02-22-2020, 11:03 PM
#1996
Originally Posted by MAST4R
Are you running the 600lb springs? My SL Wildpeaks were perfect with those at 32 psi. But my current combo of 6112 on 650 springs and LTE ATZ P3 at 35 works better for comfort on road than 6112 on 650 springs and SL Wildpeaks at 30. Go figure. My guess is that the heavier weight plays better with the heavier duty suspension.
The 600lb springs are very soft with the 6112 and they made for a fantastic ride quality at 32 psi for me with the SL Falkens. But they were too soft offroad for my use.
Thanks for the info. Yep, I am running the 600# spring on the 6112s at the 6th clip. I will give 32psi a shot to see what it feels like to compare and I will report back. I did not have any issues with my slow speed off-roading at stock weight with the KO2s, but I can see how speed and additional weight could cause some issues with the SL Falkens paired with the 600# spring.
2016 Trail | KDSS | Bilstein 6112 2.7” | Eibach Pro-Truck Rear Shocks and 1” Springs | 285/70/17 BFG KO2 | SPC UCAs
02-28-2020, 11:18 PM
#1997
Discount matched Walmart/ amazon currently $123.00 - stock size
03-01-2020, 10:26 PM
#1998
Originally Posted by RedRunner_87
How to you like the 255s?
2019 ORP, 6112/5160, Eibach load leveling springs #250, Cornfed 1/2 in front spacers, JBA UCA, RCI alum skids, TRD Pro skid, TRD Pro grill, TRD Pro valances, Baja S8 30”, 3x Baja LP4 and Baja fogs, Rays 10, Toyo AT3 185/55, Canvasback, tinted windows, clear mask, UpTop Alpha rack w/ custom fairing, Borla, AFE CAI, URD MAF, Switch Pros, Power Trays, single ARB, rod vault, iKamper X-Cover, 23Zero 270 awning, Baja scene lights, Baja S2 rear fog/camp lights, RSG KDSS skid and sliders, Coco Mats, Ellis shift knobs, C4 ladder, Kenwood DNX696S/iData link, Morimoto XB Gen2, Morimoto Tails, custom 80/20 platform with slider, RokBlokz XL, WeBoost, C4 Low Pro w/ high clearance, Warn VR10 with Factor55, etc
03-01-2020, 11:27 PM
#1999
So far I have no complaints what-so-ever with them. They have performed really well. My only complaint would be, I wish there were more tire options with the 255's.
2016 T4R SR5: Ironman FCP w/ Performance Springs l RAV4 Mirrors l TSO Pro Grill l TSO INCOG Front Bumper l Raptor Lights l 255/80 Falken WildPeak AT3W l CaliRaisedLED Ditch Light Brackets l Avid Sliders l Custom Drawers l R1 Concepts Rotors/Pads
5th Gen Build
1996 T4R Limited: E-Locked l 285 KO2's l Toytec BOSS w Superflex l SS Panhard l Ultra Gauge l AIRAID MIT l Drifter CB Mount l AOF Sliders l Weathertech's l Hilux 167 Snorke l Cobra 19DXIV l Ditch Lights l Relentless Front Bumper l Superwinch Tiger Shark l Paranoid Fab Din Switch
03-02-2020, 10:53 AM
#2000
Just got my 265/70R17's put on last week and so far I like them a lot. Im running 36psi in them and it seems to be a perfect pressure. What are you all running in yours?
2021 4Runner TRD ORP: Bilstein 5100's all 4 corners, 1" Cornfed spacers in the rear, Firestone Air Bags rear, Poly bushings for sway bars, Scangauge 2, Vent Visors, Pro Comp 32 wheels and Wildpeaks 265-70R17 tires.
03-02-2020, 11:36 AM
#2001
What load rating did you get?
2016 Nautical Blue Metallic Trail | SCS | Falken Wildpeak AT3/W | Icon CDCV | Heftyfab Front Bumper | 4x4 Labs Rear | Shrockworks Sliders | RCI Skids | Warn VR10S | OGE Dual Battery System | sPOD | Katzkin
2013 Blizzard Pearl LE 4WD - SOLD!!!
03-03-2020, 06:08 PM
#2002
I think I may have an issue with one of my tires. My front driver side tire is showing a lot more wear than the passenger. They're SL and only have a little less than 2k miles. They're at 35 psi right now, but thinking about bringing it down to 32.
I'm noticing the rubber separating on the tread already.
On the passenger side, it's not as severe and there's still a sharp straight line that you can see.
Any ideas on what might cause this?
03-03-2020, 10:43 PM
#2003
I believe SL
03-03-2020, 10:53 PM
#2004
Not sure of cause? with 2k miles the warranty is 55k - Depending where you bought them should be replaced. Discount will replace them(or should!)
03-03-2020, 11:07 PM
#2005
Real Name: B-Money
Real Name: B-Money
What kind of driving have you been doing? Any off road miles?
I’ve had two sets of these and have never seen this happen before. While I don’t think the tire is dangerous to drive on, I’d definitely have those tires looked at. I’m sure you’ll get new rubber.
Anger Fuels Motion...Motion Fuels Momentum...Momentum Fuels Action...DO SOMETHING!
2010 4Runner SR5
03-03-2020, 11:22 PM
#2006
No off roading. Just highway. It may be an alignment issue. If it's not, then I'll definitely be reaching out to Falken.
03-03-2020, 11:23 PM
#2007
I believe SL
If they're SL then just run them at OEM pressures, 32psi.
03-04-2020, 06:13 PM
#2008
Whats the load rating of each tire?
03-04-2020, 07:45 PM
#2009
SL is the load rating. Standard Load.
03-04-2020, 10:58 PM
#2010
I run about 39 in mine. I think 36 is pretty good sweet spot. I have always run them at 39 so I have gotten use to it.
