While I'm thinking about it:
When I left the dealer after the service I noticed that the "OUTSIDE AIR TEMP" display was reading 61 degrees F. It was really about 91F. So I pulled over, shut off the ignition and started it again - No change!
I thought about turning around and taking it back. I stopped about 5 miles away for lunch. I pulled out the operators manual and there was no explanation about calibrating the temp readout.
I went in and had a leisurely lunch -> about an hour. I turned on the truck and the temp was reading correctly = about 93F. Perhaps it was affected by the service tech resetting the maintenance reminder? It never happened on previous service trips - - - -
Totally stock 2013 SR5 4WD. Have added Toyo Open Country M/T LT 265/70-R17 (E) tires the first week I owned it. Added second set of Toyo M/Ts at 86900 miles.Added RCI OFF-ROAD Rock Slidersat 84000 miles. Added RCI OFF-ROAD front skid plate at 90,000 miles.
Daily driver and so far spending about 30% of time/mileage off-road. Previous truck 2004 Land Rover Discovery that also spent about a third of it's life off-road.
I HANG AROUND HERE "THE T4R FASHION FORUM" JUST FOR LAUGHS.
Perfect vehicle as it stands for northern Nevada terrain. Keep it stock - it'll go most anywhere as is.
