Old 08-20-2015, 11:05 PM #1
RysiuM's Avatar
RysiuM RysiuM is offline
RysiuM is on a distinguished road
RysiuM's Avatar
2012 SR5 rear bumper question - Custom Rear Fog Light (for EU)
Hi,
In 2012 SR5 on the very bottom of the stock rear bumper cover there are slots: on on the driver side and two on the pass side (it would be symmetrical like on the driver side but the exhaust pipe is in the way) like on the image below.
In my T4R the slot is filled with some black plastic insert looks like just for show for not particular practical reason. What I like to do is use these slots for rear fog lights (red LED). Is there any stock option or aftermarket lights that would be a direct fit replacing these black plastic inserts?
2012 SR5 rear bumper question - Custom Rear Fog Light (for EU)-4runner_rearbumper_cover-jpg
2012 4Runner SR5 4x4 (Bismarck) - all stock with minor improvements.
1995 Tacoma LS 4x4 ExCab (Taliban Truck) - all stock with minor improvements.
My "Bismarck" is the first 5th Gen 4Runner in Poland. Local Land Cruiser Diesel is just a luxury form of a farm tractor.
Motto: Diesel is for heating, gas is for cooking, electricity is for lights. Cars use petrol.
RysiuM is offline   Reply With QuoteReply With Quote
Old 08-21-2015, 12:18 AM #2
Jono.ful's Avatar
Jono.ful Jono.ful is offline
Jono.ful will become famous soon enough Jono.ful will become famous soon enough
Jono.ful's Avatar
"rear fog lights"? what?
2012 Magnetic Grey Metalic SR5 w/ upgrade pkg (Canada)
pretty much bone stock
Instagram: ab4runnin
Jono.ful is offline   Reply With QuoteReply With Quote
Old 08-21-2015, 12:33 AM #3
cjacob316's Avatar
cjacob316 cjacob316 is offline
cjacob316 is on a distinguished road
cjacob316's Avatar
California, so isn't it smog?
Depending on what you actually want to acheive, you may want to look for something that you make a cut out for rather than trying to squeeze into that space. Especially since I don't think it's the same size on the other side.
2015 Magetic Grey Trail Edition w/ KDSS
Front: Toytec/Bilstein 5100 adjustable coilovers at 2.5". Rear: Bilstein 5100 with OME 895E rear coils.
ARB CKMA12 air compressor.
cjacob316 is offline   Reply With QuoteReply With Quote
Old 08-21-2015, 08:16 AM #4
mdogg mdogg is offline
mdogg is on a distinguished road
It's a very Euro thing.
OP: you will have to go pretty custom for that small of a space. LED strip lighting, small DRL lights with red lens, small individual LEDs, etc. Not to mention you'll have to consider if you want it to have the existing asymmetric design OR make it symmetrical and blend it into the existing black trim pieces. Best of luck.
mdogg is offline   Reply With QuoteReply With Quote
Old 08-21-2015, 11:01 AM #5
RysiuM's Avatar
RysiuM's Avatar
Yep, exactly. In order to drive it in Europe you need that. While it is not required here in US, actually it makes perfect sense. If you drive in heavy fog (sometimes we have nice fog in Sacramento area) the only way to see the car in front of you is when driver steps on brakes. Red markers are not visible in fog at all. Euro "rear for lights" are additional red "marker" light of the same brightness as brake lights. They need to be at least 10 inches of the ground and not higher than 3 ft. And 4 inches away from a red marker light (don't ask me why). Don't need to be symmetrical - one on the left side is enough.
One option often used is replacing bulb of the left backup light with red LED (and routed to separate switch). Other option (which I like more) is to replace rear red reflector plates with "real" LED powered lights.
I was hoping for answer, that in some models these slots are used for red reflector plates like in many other cars have, and just my T4R is "cheap low end" version which has black plastic inserts in there. It is easier to convert reflector plates to "real" lights than making one from scratch.
The symmetry is only cosmetic issue (I don't say it is not important). I would need only 5W of LED light which will give more light than 20W incandescent bulb so technology is available, just a matter of making it the easiest way.
Old 09-18-2015, 12:40 AM #6
RysiuM's Avatar
RysiuM's Avatar
More research and I found part numbers for these black trim pieces. Got them from ebay for "experiments" - I did not want to mess around my original trims in case something goes wrong. I wanted to keep my 4Runner close to stock look but legal for "euro thing".
From Amazon I got total 8 bred LED bulbs (ZITRADES High Power Car 1.5W SMD Ultra bright LED Eagle Eye Red Light). Actually they are only 0.9W each but still very bright with light output about 100 lumens each. I made my own housing from 3/8 aluminum plate, trim pieces I got from ebay and silicon seal. I don't have pictures from the build but got the final "product" installed.
As you can see there are two LED lamps 100% weather sealed (they must survive salt on the road) with the light output about 400 lumens per lamp. The brightness is same or better than stock brake lights. That is enough to be legal on the other side of the pond.
In USA they are connected to trailer connector so they give me extra brake/blinkers - kind of high power tail bar. For Europe both lamps will be reconnected to additional switch on the dash (''AIR ON BOARD'') powered from rear marker lights circuit (rear fog lights have to be independent from front fog lights). BTW they are mounted in the bumper cover using the original stock trim mounting so in case I need to replace the bumper cover it will be easy to move these lamps to the new bumper cover. These LED bulbs are "made for tanks" so they should survive minor rear-end run-over.
Old 09-18-2015, 11:25 AM #7
bane bane is offline
bane is on a distinguished road
I think that's pretty cool. Definitely see the use of rear brights for foggy conditions having driven through the thule fog in the central valley. My only critique is that it looks like you can see some of the silicone seal on the top of the lights. I would have liked to clean that up, but like I said I think this is a cool idea.
2012 SR5 4x4 Magnetic Gray, Third Row, Cooper Discoverer AT3 LT 265/70/17 load range C, Bilstein 5100s at 0.85, Husky Weather Beaters and Mud Flaps, Front Air Dam Removed, Canvasback Cargo Liners
Former Tacoma Owner https://flic.kr/p/s1m3mS
bane is offline   Reply With QuoteReply With Quote
Old 09-18-2015, 03:25 PM #8
RysiuM's Avatar
RysiuM's Avatar
That is not a silicone. It is reflection of each bulb lenses in the bumper. Looks like a white/semi-transparent blob but it is how the clear lenses would look from the top :-)
Old 09-18-2015, 03:59 PM #9
TrkyMfns's Avatar
TrkyMfns TrkyMfns is offline
TrkyMfns is on a distinguished road
TrkyMfns's Avatar
It looks like this would be useful when it's raining really hard. For some reason, people down here feel it's a good idea to use their hazards...
2011 SR5/P 4WD Blizzard Pearl - 285/70/17 Falken Wildpeak AT3/W - Bilstein 5100 Lift @ 2.5 - SPC UCA's - Two-Tone Katzkin Interior - 15% Lumar Pinnacle Ceramic Tint - Canvasback Liner - Husky Weatherbeater Liners - Phillips Interior LED's - Completely upgraded ICE.
TrkyMfns is offline   Reply With QuoteReply With Quote
Old 09-18-2015, 05:16 PM #10
I see it now, nice install.
Old 09-20-2015, 02:41 AM #11
RysiuM's Avatar
RysiuM's Avatar
I made two pictures with light off and on. This shows as white "blobs" are turning red when lamp is on.
2012 SR5 rear bumper question - Custom Rear Fog Light (for EU)-blink-gif
Old 12-18-2015, 01:01 PM #12
SnrDisregardo SnrDisregardo is offline
SnrDisregardo is on a distinguished road
This is awesome. I am looking to do this myself. I was going to try to integrate it in with the turn signal somehow, just the one side, but this gives me some direction. You don't have a write up on making these?
2016 4Runner TE Barcelona Red
SnrDisregardo is offline   Reply With QuoteReply With Quote
Old 12-18-2015, 02:38 PM #13
RysiuM's Avatar
RysiuM's Avatar
Nothing more that I already put in this thread. ZITRADES Leds are screwed into 6061 3/8 aluminum plate which works as a heat sink. Aluminum plate is painted black for the look. ZITRADES Leds have quite long thread (some have M10-coarse other M10-fine thread) so they go through the black trim piece (the one I was asking about). All four wires are bundled behind the trim piece and go through the plastic bumper behind the trim (I drilled 10mm hole in the bumper for these wires). Of course all four bulbs are connected in parallel.
Now there is an ugly part, may sound like ghetto, but actually it works. The entire space between the aluminum plate and plastic trim is filled up with black silicone (gasket maker). It works as a glue making sure the metal plate stays with the plastic trim (does not vibrate off) and protect the guts of the lamp from the environment. It simple looks like the lamp is one solid piece with the original plastic trim. So far LED bulbs are holding up and I hope I will never have to replace them (it would require some major surgery to remove all silicone).
Below there is a picture of two ZITRADES bulbs one with M10-1 (fine) thread, the other with M10-1.5 (coarse) thread
2012 SR5 rear bumper question - Custom Rear Fog Light (for EU)-m10-coarse-m10-fine-threaded-bulbs-jpg
Old 12-18-2015, 04:43 PM #14
Thanks! After looking at my rear bumper though, I don't have those trim pieces to add to. I have a 16 Trail. I am trying to be sleeper about it using factory locations and don't necessarily want to blast holes I the bumper.
Old 12-24-2015, 03:53 PM #15
RysiuM's Avatar
RysiuM's Avatar
Now I will have some time to wire a switch to rear fog lights. I bought Air On Board switch, very nice quality switch that fits 4R like a factory switch with few exceptions:
- the back-light is red, not orange. The switch contains red 3mm LED on the board. I'm going to replace it with orange 3mm LED that I just ordered.
- the back-light for both LEDs (upper and lower) have the same common ground. It means that if I want the switch to dim with the rest of switches, the back-lighting indicating that switch is "ON" will also be dimmed. I don't like it.
So first I disassembled the switch and reverse engineered the circuit (very simple). With some trace cutting and soldering I'm going to achieve:
1. Lower back-light (the text) will be orange (like all other 4R switches) and will dim with all other switches.
2. Upper back-light (symbol) will be red (now it is green) and will shine full brightness regardless of the dim position.
I will post pictures after the modification, for now here is how the switch looks inside.
2012 SR5 rear bumper question - Custom Rear Fog Light (for EU)-switch-jpg
Rear Bumper compatibility question BlueGuitar 3rd gen T4Rs 4 08-09-2015 11:42 PM
2012 4runner Rear Bumper Fix for Dogs buzzface 5th gen T4Rs 15 05-10-2014 08:21 AM
Rear suspension question for CBI rear bumper. OCMEDIC 4th Gen T4Rs 1 10-03-2013 03:11 AM
rear bumper question dirtbike250x 3rd gen T4Rs 4 01-15-2011 10:54 AM
Rear bumper question ? RED123 Classic T4Rs 6 07-16-2007 08:18 PM
