortable rake.
08-18-2015, 12:56 PM
Thanks for the responses. I tow a pretty heavy pop up camper (~3800 lbs loaded) so I'm looking forward to getting rid of the sag, which is significant. But, 99% of the time, the truck is empty, so I thought I would compensate with some 5100's to make it all nice and level. Sounds like that's what I need to do.
Thanks again
08-18-2015, 01:07 PM
Real Name: Jeff
Real Name: Jeff
Thanks again
FWIW:
One of my lines had rubbed very slightly on the spring perch causing a hole and subsequent leak. I noticed the leak when it was friggin' cold out this past winter. I didn't get around to fixing it until the spring and figured I would need new bags because I drove around for months with zero air in them...
Patched the line and they still work perfectly and hold air 100%. Very durable!
HERE FISHY FISHY FISHY!
08-18-2015, 02:32 PM
^^ good to know!
08-18-2015, 02:53 PM
Real Name: Karl
Real Name: Karl
Another thing with the air bags is if you cover the tubing with split wire loom this will cut down on the possibility of wearing a hole in them.
http://www.amazon.com/Best-Connectio...ords=wire+loom
This or something similar.
2016 Barcelona Red Trail
Its 5:00 somewhere.
WARNING: T4R.ORG IS HAZARDOUS TO YOUR WEALTH
08-18-2015, 04:26 PM
FYI - I have had two Firestone's split where the bottom spring perch contacts the bag. (different sides at different times). I ended up cutting the top 2" off the damaged bags. Then I cut the centre tube coupler out, then rolled them inside out. Basically made an airbag perch for the replacements (which Firestone sent me no questions asked, just a photo) to sit inside. I RTV'ed the inverted airbag cradles onto the spring perches and no more issues!!! I drive in -30 deg and colder temps and I think the bags can't handle these low temps because they looked like they cracked under that type of cold situation.
02-21-2016, 01:48 PM
Sorry to dig up old topic but I'm on fence of going with bags. Running SAW 1.5" coils now and very happy with normal daily use for ride stiffness and all. Standard empty truck and someone's a few people or bicycles on hitch isn't a thing. Maybe 5x a year I'll be towing an actual heavy load or fully loaded truck.
Would it be worth it still? I worry keeping bags at 5 psi minimum as they need to be will increase rear stiffness. Which I really don't want. Also don't want any higher while empty.
Thanks for input
'19 White TRD Pro
TRD CAI - Magnaflow 15584
Pedal Commander - D2 Fogs - 20" in Grill
02-21-2016, 02:11 PM
I don't notice any added stiffness at 5 psi or any extra height. Very glad I have them when towing a heavy trailer.
2014 MGM TEP - Dobinsons’ C59-300, Bilstien 5100 (front set to stock height), Cornfed 1/2 spacers in rear, Spidertrax, Airlift 1000
02-21-2016, 02:12 PM
I picked up 0.5" with 10 psi in coil-rite airbags in my 5th gen. I cannot tell if the ride changed.
Thanks for input
02-21-2016, 02:44 PM
Real Name: Patrick
Real Name: Patrick
Thanks for input
I doubt at 5 your going to notice any difference what soever
White 2016 TEP .....My ROAM Truck Build....... My ROAM trailer Build
02-21-2016, 04:56 PM
Real Name: David
Real Name: David
No discernible difference in ride height or stiffness with 5-10 lbs. in mine.
Sure do appreciate them when towing the camper.
2015 Trail Edition, Barcelona Red / Shrockworks sliders/ Airlift 1000 / Cooper AT3's 265/70/17 / Baja long rack /
02-21-2016, 07:26 PM
Same here. Mine are between 5-10psi most of the time and I haven't noticed any negative effects on the ride.
2010 4Runner Trail Edition
02-21-2016, 07:48 PM
Real Name: Keith
Real Name: Keith
My personal opinion is people worry too much about the minimum pressure. For a point of reference...when you lift the rear hatch of my 4Runner you'll see a small leftover fuse holder box with two schrader caps and valve cores in it in the storage tray area next to the jack cubby. If you look directly down next to where the hatch latch is on the bumper skin you'll see the fill locations for the air bags with the aforementioned items missing.
I have done this in a couple vehicles with coil spring type airbags. No matter what air you have in them unloaded they can be harsh on big hits and they do change the spring rate. I leave the valve cores and caps off so they can naturally flex and move without trapped air pressure. Never been a problem.
2015 TEP/KDSS
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Bug Out Bags
Logan714 |
Off Topic |
13 |
12-12-2013 08:19 PM |
Air bags and Wdh
lezavw90 |
5th gen T4Rs |
3 |
06-05-2012 03:53 PM |
Air bags
cj80cruiser |
3rd gen T4Rs |
7 |
02-07-2012 03:02 AM |
ARB with air bags?
buck912 |
3rd gen T4Rs |
2 |
08-23-2009 03:51 PM |
air bags
thunderpaw |
4th Gen T4Rs |
2 |
10-08-2003 08:28 PM |
