04-09-2019, 07:38 AM
#31
Damn this site is good! Literally just had this tear off when rolling up my window this morning and was going to ck here for solutions, then bam! It's a top thread on the first page. Freaking reading my mind! Love it.
09-09-2019, 07:32 PM
#32
Double check your parts numbers before ordering...
The rear window numbers above are reversed; 757 21 35011 is the right rear not the left rear......
2011 LTD, Magnetic Grey, Leather, Nav, Custom Expedition Box, Ballistic Morax flat black 18" with Hercules Terra Trac 275 65 18, Toyotec lift and level, Flowmaster 40 series, CBI ditch light brackets 36w 6.6 6000k 60 degree flood LEDs, OSRAM Nightbreakers and PIAA Extream White DRLs, Tint, Full chrome black out (dip), door handles Fusion black out and moving the other dip to Fusion, Front licence Plate relocate, Grill mod and front end black out, Uniden Bearcat 980SSB with 4' Firestick rear mount, on board UHF/VHF, Weathertechs, Zulu Visor....just getting started...
09-11-2019, 03:21 PM
#33
Thanks for this!
I joined up here today because this post was excellent and I used it to order weather strips for my 4runner.
I appreciate all the effort you made on this, just outstanding!
Thanks again!
David in OK
09-17-2019, 12:45 PM
#34
I have purchased the front strips previously, but just ordered the belts for the second row and the rear hatch. They have needed to be replaced for some time. OEM Part Source seems to have the best deal right now. No free shipping, but after using the code 10OFF, shipping was only like $10.
Part Number Price
75721-35011 $39.16
75722-35011 $39.16
68292-35041 $25.62
Subtotal: $103.94
Estimated Standard Shipping: $11.09
Discount: -$1.11
Total: $113.92
2011 T4R SR5 premium- Magnetic Grey
Suspension: Dobinsons heavy duty suspension with JBA upper control arms l Tires and Wheels: 285/70R17 Nitto Ridge Grapplers on Level 8 MK6 17x9 -12 l Armor: Coastal Offroad front and rear bumpers, LFD Offroad full roof rack and wide skid, RSG Sliders l Other: 23Zero Walkabout 72, Spyder Auto headlights, Warn Evo VR 10s l Coming Soon: ?
10-27-2019, 06:16 AM
#35
Easy-Peasy...
Originally Posted by chitown616
Thanks all! Antman I think that is the process for the inner window weatherstripping! Which will probably be next on the list. Deep.. you are correct.
After an adult beverage and looking at the new pieces I gave it a shot, figuring there was only 1 clip that was actually holding in. 30 min later all 5 outer weatherstripping pieces were done. $600 my as* Findlay Toyota Flagstaff. This really could not be any easier. You just have to be careful when removing not to scratch the paint on your door.
Here is the process......In order of photos.....
1)Buy parts...
Front Drivers- 75712-35011
Front Passen- 75711-35011
Rear Drivers- 75721-35011
Rear Passen - 75722-35011
Rear Hatch- 68292-35041
2)Locate the clip on the specific part you are replacing and locate it on the one thats on the truck.
3)PRY UP CAREFULLY. I used a standard screwdriver wrapped in duct tape. Deep a plastic putty knife is a good idea. THIS IS THE PART TO BE CAREFUL WITH. You can scratch your paint pretty easily if you are not careful. Use your fingernail to get the weatherstrip piece up, then use your tool to go under it and keep going up. You will probably break the plastic clip off, but you thats okay. Just use pressure and get it up and off.
4)Grab the now loose piece, and start working it out of the channel it is in by the mirror, once that is done you can pull it straight up and back.
5)Throw the broken piece at your neighbor.
6)Clean off any left over plastic crap.
7)Start installing the new piece with the end in the mirror channel first. Then working it down until the clip os in its home. Press down firmly over the entire length to ensure a tight fit.
8) REPEAT!! The rear doors have 2 clips and the hatch window has none. The hatch you will end up mutilating, but thats okay. It installs as easy as the others.
9) Enjoy adult beverage and your work!!!
Had it in my mind that I was going to have to pull door panels to install the new moldings. Part numbers are correct, procedure is correct, everything posted above was very, very helpful. Thank you!!
10-29-2019, 10:18 AM
#36
Its been some time since I've been active on this forum and much like this forum, my 4Runner has been neglected over the past few years.
I am getting ready to sell it and noticed the passenger side weather stripping is failing and I'll have it replaced prior to selling. I love how easy it was to find this thread / process / info.
Too easy! Thanks all!
::2010 Trail Edition:: ICON Front Coilovers w/Remote Resi's and CDC - ICON Tubular UCAs, ICON Rear Ext-Travel Shocks w/Remote Resi's and CDC - MT Long Travel Springs and Lower Links, 285/70 Goodyear Duratracs, Bronze Countersteer Offroad Type X, CBI Rear Bumper w/Tire Carrier, Shrockworks Sliders and full skids, Pioneer Z120BT, Rockford Fosgate Speakers and Amps, aFe Intake, Aux Battery set up, Roofrack by drabbits, SoCalTrail Behind the Grill Light Bracket
11-14-2019, 01:23 PM
#37
My front passenger side just went. Thanks for this write-up.
Parts ordered from Roseville Toyota.
$177 shipped for the 4 doors. Prices have gone up since 2015.
Other places had them a bit cheaper but shipping was higher.
11-14-2019, 04:31 PM
#38
Appreciate the write-ups, but to the original poster's comment (from way back when), has anyone had any luck getting these replaced under warranty?
I took ownership of a new 2019 earlier this year. If it's rained, the window is dry, I put it down, and then bring it back up and it's wet. Now that it's gotten cold here after a rain, the window is frozen shut and I hear ice in the door when I close it.
Understandable for something that's been sitting in the elements a few years, but not a brand new vehicle.
My weather stripping was either installed wrong or was garbage to begin with. And it's all 4 doors, too. I'm not big shelling out the amount required for the parts here...which sounds like it's over $100, for something so new.
Looking to hear any stories...
05-06-2020, 12:13 AM
#39
Real Name: Matt
Real Name: Matt
I just noticed my rear hatch trim fall apart in this southwest florida sun. Bought the part off amazon, had to pry the old one off with a padded putty knife, then used plyers to grab the top of the trim and pull. No issues, no damage to the body. Cleaned the metal on the body with an old shirt and water, then snapped the new one on..in 5 mins. Thanks again.
2011 4Runner SR5 - Black
Stubby Antenna - 5% Tint - Weathertech Liners
Pioneer AVIC z130BT w/Camera feed in Nav
Ultra Gauntlet 20 X 9 - Nitto Terra Grappler G2 275/55r/20
H11 XTREME LED PRO Kit
07-07-2021, 02:43 PM
#40
I love it when a 6 year old thread saves the day! Got the part # and saw the note about a TR4 discount at Camelback.
2011 Trail Edition w KDSS
07-10-2021, 09:56 PM
#41
Just finished my 5 weather strip replacement. Thanks to the OP!
08-16-2021, 02:02 PM
#42
1)Buy parts...
Thank you for posting this. I was able to follow and easily tackle this during a lunch break. I love this forum!
08-18-2021, 10:26 AM
#43
I’m needing to replace the weatherstripping on my rear window. I have the new one on order, but it won’t be here till next week. Until then, If I get caught in rain, what kind of issues will I be looking at? Anybody have issues from water intrusion in the rear hatch?
2014 MGM TEP - Dobinsons’ C59-300, Bilstien 5100 (front set to stock height), Cornfed 1/2 spacers in rear, Spidertrax, Airlift 1000
08-18-2021, 12:55 PM
#44
There are the small drains at the bottom of the liftgate. To be sure I would remove the back panel and look for myself.
You can see some pics here to get an idea of what it takes to remove.
Removing rear hatch cover
08-23-2021, 04:30 PM
#45
Replacement of the rear piece took me about 10 minutes. That included cleaning the window and area of door that the strip covers. There was a lot of dust underneath the trim piece. I used a plastic trim tool to remove the original. It was almost as easy as changing the air filter.
