09-27-2020, 03:41 PM
#2176
Originally Posted by blschaefer1
Hello, new member and first post here.
I just picked up a new 2020 ORP, and have TRD SEMA wheels incoming.
My intent is to replace stock tires with Falken AT3W SL in stock size.
I’ve spent an hour reading through this thread, so apologies if this is redundant but I can’t seem to find a definitive answer.
As the TRD wheels have slightly less offset than the stock wheels, and these Falken’s appear to run a bit wide, will I have any rubbing issues on a bone stock non-KDSS ORP?
Had these tires on a Wrangler and loved them, BTW.
Thanks in advance.
I have the same exact set-up, aside from mine having KDSS. While I have not fully flexed out the suspension off-road, the only rubbing I’ve experienced so far is at full-lock in reverse.
It’s not bad, and could probably be handled w/ just a little modifying of the fender. I simply avoid full-lock in reverse.
Here is the Toyota TRD Pro fender mod:
https://www.toyotapartsdeal.com/reso...kit%20issa.pdf
09-27-2020, 07:28 PM
#2177
Thanks. I'm thinking a leveling kit might be easier?
09-27-2020, 07:43 PM
#2178
If the tires rubbed before lifting, than they will probably still rub occasionally after a lift when compressed. Fender mod isn't too difficult to do and and is the more effective method imho.
2019 ORP - KDSS, Dobinsons C59-302/GS59-700 front and C59-725/IMS59-50701 rear, Dobinsons UCA, DuroBump/Daystar bumpstops, Sonoran Steel High Articulation tracbar, Marlin Crawler LCA frame brace, OGS Lo-Key Bumper w/ Warn VR EVO 10-S, RCI Sliders, fully armored with RCI/C4/Outgear Solutions skids, Falken Wildpeak M/T 285/70/17, LFD SS-Crossbars, ARB breather kit (Rear Diff and Locker), ScanGaugeII, Anytime Front/Backup Camera, onboard ARB Twin compressor MORRFlate kit, and DD SS3 Sport fogs
09-27-2020, 08:27 PM
#2179
X2! I installed 5100s set on .85 and still have the slight reverse rub. Will do the fender mod one of these days...
09-28-2020, 06:50 PM
#2180
Originally Posted by StrykerT4R
Sorry to hear about that. Looks like a big gash on your sidewall? Are your tires rated LT?
Yup, 255's only come in LT. I was running 20psi, but I hit the rock just right and it went right through. I think any tire would have been gashed on that rock.
2016 T4R SR5: Ironman FCP w/ Performance Springs l RAV4 Mirrors l TSO Pro Grill l TSO INCOG Front Bumper l Raptor Lights l 255/80 Falken WildPeak AT3W l CaliRaisedLED Ditch Light Brackets l Avid Sliders l Custom Drawers l R1 Concepts Rotors/Pads
5th Gen Build
1996 T4R Limited: E-Locked l 285 KO2's l Toytec BOSS w Superflex l SS Panhard l Ultra Gauge l AIRAID MIT l Drifter CB Mount l AOF Sliders l Weathertech's l Hilux 167 Snorke l Cobra 19DXIV l Ditch Lights l Relentless Front Bumper l Superwinch Tiger Shark l Paranoid Fab Din Switch
10-11-2020, 02:24 PM
#2181
Originally Posted by kevstaarr
I have these in stock size, 265/70/17. SCRunner12's review is pretty spot on They are pretty quiet compared to stock tires. So far, I'm happy with them especially since I got them for a good price. I haven't had a chance to wheel with them yet, but when I do, I'll chime back in.
These wheels look good! What wheels are they? width and offset?
10-12-2020, 10:45 AM
#2182
Best AT tires ive ever ran in the wet.
10-12-2020, 11:13 AM
#2183
X2!
Very impressive all-around tire.
10-12-2020, 05:23 PM
#2184
I've had mine for 3 weeks and haven't seen a drop of rain.
10-15-2020, 09:39 AM
#2185
Originally Posted by High4
Drobs, 265/70-17 with SL load.
Sorry for the slow reply.
I just had 2 US made Falkens added to my 4Runner and now I'm feeling some steering wheel shake. Finding it goes away after about 20 minutes.
2019 OR - LT285/70R17 Yokohama Geolandar MT, SPC UCA's, BMC, Eibach Pro Truck Lift, Warn VR10 Winch, Warn 100022 Winch Bumper, TRD Skid Plate, Cali Raised Light Bar, Shrockworks Sliders and Skids, LFD Ruggadized Cross Bars, Sprint Booster.
10-15-2020, 04:46 PM
#2186
I've been researching wheels and tires for the last week and I'm having a hard time finding an answer. I finally decided to give up and ask the questions I was curious about. I honestly haven't seen anyone on here with a front leveling kit only. At least not where I have been looking.
I have a 2019 TRD Pro with a Cornfed 3/4" Front Spacer Leveling kit. I know that 275/70/17 will work with stock wheels on that setup for KO2s because someone was generous enough to post a picture of their setup without a front leveling kit. I figured if they fit without the leveling kit then they should fit with the leveling kit.
I have a few questions.
1. Will the Falken A/T3W fit my setup in 275/70/17 with stock wheels without any further modifications?
2. Will the Falken A/T3W fit my setup in 285/70/17 with stock wheels without any further modifications?
3. Will the Falken A/T3W fit my setup in 275/70/17 with Method 17x8.5 0 offset wheels without any further modifications?
4. Will the Falken A/T3W fit my setup in 285/70/17 with Method 17x8.5 0 offset wheels without any further modifications?
10-15-2020, 10:28 PM
#2187
Real Name: BLACK TRD PRO
1. Will the Falken A/T3W fit my setup in 275/70/17 with stock wheels without any further modifications? YES
2. Will the Falken A/T3W fit my setup in 285/70/17 with stock wheels without any further modifications? MAYBE
3. Will the Falken A/T3W fit my setup in 275/70/17 with Method 17x8.5 0 offset wheels without any further modifications? NO
4. Will the Falken A/T3W fit my setup in 285/70/17 with Method 17x8.5 0 offset wheels without any further modifications?[/QUOTE] NO
10-15-2020, 10:57 PM
#2188
Here are some pics with a 1.5" Cornfed spacer up front with AT3W's in 285/70-17 with slight articulation. No rubbing with a minimum of 1" clearance on the front fenders or back at the mud flaps. No clearance issues with the UCA's either.
10-19-2020, 10:27 AM
#2189
4. Will the Falken A/T3W fit my setup in 285/70/17 with Method 17x8.5 0 offset wheels without any further modifications? NO
I wonder is the KO2 will fit with the Method Wheels and 275/70/17 or do I need to stick with the factory tire size if I want to go with the Method wheels?
10-19-2020, 11:50 AM
#2190
KO2's always run smaller.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
