Thread Tools Rating: Thread Rating: 18 votes, 2.83 average. Display Modes
Old 08-02-2021, 09:41 PM #2341
Argyle Edison Argyle Edison is offline
Argyle Edison will become famous soon enough
Find a place that does roadforce balancing properly. It will change everything.
Argyle Edison is offline   Reply With QuoteReply With Quote
Old 08-05-2021, 12:40 PM #2342
slider76 slider76 is offline
slider76 is on a distinguished road
"Been lurking around for some time and doing as much reading as I can, didn't quite read all 150+ pages, did read a nice chunk of it though. I picked up a 2019 4runner SR5 Premium mostly for fishing and camping. which turned into overlanding/offroading. After a ton of reading I decided to go with:
Dobinsons IMS Suspension Kit Toyota 4Runner 2010-21
* C59-300 - 1.75 - 2" lift in the front, haven't decided where i'll land yet
* C59-325 - 2" lift in the rear
JBA UCA's in standard for it's reliability and ease of replacement parts should i need them in a hurry.
I'm more of a weekend warrior than anything, the 4runner is my DD so I'm trying to balance ride quality, MPG, acceleration etc with capability. I live in Colorado, run trails once a month and fishing the rest of the time, so generally dirt roads and level 1 or 2's will get me to most fishing spots but i'm not shy about pushing the 4runner harder if it means better fishing / views (photography). What draws me to the AT3W's is it's such a great all around tire sans balancing issues. The most difficult trails I've ran so far are Tin Cup Pass (in 2019) and Imogene last year. I don't envision myself running any trails more difficult than either of those and i'm more a fair weather off-roader.
After reading this thread i'm still on the fence on the Falken AT3W WildPeaks due to balancing issues. My initial plan was to go with 275/70R17 but am considering the 285's which is why I picked up the UCA's, even if I don't go with 285 they'll still be of help. I'm planning on regearing to 4.56 in the future, not sure when (likely in the next couple of years).
To the best of my knowledge, if i go with 275's i can stay on the stock SR5 wheels, if i go up to 285, i believe I'll need spacers (1.25") or a new set of wheels with a -10mm offset?
I'm torn between the SL and C rated tires. I like the idea of a SL rated tire for MPG and comfort, just a bit worried about longevity. I believe mast4r said the C wouldn't provide more protection than an SL, it will however likely wear down faster than a C rated tire? Given my usage though, maybe it won't matter too much?
Considering the weight of the tires, if I do go for a C tire it'll be in 275's or SL if I go to a 285 i think. The last option i suppose is, i could always wait a bit longer, try to find a lighter wheel to help offset the weight of the tires a bit.
I'd be open to other options provided they perform as well as the AT3W's do. Deceiver mentioned the MT01's, after looking at the weight though i'm worried about breaking power on the heavier tires.
Thanks!"
Hi,
I'm in a very similar position as you. I just went to 275/70/17 C loads yesterday after I saw a puncture on the stock H/T yesterday (it couldn't be repaired because it was too close to the sidewall: this is also the second puncture I've had in about the 30k miles the vehicle has been driven since it came off the lot in early 2018). I'm running an Ironman 4x4 Foam Cell Pro Stage 3 suspension (went on in January) with about 2.5" and 2" of lift in the front and back, respectively (this includes UCAs that come with the kit). I don't know if I can feel the difference in unsprung weight quite just yet, but it does seem to ride nicer/smoother in the little bit of street driving I've done so far. My initial thought was to get FN wheels, but I'm going to keep them on the stock SR5 wheels for now. I'm trying to keep the rig as close to stock as possible while upgrading functionality (ditch lights, LFD crossbars instead of a roof rack, other lighting upgrades, etc.): the thought of having to modify the vehicle just so I can run rims I like seems a little backwards to me, especially if the stock rims will take the tires I wanted. Also, with the vast majority of my offroading being on forest roads and tracks out here in SoCal, I don't need tires/suspension that are more extreme.
2018 SR5 Premium, LFD steel crossbars on OEM side rails, Shrockworks sliders, Ironman 4x4 Foam Cell Pro Stage 3, Morimoto XB headlights, Baja Designs Squadron Pros (driving/combo) on Rago ditch light mounts
slider76 is offline   Reply With QuoteReply With Quote
Old 08-09-2021, 06:05 PM #2343
Bluepatrol Bluepatrol is offline
Bluepatrol is on a distinguished road
Just got my new tires on in stock size, so far it's only been 20 miles, but noticeable difference in ride quality and noise, look a lot more aggressive than the stock tires too. Here are some before any after pics:
New Falken AT tire (A/T3W)
Bluepatrol is offline   Reply With QuoteReply With Quote
Old 08-09-2021, 08:42 PM #2344
bglfgd bglfgd is offline
bglfgd is on a distinguished road
50+K on my stock size SL falkens and up until recently I was set on getting another set in another 5-10K miles. They've been excellent in the rain and snow, and haven't had too much trouble getting them balanced at DT (I do recall at least 2 trips back after rotation to get them rebalanced). However, they have gotten stupid loud over the last 10K or so miles. It's bad enough for me to be taking a hard look at the Toyo AT3s and other options, especially considering the falkens aren't as cheap as they were initially...
Sent from my SM-G973U using Tapatalk
bglfgd is offline   Reply With QuoteReply With Quote
Old 09-22-2021, 05:20 PM #2345
RedRunner_87's Avatar
RedRunner_87 RedRunner_87 is offline
RedRunner_87 is a glorious beacon of light RedRunner_87 is a glorious beacon of light RedRunner_87 is a glorious beacon of light RedRunner_87 is a glorious beacon of light RedRunner_87 is a glorious beacon of light
Wear update:
32,000 miles and my tires are 2 @ 10/32 and 1 @ 9/32. My other one is still newish
Tire size: 255/80R17
2016 T4R SR5: Ironman FCP w/ Performance Springs l RAV4 Mirrors l TSO Pro Grill l TSO INCOG Front Bumper l Raptor Lights l 255/80 Falken WildPeak AT3W l CaliRaisedLED Ditch Light Brackets l Avid Sliders l Custom Drawers l R1 Concepts Rotors/Pads
5th Gen Build
1996 T4R Limited: E-Locked l 285 KO2's l Toytec BOSS w Superflex l SS Panhard l Ultra Gauge l AIRAID MIT l Drifter CB Mount l AOF Sliders l Weathertech's l Hilux 167 Snorke l Cobra 19DXIV l Ditch Lights l Relentless Front Bumper l Superwinch Tiger Shark l Paranoid Fab Din Switch
RedRunner_87 is offline   Reply With QuoteReply With Quote
Old 09-22-2021, 06:36 PM #2346
91foxbody 91foxbody is offline
91foxbody will become famous soon enough 91foxbody will become famous soon enough
Originally Posted by RedRunner_87 View Post
Wear update:
How do you like them in that size? I think that will be my next tire.
91foxbody is offline   Reply With QuoteReply With Quote
Old 09-22-2021, 06:39 PM #2347
Absolutely love the skinnies. I can still pull 20mpg+ on the highway. I have had no issues with them off-road and they perform really well. I am debating bumping up to 35x10.50's since the skinnies have performed so well.
5th Gen Build
Old 10-08-2021, 10:24 AM #2348
YoRunner2017's Avatar
YoRunner2017 YoRunner2017 is offline
YoRunner2017 is on a distinguished road
Originally Posted by Lightenup_bro View Post
Well I made the switch from the At3w to Falken Wildpeak MT01s. The change had little to do with the performance of the AT since it handled everything I through at it, I just wanted a MT and larger tire. Though the improved performance in mud will be nice, that's the one downfall for the AT.
So you got the 295s with a 2.5inch lift on 17" wheels? What did you have to chop off to fit those there? I am about to get the 285s since I have a Eibach Pro lift which is 2.75 front/1 rear but if the 295s fit I might just get those.
YoRunner2017 is offline   Reply With QuoteReply With Quote
Old 10-29-2021, 02:49 PM #2349
Lightenup_bro's Avatar
Lightenup_bro Lightenup_bro is offline
Real Name: Austin
Lightenup_bro is on a distinguished road
Real Name: Austin
I had to chop alot...but to be honest I can't remember specifically how much was chopped for that one change. I had chopped alot already, BMC for sure. I switched the bumper out the next year too so that took care of the last bit of rubbing.
'16 TE (KDSS Delete) / other goodies
Lightenup_bro is offline   Reply With QuoteReply With Quote
Old 11-12-2021, 09:45 AM #2350
DallasTRDPro's Avatar
DallasTRDPro DallasTRDPro is offline
DallasTRDPro is a glorious beacon of light DallasTRDPro is a glorious beacon of light DallasTRDPro is a glorious beacon of light DallasTRDPro is a glorious beacon of light DallasTRDPro is a glorious beacon of light DallasTRDPro is a glorious beacon of light
I think I have decided on 275/70/17. I'm only going to level the front with a 1" Cornfed spacer. I already removed my front mudflap so it should fit fine. I just don't feel like trimming anything at the moment. I have less than 400 miles on my Nitttos. I wanted to sell them and at 400 miles they will sell better than if I wait a few months. The AT3's have performed very well for me on my Pro and my Outback. I like having a C load for the possible slightly better sidewall strength. Plus they just look more aggressive. After going through the entire thread it seems like the 275's are basically plug n play.
DallasTRDPro is offline   Reply With QuoteReply With Quote
Old 11-12-2021, 11:14 AM #2351
Pedro367 Pedro367 is offline
Pedro367 is a name known to all Pedro367 is a name known to all Pedro367 is a name known to all Pedro367 is a name known to all Pedro367 is a name known to all Pedro367 is a name known to all
Is the extra 3/4" of tire worth an extra 10lbs per corner just to have a C on a basically stock 4Runner? 57lbs of tire vs 46ish.
Pete - 2018 Silver TRDORP w/ KDSS. 2" Fox 2.0s and 285/70r17 Maxxis Razr ATs
Pedro367 is offline   Reply With QuoteReply With Quote
Old 11-12-2021, 12:06 PM #2352
Metalsaber Metalsaber is offline
Metalsaber is on a distinguished road
I got mine a few weeks ago. So far so good.
New Falken AT tire (A/T3W)-img_0987-002-jpg
Metalsaber is offline   Reply With QuoteReply With Quote
Old 11-12-2021, 01:07 PM #2353
Looks like AT3's only have an E load in 265 and I definitely don't want E load. The AT3's are so much better than the Nitto's so yes its worth the extra penalty in weight I think for capability and looks.
Old 11-12-2021, 02:15 PM #2354
They make them in a SL 4ply too which is what I was comparing too.
Old 11-12-2021, 03:24 PM #2355
yeah i got my stock sized AT3Ws in SL.
4Runner in Falken ad in Outside Magazine Paisano 5th gen T4Rs 8 08-19-2015 05:15 PM
Goodyear vs Falken Jbot 3rd gen T4Rs 29 07-16-2014 07:00 PM
Falken Wildpeak A/T Thoughts? jswinkT4R Classic T4Rs 14 02-16-2014 05:47 PM
Falken Wild Peak A/T Paulie6909 4th Gen T4Rs 11 10-30-2011 12:49 PM
Falken Tires...your thoughts... njharrell Engines / Suspension / Wheels / Tires / Audio / Accessories 2 10-25-2009 03:36 AM
