07-06-2020, 11:13 PM
#2116
Real Name: Don
Real Name: Don
Originally Posted by Baystate4Runner
Got the same tires delivered today - not installed yet - but mine are Made in USA.
Looks like they moved production to the US.
Oh and build date is 09/20 for one tire and 21/20 for the other three.
I was hoping my last set was made in USA. But no good. All 3 sets I had all had same issue. My tire place installs a lot of the Falkens with no issues at all. I had no luck with them.
07-07-2020, 09:05 AM
#2117
How do you know they are US made or not? are they stamped? I haven't paid much attention.
2014 4R SR5 - 3" Dobinsons, 285/70 Wild Peak AT3, RCI Skid & Sliders, CBI Bumper, Firewire light bar, Diode Dynamics Fogs
07-08-2020, 09:39 AM
#2118
Yes - it says on the tires "Made in USA" or wherever.
2024 Lexus GX550 Overtrail+ - pre ordered
2021 TRD Pro - Lunar Rock
2017 TRD Pro - Super White, RCI Rock Sliders, Falken Wildpeak A/T3W - SOLD
2012 Porsche Cayman S
07-08-2020, 07:06 PM
#2119
Just to the left of "Falken"
07-08-2020, 10:48 PM
#2120
Real Name: Don
Real Name: Don
It’s stamped on the tire made in USA.
07-08-2020, 11:10 PM
#2121
How do these tires ride on the highway vs the OEM tires?
2013 Toyota 4Runner SR5
07-09-2020, 04:58 PM
#2122
Measured clearance w/ 255/80R17s and 5100 lift @ 2.5"
Figured I'd post some crude clearance measurement improvements I got from upgrading to new Wildpeak AT3 LT255/80R17s from worn ~3/16" tread depth Cooper Discoverer AT3s LT265/70R17 and adding Bilstein 5100's @ 2.5" lift.
I measured by simply sticking a tape measure between front skid plate right beside jack point and ground. I measured similarly off the center of the rear diff. I didn't get too techy by checking naunces like tire pressure and whether the gas tank was full, but I'm guessing those naunces are well within the error of my crude way of measuring. I assume tire pressure was around 35-40 psi all around for all measurements.
Front skid plate went from about 8.5" to 12.5" clearance, and the rear diff went from 9.25" to 10.5" clearance. I'd estimate there could be roughly 0.25" error per measurement (0.5" total error in calculating actual lift acheived). Error is simply from eyeballing where the bent tape measure would contact the ground if I wasn't bending it, and from probably not holding it perfectly vertical (as well other nauances like tire pressure and vehicle weight distribution). Also, I'll say that I'd driven the 4R around for about 2 weeks after the shocks were installed, so hopefully they're fully settled by now. Although, given that the 4" difference in front end clearance is more than the difference in tire diameter and Bilstein's advertised 2.5" lift, it's possible they'll settle more. The truck certainly looks level though (w/ 1.5" Daystar spacer in rear). Only other thing to add is that I haven't realigned the front yet, but will that actually change the clearance significantly?
Interesting, I haven't seen a difference in gas mileage driving 65mph on the highway, but that's only after the first drive.
07-24-2020, 11:21 AM
#2123
Real Name: Brad
Real Name: Brad
Just ordered the 275/70/17 C's from Discount. I went back and forth a ton, between P-metric 265's, due to the weight, however I wanted a 275 and I wanted a C load so these fit the bill. Putting the 6112/5160 set up this weekend, tires next Wednesday. Will post pics and my initial thoughts sometime next week.
07-25-2020, 01:11 PM
#2124
I love my 275s so far. So happy that I didn't need to do a BMC either.
15 SR5 4WD
07-26-2020, 11:39 AM
#2125
New A/T 3W LT275/70/17 c-rated tires
These definitely run large, as I have a Toytec boss lift and I get very minor rubbing on the mud flaps at a full turn backing out of the driveway. They look great and I’m super happy with them. They are heavy, 14lbs heavier than the Geolandars my Runner came with. Obviously this is to be expected, as the Geolandars were p-rated 265’s. So far so good. I’ve only had them a couple of weeks now.
07-26-2020, 04:05 PM
#2126
Curious to know if 275s will fit on a non-lifted ORP. I don't mind getting the 265s but would prefer 275s. Not planning to lift mine any time soon, if ever.
07-26-2020, 05:42 PM
#2127
Sorry bud, i wouldn't know. I had the Eibach kit installed before I slapped on the wheels/tires.
I'm sure some adjustments will need to be made to avoid rubbing.
With my setup, I had to push the front fender forward a bit, trim bits of plastic and remove the front mudflaps.
15 SR5 4WD
07-26-2020, 07:01 PM
#2128
Real Name: Aaron
Real Name: Aaron
I expect some adjustments will need to be made.
I just put 275/70/r17 Falkens on my T4R, and I need to trim my front bumper a bit. I have TRD Pro wheels and Bilstein 5100s all around, and still have some rubbing.
2017 SR5 4x4 Premium (Nautical Blue)
Old 97 T4R Journal
07-26-2020, 09:02 PM
#2129
Looks plain jane
07-30-2020, 09:57 AM
#2130
Real Name: Brad
Real Name: Brad
Got the 275's installed yesterday, suspension went on over the weekend. No rubbing, no balancing issues (yet)
Love the way the 275's look, if I run in to any issues with them I will be sure to post em.
Edit: Tires manufactured in Thailand
Black 2020 ORP: Bilstein 6112/5160, Dobinson 1.5" rear coils, SPC UCA's, Wildpeak 275/70/17's, RSG Sliders, Sherpa Crestone roof rack (on the way)
