04-19-2019, 01:37 PM
#1336
Originally Posted by MAST4R
Would you mind measuring their exact tread depth while brand new?
The P-metric are said to be 14/32 but in reality they are 13/32 with occasional 12 and 14/32 readings. I am curious about the LT.
04-19-2019, 04:40 PM
#1337
I could have sworn the WildPeak LT's were 18 but I can't remember exactly. Edit, just saw the pic, looks like 16.
My BGF K02's load C were 14, manufacturer said they were 15. I guess close enough, maybe my guage was a little off.
2017 Off-road Premium w KDSS, moon roof, sliding rear cargo deck,3" Toytech Boss lift, SPC upper control arms, Sonoran Steel High Articulation KDSS Trac/PanHard Bar, RCI sliders, RCI skid plates aluminum including gas tank, C4 Fab diff skid plate, SCS Ray 10 Wheels Matte Gray, 285/70R17 Hankook Dynapro AT2 RF11 E-load RWL, Cali Raised LED 3x2 fog-light pods, Lock'r Down EXxtreme console safe with electronic lock, Auto Heat Shield all windows, Raingler rear cargo net, Canvasback rear covers, LFD Off-Road cross bars aluminum, LFD Hybrid bumper, LFD wind fairing, LFD Hi-lift jack mounts, Goat Armor, Blackgate Custom KDSS spacers, Ironman 2.5 awning with quick release mounts, Ironman 12,000 lb synthetic line winch.
04-19-2019, 07:22 PM
#1338
So which tire is worse for acceleration?
Heavier but smaller diameter LT275/70 load range C or the lighter but bigger diameter 285/70 p-metric?
2018 SR5 Premium MGM
TRD Pro wheels
LT265/70/17C BFG KO2
04-19-2019, 08:18 PM
#1339
Originally Posted by Jaykulast4r
Thanks!
It looks like 17 vs 18 advertised, same as all others I have seen.
They all seem to be 1/32 less at the start, not sure why. Not sure what and how is measured but for personal use it seems useful to just subtract 1/32 from whatever is advertised.
Next time I go to Discount Tire, I should use my gauge to see if this is indeed true across the board for AT tires
(6112s/650lb at 2.25" lift, 8100 rear with Bilstein B12 1.5" springs, Mickey Thompson ATZ P3 LTE 265 70 17, RCI set of front 3/16 skids, Shrockworks step sliders and 3/16 steel gas tank skid, C4Fab rear diff skid, Rockmen rear LCAs, Total Chaos rear LCA bracket skids, Diode Dynamics SS3 white fog lights).
04-20-2019, 09:46 AM
#1340
Just installed, no rubbing whatsoever rides like stock, cant tell about the noise but will update. Just drove it 4 miles shop to home in Nj pothole cursed roads. 275 no lift.
04-20-2019, 09:53 AM
#1341
MT's vs AT's, both are great tire:
04-20-2019, 11:07 AM
#1342
[QUOTE=Jaykulast4r;3275129]Just installed, no rubbing whatsoever rides like stock, cant tell about the noise but will update. Just drove it 4 miles shop to home in Nj pothole cursed roads. 275 no lift.
Just want to make Sure
So at full cranked turn backing up or making a U turn no Rubbing and you have a SR5 4X4 275/70/17 on stock rims do you have mud flaps or gaurds ? thanks
18 FunRunner
04-20-2019, 11:45 AM
#1343
[QUOTE=edgesalon;3275177]
Yes that’s correct, i got the factory flaps, checked and made my wife back it up fully lock and no rubbing anywhere, was surprised too! 2019 sr5 4x4 on stock rims no lift.
04-20-2019, 05:15 PM
#1344
Real Name: Tom
Real Name: Tom
I don't remember the exact measurements, but I can say that the load range E on my 4Runner are much deeper after 30k miles than the brand new P's on my Dads Jeep. I was surprised because its actually a pretty big difference.
2012 Trail (KDSS), Falken Wildpeak AT3W (E) / General AltiMAX Artic's, Level 8 MK6 (0), Pilot stubby, Max Liners
04-20-2019, 07:54 PM
#1345
[QUOTE=Jaykulast4r;3275194]
thanks i might have to look at 275 instead of 265 now to wait for a Sale
18 FunRunner
04-21-2019, 09:29 AM
#1346
Real Name: Alan
Real Name: Alan
What are people running for tire pressure with the P285/70R17? I started at 34/35psi but have since adjusted down to 31, might go down to 30 or would that the to low. It seemed like when I was running 34/35psi the outer edge on the front wasn't making contact with the road and was starting to feather a little bit.
04-21-2019, 10:17 AM
#1347
The size should not matter. I run 33 normally on and offroad with 35-36 for long highway trips. My outer edges have a tiny bit more tread than the rest but the difference is negligible.
04-21-2019, 10:41 AM
#1348
Do a chalk test.
Buy some kids oversized chalk they use on driveways
Over inflate you tires
Find a flat parking lot
Cover a section of tread side to side with the chalk.
Rolled it one or two revolutions
Look at the chalk. You want it to just barely be touching at the edges of your tires. Keep deflating until you reach this. This will be your running temp.
Of course what sucks here is the 4R does not show the psi for each wheel in its stock set up. Sooooo....get the tires up to temp and lower them to your new psi setting.
Then you can check your psi in the morning or whenever the tires are completing cooled down for your cold psi setting.
Finding the right psi for your rig based on its weight and tire is going to give you the best ride, tire longevity, reduce cupping. Just be sure to rotate AT tires every 5k or so. I have gone 60k on Duratracs 33” on my JK doing this with completely even tire wear and zero cupping. 4R will get the same treatment.
Do not fill to tires rated max psi. The factory psi will only be a rough target, added weight, different tires, extra plys, etc play a big role. Also bigger the tire the more air, so temps outside play a bigger role. Real bummer the 4R does not provide this display! I will be upgrading to a new head unit, and getting this info is a big part of that. I can feel a difference in ride when they are only 2-3 psi over target.
2019 ORP, 6112/5160, Eibach load leveling springs #250, Cornfed 1/2 in front spacers, JBA UCA, RCI alum skids, TRD Pro skid, TRD Pro grill, TRD Pro valances, Baja S8 30”, 3x Baja LP4 and Baja fogs, Rays 10, Toyo AT3 185/55, Canvasback, tinted windows, clear mask, UpTop Alpha rack w/ custom fairing, Borla, AFE CAI, URD MAF, Switch Pros, Power Trays, single ARB, rod vault, iKamper X-Cover, 23Zero 270 awning, Baja scene lights, Baja S2 rear fog/camp lights, RSG KDSS skid and sliders, Coco Mats, Ellis shift knobs, C4 ladder, Kenwood DNX696S/iData link, Morimoto XB Gen2, Morimoto Tails, custom 80/20 platform with slider, RokBlokz XL, WeBoost, C4 Low Pro w/ high clearance, Warn VR10 with Factor55, etc
04-22-2019, 11:02 AM
#1349
My tpms in the dash came on after about 20 miles driving, was wondering what psi do guys run with these tires on 275 sizes. I checked and the shop put 40 on all four corners think thats what triggered it?
04-24-2019, 12:09 AM
#1350
Definitely the 275C for me but they did absorb more bumps and provided a softer feel of the road.
I'm glad I swapped them for the 285P I needed freeway boost. For the three trips I took they perform well off road. I just wish I had bought lighter wheels for less rotational mass.
2011 Starfire Pearl GX460 stock base ;)
2012 Blizzard Pearl SR5 | 285 Toyo OC AT3 | Level 8 Slam | YotaWerx ActiveDuty | Die Hard AGM w/ArcLightLeds V2 Booster | Borla 40665 | URD Y & MAF Cal TRD | C4 Center LP | Maxbore 2mm TB "loaner from my boy Dave" | X20 10k Factor55 | Shrockworks Armory | RCI LCA skids | TC Gusset | LFD Offroad 7/8 | TJM Airtec dry aFe HPS coupler w/TRD CAI tube | B8 6112 | 650# King | ICON Delta Joint | Fox 2.0 VS| SAW 1.5" |230k|
| 03 DCSB Tacoma OME equipped, +320k Still Truckin |
