Thread Tools Rating: Thread Rating: 17 votes, 2.41 average. Display Modes
Old 09-02-2020, 11:18 PM #1336
TRD PANTHER's Avatar
TRD PANTHER TRD PANTHER is offline
Real Name: BLACK TRD PRO
TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of
Originally Posted by Theomoji View Post
I'm thinking something like this?
Amazon.com: AUTOMUTO 1.5" Front Leveling lift kit Replacement compatible with Supreme Suspensions Toyota Tacoma Leveling Kit Aircraft Billet: Automotive
So I guess TRD PROs are leveled. So how do you guys drive when it's packed with people and gear? Does the nose go up?
"Underneath, the Pro Series 4Runner packs TRD-tuned Eibach springs and Bilstein shocks that equate to a softer-than-stock ride and grant an invaluable 1-inch lift in ride height, leveling the front and rear ends. ... Suspension aside, the rest of the Pro Series 4Runner plays up to par."
That link is for a Tacoma. As far as the leveling, I still have a very slight rake. I have never put much of a load in the back besides my son and a couple other people and groceries. If you plan on towing or installing heavy bumpers, etc. I would consider aftermarket springs.
TRD PANTHER is offline   Reply With QuoteReply With Quote
Old 10-19-2020, 12:53 AM #1337
Ltancredi Ltancredi is offline
Ltancredi is on a distinguished road
I just got a Toyota 4Runner trd 2016 preowned and the tires rub on the front bumper do you think its better to shave it down or put a small lift on it ?
Ltancredi is offline   Reply With QuoteReply With Quote
Old 10-19-2020, 01:11 AM #1338
no offloading in Hawaii 😒 BUT my tires rub so to lift or not to lift....
my tires rub when I make sharp turns or try to reverse sometimes and although there's a lot of people who lift their runners here there's really not too many places to go off roading so my question is should I shave some of the fender/ front bumper so the rubbing stops or is it worth it to do a small lift and will a lift even help? I want to lift I just don't know if its worth it???? any advice??
Old 10-19-2020, 01:41 AM #1339
It sounds like you have a SR5, OR or ORP. The Pro has the fender trim mod done and is 1” higher than the other 4Runners. Also the Pro wheels being 7” with the offset clear better than the other 4Runners.
Old 10-21-2020, 01:00 PM #1340
RedEarth RedEarth is offline
RedEarth is on a distinguished road
Originally Posted by bigair96 View Post
For the TRD Pro suspension, whats the tallest lift spring you can use in the rear?
I ask because I have the Toytec 2 inch lift with the superflex 2inch springs. With my base setup (full roof rack, sliders, skids, toolbox in back), it sits perfectly level. However, any additional weight and I get a negative rake.
I would be OK with a little rake with my normal set up if it keeps it more level when loaded up (gear, hitch rack or wilco tire carrier).
Thinking Toytec HD 2.5 inch springs or Icon overland 3 inch springs (or open to other suggestions). Will these work with the Pro bilsteins?
Thanks
+1 trying to figure this out as well.
Have a 2017 TRD Pro w/ Toytec FJ4RPRO lift and 285s
Have a negative rake when im fully loaded up w/ gear, cooler, tire carrier, roof rack, roofnest falcon, and no passengers
I contacted Toytec before to see if they have a heavier spring for the rear but they mentioned not to go that route cause the rear shocks wont be able to work with it
RedEarth is offline   Reply With QuoteReply With Quote
Old 10-21-2020, 05:31 PM #1341
2016 4Runner SR5's Avatar
2016 4Runner SR5 2016 4Runner SR5 is offline
Real Name: Chris
2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold
Real Name: Chris
With the OEM shocks I would not go over 2"
2016 4Runner SR5 is offline   Reply With QuoteReply With Quote
Old 10-21-2020, 09:02 PM #1342
bigair96 bigair96 is offline
bigair96 will become famous soon enough
I have a lot of weight in the back and ended up doing the HD springs and its been perfect. Without the weight it would be too much but with my setup it's great. I may get heavier in the rear and am going to chat with my shop about the xd springs vs finally replacing the shocks.
2018 sr5P XP Predator. Needed that 3rd row. TRD Pro susp, Toytec trd pro 2inch lift (HD springs), Gobi stealth, Falken at3w 285s, Trd and rci alum skids, Arb breather, Upper grill light source lightbar, slee sliders, wilco high clearance, arb awning, pedal commander, treaty offroad recovery points, alpha rex pro headlights, trd intake/exhaust, goal zero solar setup, greenlane offroad bumper, warn winch. C4 rear bumper coming...
bigair96 is offline   Reply With QuoteReply With Quote
Old 10-22-2020, 05:23 AM #1343
Kamalani Mahie's Avatar
Kamalani Mahie Kamalani Mahie is offline
Kamalani Mahie is a jewel in the rough Kamalani Mahie is a jewel in the rough Kamalani Mahie is a jewel in the rough
Trd pro lift question
I’ve got OME 895’s in the rear with Airlift 1000 airbags. Love it! The 895’s are much better than stock and give me around 2” of lift, and airbags help a ton when I go super heavy and I can quickly pump them up or let some air out.
Originally Posted by RysiuM View Post
I just look at them and say: you have not the absolute slightest idea what you are talking about. This is 4Runner.
'15 Trail Premium, GOBI Stealth, CVT Summit Awning, ARB Safari Snorkel, TRD Pro susp. w/Bilstein 6112 coils & 1" spacer (front) & OME 895 (rear), 285/70/17 BFG KO2, Spidertrax wheel spacers, TRD Pro package (wheels, grill, valences, & skid), full RCI aluminum skids, C4 Fab diff skid, Toytec bump stop extensions, plenty of lights, patches, stickers, and other miscellaneous mods (backup & front camera, accessory meter display, rear window/hatch, bumper cup holders, Wit's End fire extinguisher mount, Ellis Precision TRD shift lever)
Kamalani Mahie is offline   Reply With QuoteReply With Quote
Old 10-27-2020, 08:49 PM #1344
Nice! Toytec just got back to me and mentioned i should probably get the XDs as well but may need to replace the shocks and get longer brake lines.
Have you had any issues with using XDs on your TRD Pro rear shocks?
Old 10-28-2020, 01:04 AM #1345
perf0rmance perf0rmance is offline
perf0rmance will become famous soon enough
For anyone that wants to lift their truck using a proper spring setup, here's what I used on my Pro for the fronts:
PTR13-35140-AA
Its an OEM TRD spring which is also in TRD red. It's a 14" springs and gives your PRO an additional 1.5" of lift. Personally, I'd stay away from spacers. It's a quick solution, but please do some research regarding reliability and the ramifications for adding either extra preload on your springs or using spacers above your front coilover.
For the rears, get some springs.
T13 have a mild lift
T12 are even taller
I ended up with Icon 2" rear springs
perf0rmance is offline   Reply With QuoteReply With Quote
Old 10-28-2020, 09:29 AM #1346
NW.OH.T4R NW.OH.T4R is offline
Real Name: Jason
NW.OH.T4R is a jewel in the rough NW.OH.T4R is a jewel in the rough NW.OH.T4R is a jewel in the rough NW.OH.T4R is a jewel in the rough
Real Name: Jason
PTR13-35140-AA
T12 are even taller
Is the OEM TRD a 600# spring? I was looking at Icon 13.5" 650# or King 14" 600# for the front. I haven't found Eibach's spring rate for their new springs for the PRO either, but sounds like they are higher rate than stock.
NW.OH.T4R is offline   Reply With QuoteReply With Quote
Old 10-28-2020, 01:22 PM #1347
I don't recall the spring rate but I'm pretty sure it's closer to stock values.
If you don't care for the colors, then look for a 14" spring like the ones that come on the bilstein kit. Icon and king both make 14" springs too (which is a common size) and they have a selection of rates from 550-700 in 50lb increments
Old 10-28-2020, 01:33 PM #1348
Real Name: Jason
Real Name: Jason
Leaning towards the 14" 600# Kings. The blue doesn't matter to me. I'd like to keep the on-road manners as close to the factory Fox TRD setup as possible.
Old 10-28-2020, 05:31 PM #1349
I should note, I have a 2017 Pro so I had the "bilstein" TRD shocks/springs
Old 10-28-2020, 05:44 PM #1350
Real Name: Jason
Real Name: Jason
Ahh, thanks.
Air Lift 1000 and Lift Question - Spring Seats G8RB8_12SR5 5th gen T4Rs 4 08-24-2014 11:15 PM
To lift or not to lift. That is the question. beaver_scott Classic T4Rs 8 08-22-2014 03:50 AM
Coil lift question question coachnov 3rd gen T4Rs 2 01-21-2011 12:09 AM
quick question, do i need body lift for arb and ome sus. lift? theizzardking 3rd gen T4Rs 7 10-16-2010 12:54 AM
Wheels Question and Lift Question. K6UK Engines / Suspension / Wheels / Tires / Audio / Accessories 22 02-12-2007 11:45 AM
