Thread Tools Rating: Thread Rating: 18 votes, 2.83 average. Display Modes
Old 07-06-2020, 11:13 PM #2116
RusPro17 RusPro17 is offline
Real Name: Don
RusPro17 has a spectacular aura about RusPro17 has a spectacular aura about RusPro17 has a spectacular aura about
Real Name: Don
Originally Posted by Baystate4Runner View Post
Got the same tires delivered today - not installed yet - but mine are Made in USA.
Looks like they moved production to the US.
Oh and build date is 09/20 for one tire and 21/20 for the other three.
I was hoping my last set was made in USA. But no good. All 3 sets I had all had same issue. My tire place installs a lot of the Falkens with no issues at all. I had no luck with them.
RusPro17 is offline   Reply With QuoteReply With Quote
Old 07-07-2020, 09:05 AM #2117
Ogre75 Ogre75 is offline
Ogre75 has a spectacular aura about Ogre75 has a spectacular aura about Ogre75 has a spectacular aura about
How do you know they are US made or not? are they stamped? I haven't paid much attention.
2014 4R SR5 - 3" Dobinsons, 285/70 Wild Peak AT3, RCI Skid & Sliders, CBI Bumper, Firewire light bar, Diode Dynamics Fogs
Ogre75 is offline   Reply With QuoteReply With Quote
Old 07-08-2020, 09:39 AM #2118
Baystate4Runner's Avatar
Baystate4Runner Baystate4Runner is offline
Baystate4Runner will become famous soon enough Baystate4Runner will become famous soon enough
Yes - it says on the tires "Made in USA" or wherever.
2024 Lexus GX550 Overtrail+ - pre ordered
2021 TRD Pro - Lunar Rock
2017 TRD Pro - Super White, RCI Rock Sliders, Falken Wildpeak A/T3W - SOLD
2012 Porsche Cayman S
Baystate4Runner is offline   Reply With QuoteReply With Quote
Old 07-08-2020, 07:06 PM #2119
ForRun's Avatar
ForRun ForRun is offline
ForRun is a name known to all ForRun is a name known to all ForRun is a name known to all ForRun is a name known to all ForRun is a name known to all ForRun is a name known to all
ForRun's Avatar
Just to the left of "Falken"
New Falken AT tire (A/T3W)-20200708_180319-jpg
ForRun is offline   Reply With QuoteReply With Quote
Old 07-08-2020, 10:48 PM #2120
Real Name: Don
Real Name: Don
It’s stamped on the tire made in USA.
Old 07-08-2020, 11:10 PM #2121
4Runner&Airstream 4Runner&Airstream is offline
4Runner&Airstream is on a distinguished road
How do these tires ride on the highway vs the OEM tires?
2013 Toyota 4Runner SR5
4Runner&Airstream is offline   Reply With QuoteReply With Quote
Old 07-09-2020, 04:58 PM #2122
Aerodan Aerodan is offline
Aerodan is on a distinguished road
Measured clearance w/ 255/80R17s and 5100 lift @ 2.5"
Figured I'd post some crude clearance measurement improvements I got from upgrading to new Wildpeak AT3 LT255/80R17s from worn ~3/16" tread depth Cooper Discoverer AT3s LT265/70R17 and adding Bilstein 5100's @ 2.5" lift.
I measured by simply sticking a tape measure between front skid plate right beside jack point and ground. I measured similarly off the center of the rear diff. I didn't get too techy by checking naunces like tire pressure and whether the gas tank was full, but I'm guessing those naunces are well within the error of my crude way of measuring. I assume tire pressure was around 35-40 psi all around for all measurements.
Front skid plate went from about 8.5" to 12.5" clearance, and the rear diff went from 9.25" to 10.5" clearance. I'd estimate there could be roughly 0.25" error per measurement (0.5" total error in calculating actual lift acheived). Error is simply from eyeballing where the bent tape measure would contact the ground if I wasn't bending it, and from probably not holding it perfectly vertical (as well other nauances like tire pressure and vehicle weight distribution). Also, I'll say that I'd driven the 4R around for about 2 weeks after the shocks were installed, so hopefully they're fully settled by now. Although, given that the 4" difference in front end clearance is more than the difference in tire diameter and Bilstein's advertised 2.5" lift, it's possible they'll settle more. The truck certainly looks level though (w/ 1.5" Daystar spacer in rear). Only other thing to add is that I haven't realigned the front yet, but will that actually change the clearance significantly?
Interesting, I haven't seen a difference in gas mileage driving 65mph on the highway, but that's only after the first drive.
Aerodan is offline   Reply With QuoteReply With Quote
Old 07-24-2020, 11:21 AM #2123
bakerb87 bakerb87 is offline
Real Name: Brad
bakerb87 is on a distinguished road
Real Name: Brad
Just ordered the 275/70/17 C's from Discount. I went back and forth a ton, between P-metric 265's, due to the weight, however I wanted a 275 and I wanted a C load so these fit the bill. Putting the 6112/5160 set up this weekend, tires next Wednesday. Will post pics and my initial thoughts sometime next week.
bakerb87 is offline   Reply With QuoteReply With Quote
Old 07-25-2020, 01:11 PM #2124
SICKwidIT SICKwidIT is offline
SICKwidIT is on a distinguished road
I love my 275s so far. So happy that I didn't need to do a BMC either.
15 SR5 4WD
SICKwidIT is offline   Reply With QuoteReply With Quote
Old 07-26-2020, 11:39 AM #2125
43N3R's Avatar
43N3R 43N3R is offline
43N3R is on a distinguished road
43N3R's Avatar
New A/T 3W LT275/70/17 c-rated tires
These definitely run large, as I have a Toytec boss lift and I get very minor rubbing on the mud flaps at a full turn backing out of the driveway. They look great and I’m super happy with them. They are heavy, 14lbs heavier than the Geolandars my Runner came with. Obviously this is to be expected, as the Geolandars were p-rated 265’s. So far so good. I’ve only had them a couple of weeks now.
New Falken AT tire (A/T3W)-19c60384-1d56-40ef-ba5f-d04ed068ec05-jpg
43N3R is offline   Reply With QuoteReply With Quote
Old 07-26-2020, 04:05 PM #2126
Vecsus Vecsus is offline
Vecsus is on a distinguished road
Curious to know if 275s will fit on a non-lifted ORP. I don't mind getting the 265s but would prefer 275s. Not planning to lift mine any time soon, if ever.
Vecsus is offline   Reply With QuoteReply With Quote
Old 07-26-2020, 05:42 PM #2127
Sorry bud, i wouldn't know. I had the Eibach kit installed before I slapped on the wheels/tires.
I'm sure some adjustments will need to be made to avoid rubbing.
With my setup, I had to push the front fender forward a bit, trim bits of plastic and remove the front mudflaps.
15 SR5 4WD
Old 07-26-2020, 07:01 PM #2128
Old 97's Avatar
Old 97 Old 97 is offline
Real Name: Aaron
Old 97 is on a distinguished road
Old 97's Avatar
Real Name: Aaron
I expect some adjustments will need to be made.
I just put 275/70/r17 Falkens on my T4R, and I need to trim my front bumper a bit. I have TRD Pro wheels and Bilstein 5100s all around, and still have some rubbing.
2017 SR5 4x4 Premium (Nautical Blue)
Old 97 T4R Journal
Old 97 is offline   Reply With QuoteReply With Quote
Old 07-26-2020, 09:02 PM #2129
USaleem USaleem is offline
USaleem is on a distinguished road
Looks plain jane
USaleem is offline   Reply With QuoteReply With Quote
Old 07-30-2020, 09:57 AM #2130
Real Name: Brad
Real Name: Brad
Got the 275's installed yesterday, suspension went on over the weekend. No rubbing, no balancing issues (yet)
Love the way the 275's look, if I run in to any issues with them I will be sure to post em.
Edit: Tires manufactured in Thailand
Complete-front
Complete-Side
Black 2020 ORP: Bilstein 6112/5160, Dobinson 1.5" rear coils, SPC UCA's, Wildpeak 275/70/17's, RSG Sliders, Sherpa Crestone roof rack (on the way)
4Runner in Falken ad in Outside Magazine Paisano 5th gen T4Rs 8 08-19-2015 05:15 PM
Goodyear vs Falken Jbot 3rd gen T4Rs 29 07-16-2014 07:00 PM
Falken Wildpeak A/T Thoughts? jswinkT4R Classic T4Rs 14 02-16-2014 05:47 PM
Falken Wild Peak A/T Paulie6909 4th Gen T4Rs 11 10-30-2011 12:49 PM
Falken Tires...your thoughts... njharrell Engines / Suspension / Wheels / Tires / Audio / Accessories 2 10-25-2009 03:36 AM
