Old 08-26-2015, 06:44 PM #1
mrtifftiff mrtifftiff is offline
mrtifftiff is on a distinguished road
Aftermarket Suspension Routine Maintenance
What do you do for routine maintenance? I have an Icon lift front and back as well as LCAs from TC. Should I be greasing the parts on a semi-regular basis? Specifically the uniballs. What about joints/bushings/ect? I don't trust myself to be take anything apart but was curious what everybody does to prevent excess wear and tear.
mrtifftiff is offline   Reply With QuoteReply With Quote
Old 08-26-2015, 06:48 PM #2
Jeremy556's Avatar
Jeremy556's Avatar
Triflow on uniballs and spherical bearings as often as I think about it, grease for bushings every oil change. The spherical bearings on top and bottom of shocks wear out and need regular replacement, and shocks need rebuilt.
Old 08-26-2015, 07:06 PM #3
dahorst dahorst is offline
Real Name: David
dahorst is on a distinguished road
Real Name: David
If you have shin guards, clean them out regularly so that any moisture in the crud won't corrode your shafts. You can also spray some lube on the section of the shaft that doesn't get normal use. +1 on lubricating the uniballs, mine got severely corroded. Depending on use and climate, complete rebuilds will be necessary at some interval. I have yet to blow a seal between the shaft and reservoir but blew 3/4 internal floating piston seals. 1 shock had no leaks so all I did was do a fluid change.
2010 Toyota 4runner Trail Edition w/ KDSS. Dual Battery w/ ARB Sidewinder Monitor. Radflo Coilovers / OW Lift Kit. Light Racing UCAs. Front Bumper. Dual Swing Out Rear Bumper by Hefty Fab Works. Budbuilt Full Skid Plates. Shrockworks rock sliders. Magnaflow Exhaust. 170 Striker HID. 9.5XP-S Warn Winch w/ wireless remote. Procomp Wheels. Cooper Disc STT tires. Baja Full Length Rack. Maxtrax Traction Aids. HiLift Jack. Yeti Tundra Cooler. Swag Offroad Action Packer Baja Bin. ROTOPAX gas and storage containers. Powertank C02.
dahorst is offline   Reply With QuoteReply With Quote
Old 08-26-2015, 07:07 PM #4
Thank you. I had both rear and front driver rebuilt ~3 months ago. The front driver spherical bearing (Demello called them heim joints. same thing?) fell to the ground in pieces when they took it apart. I have synthetic bushing up front. Same care required?
Old 08-26-2015, 07:10 PM #5
SKP-4R's Avatar
SKP-4R SKP-4R is offline
Real Name: Sean
SKP-4R will become famous soon enough
SKP-4R's Avatar
Real Name: Sean
Any recommendations on products to use? So far nothing has been squeaking on my ICON stage 2 but I do want to make sure it gets taken care of properly.
'15 Trail Edition Attitude Black w/ KDSS | ICON Stage 2 | Dirt King UCA's
SKP-4R is offline   Reply With QuoteReply With Quote
Old 08-26-2015, 09:01 PM #6
Jeremy556's Avatar
Jeremy556's Avatar
Heim is often used interchangeably*. I imagine the Icon UCAs have zerk fittings at the bushings. You may want to check with what Icon recommends, but Total Chaos recommends SuperLube grease, and that is what I use.
* My understanding, a heim is a threaded rod end with a spherical bearing in it
A spherical bearing or uniball is the same type of bearing, but can be pressed into a multipart rod end or used in other applications, such as in place of ball joints, or as shock mounts.
Triflow seems to be highly recommended, and what I use.
If routine maintenance is performed...how long do they last? glocke12 5th gen T4Rs 15 09-28-2014 11:12 AM
The importance of routine maintenance checks... Macaque 4th Gen T4Rs 6 06-12-2013 05:02 PM
Routine summer maintenance for road trips (Am I missing something?) Vancouver93SR5-BLK Classic T4Rs 7 07-26-2012 12:10 AM
After routine maintenance....P0125 & P0171 robstibz 3rd gen T4Rs 6 08-07-2010 05:52 PM
time for maintenance? and suspension question RoyB 3rd gen T4Rs 0 09-21-2008 09:04 PM
