Old 10-16-2015, 06:38 PM #1
GabrielM GabrielM is offline
GabrielM is on a distinguished road
Question Parking brake seize, need help
Even if I somewhat use my parking brake, it's now seize and I'm looking to unstuck them to at least be able to use the truck.
I do have read the manual, but today I removed a wheel and tried to remove tension on the tensioner, but wasn't able to rotate the disc to align with the hole at the bottom. I also tried to remove the disc but the parking brake pressure didn't allowed me to do so.
Any pointer or tricks you may think of to guide me for when I'll try again?
Thanks
2022 T4R OR (Cdn edition)
2016 T4R TE (SOLD)
2010 T4R TE: 275/70R17 BFG KO2, Bilstein 5100, TOYTEC 2.5" lift. (SOLD)
1987 Land Cruiser HJ60 (SOLD)
1974 FJ40 (SOLD)
GabrielM is offline   Reply With QuoteReply With Quote
Old 10-16-2015, 08:11 PM #2
flyinhawaiian01's Avatar
flyinhawaiian01 flyinhawaiian01 is offline
Real Name: Chris
flyinhawaiian01 will become famous soon enough
Real Name: Chris
Is this an SR5? Limited? 2WD? 4WD? Will the vehicle actually drive forward/backward if forced (maybe try 4 low to move it)?
Need more info to answer this correctly, but if its an FT4WD, you will not be able to rotate the wheel until all 4 wheels are off the ground.
If it isn't, or its 2wd, you should be able to just put a flat bar between two wheel studs and rotate it using the bar as a fulcrum. Of course, if its really that frozen, you may not be able to get it to break loose at all.
2011 4 Runner (my daily driver)
1987 Xtra Cab (35's and locked front/rear, the trail toy!)
1985 Supra (430rwhp track toy!)
2006 Honduh Odyssey (the wife's van)
flyinhawaiian01 is offline   Reply With QuoteReply With Quote
Old 10-16-2015, 08:43 PM #3
-It's a 4wd Trail Edition, so part-time 4wd
-Yes, it can move forward /backward. At higher speed, it made a loud noise as repeatedly hammer sound. I only drove to came home.
-I've drove on 4H this morning prior to remove the wheel, I may forgot to put it back in 2wd.
2016 T4R TE (SOLD)
1974 FJ40 (SOLD)
Old 10-16-2015, 11:35 PM #4
Real Name: Chris
Real Name: Chris
If its still in 4 high, that's why you can't turn the wheel to get to the service window to align. You'll probably need to roll forward and back a couple of feet to get it to disengage.
Try doing that, then see if you can get the wheel to turn.
Old 10-17-2015, 09:01 PM #5
Problem solved. Thanks for the help @flyinhawaiian01 .
2016 T4R TE (SOLD)
1974 FJ40 (SOLD)
5th gen , brake , parking brake
Parking Brake SoCal4Run 5th gen T4Rs 25 08-15-2014 12:15 PM
parking brake jkpott Engines / Suspension / Wheels / Tires / Audio / Accessories 5 05-15-2014 08:14 AM
Parking Brake jmm3807 4th Gen T4Rs 0 08-04-2013 11:41 AM
Is driving 07 T4R with the parking brake shoes on, only hurting the parking brake’s jow 4th Gen T4Rs 2 05-15-2013 02:31 PM
Driving while parking-brake is on brake zak4runner Maintenance/Detailing 9 04-07-2007 08:24 AM
