01-13-2017, 06:15 PM
Wet Seat Belt
I normally in the garage but last night left the runner outside in the cold, which turned out to be cold and very wet. We had a rain storm that lasted almost all night.
The Drivers side seat belt was soaked when I went to put it on. Passengers side was fine, Carpet dry, etc. etc. Checked some threads and first thing that came to mind was my Prinsu Rack and that all the bolts are in place...They are and seemed to be tight.
Is there anything else that I could have done, before I have Toyota look at it and them tell me it's my fault? I just don't want to be that guy that shows up claiming something is wrong with the sunroof, windshield or something else when it was me that caused the issue.
Anyone else have something like this??
Mike
2016 TEP (W/KDSS)...TRD Wheels, black out kit, TRD Grille, Tinted front windows, Bilstien 5100's set at 1.75" in the front, LED Footwells, Husky Liners, Salex Console Organizer, iPad Mini mount over stock nav, All over speaker upgrade with Kicker's and Sundown 8" Sub in custom box
01-13-2017, 06:23 PM
Is there any chance the seat belt was hanging outside the door when you got out?
2013 SR5 Mag Gray, Pre-leveled, Non-nosedive edition
Plastic license plate frame
01-13-2017, 06:27 PM
Was the headliner wet at all?
01-13-2017, 06:47 PM
he3adliner was dry and the seat belt was in the car. I pulled it out all the way and the more extended, the wetter it was...
I know...That's what she said.
01-13-2017, 08:45 PM
I have the same issue but on the passenger side. Come to the conclusion its from my K9 rack and been too lazy to take it all apart to put on globs of sealant.
16' Trail: TRD Pro front| Safari Snorkel l SSO Rear Bumper|RCI Aluminum Skids|MetalTech OPOR Sliders|SCS Ray 10s|Cooper Discover ST Maxx 255/80/17|5100's front(.85) Long Travel Kings Rear|OME884 Icon Overland Rear|CaliFab Rear linkages|Ezi-Awn k9 1.6m rack|ARB awning|CVT MT. Shasta ext|Baja Design Squadron Pros and S2's|Rigid LED flasher module|Gobi Ladder|Spidertrax|Ram mount tablet and Garmin GPS
03-10-2017, 07:16 PM
So I just had this exact problem happen to me. Did you just remove the bolts and put sealant around them and reinstall them?
2013 SR5 | VTX Wheels | 3" stubby antenna | 20% tint | 2014 taillights | K9 roof rack | Budbuilt bump out sliders | CVT Rainier RTT and Awning | Interior LEDs | Custom ECG Grill | Icon Stage 2 lift with 275/70/17s BFG | ARB twin compressor | Shrockworks front bumper | GGlighting 20" light bar | Coming soon....Rigid Ignite lights | Rigid underbody lights | Rigid back up kit | ARB 50q fridge | Odyssey Group 31 battery | Switch pro 8100
03-10-2017, 07:20 PM
I suspect it is the rack mount not having enough sealant or improperly done, the driver/pass belts are directly below, AFAIK the factory rack is a port installed item, done by a human, that may hate their job or first day... enough of me speculating
2013 TE w/ KDSS Nav
=-> Get yer Custom "Trail" Edition Emblem/Badge 3d Print here! or maybe you just want to go "Pro"
09-03-2018, 01:53 PM
Real Name: Daren Welsh
I think I have joined the club, unfortunately. After having the k9 roof rack for about a year, I'm seeing the first signs of a leak. Water is leaking out of the passenger seat belt reel. When I installed the rack, I put a bunch of silicone with the spacers. The vehicle has been through some serious rain storms, so it's strange that it's just now showing the leak. I find it hard to believe I missed it for a year. Maybe our recent trip with all the washboard trails rattled something loose up there ... It's also frustrating that installing a rack that requires no drilling could still lead to leaks. That was one of the reasons I swayed from other brands.
My question is whether I need to completely remove the rack to re-seal those bolts or if I can just apply a bunch of silicone once the rain stops and it dries out. Any thoughts?
09-03-2018, 02:58 PM
Real Name: Luke
Real Name: Luke
I've got to wonder if the best way to fix this properly is to drop the headliner and liberally apply silicone from beneath. That way you ensure it gets everywhere around the anchor instead of just trying to get it best you can from the top.
09-03-2018, 02:59 PM
I'd take it off completely and reseal. Saves the bother of you missing the leak and having to do it all over again. Plus sealant doesn't last forever. Almost all brands shrink, dry out and crack.
09-03-2018, 07:32 PM
Real Name: Jonathan
Real Name: Jonathan
Dropping the headliner involves basically striping the interior. It’s pretty much the first thing installed and everything else overlaps as you go down. I think everyone else has been able to seal under the racks without doing this.
2010 TE KDSS|275/70R17 Goodyear MT/Rs|Front Bilstein 5100s @ 2.5", rear Bilstein 5100s & 2" Icon lift springs|RR sliders|RCI skid plates|BudBuilt diff skid|Sonoran Steel HD rear lower links|RCI rear lower link bracket skid plates
09-03-2018, 07:50 PM
Well to add to the dismay, since my last post I have heard of a couple instances (ie two people) having the sunroof drain lines leak, one was detached, not sure about the other.
Pulling the trim is involved but it isn't terrible with a set of decent trim tools, an e-driver and yeah time. (you shouldn't have to pull the seats) Just plan it. If you have any wiring you want to run, radio antenna, lights, just a hot lead, two birds one stone.
2013 TE w/ KDSS Nav
09-04-2018, 02:27 PM
Took the stock roof rack off, 4Runner out in the rain, driver's side seat belt wet. The hole goes directly thru the roof and apparently right over the seat belt roll. Also the height of the lip around the whole is less than the 'top of the canyon' so if water gets in there its going to find a way thru if it can.
I fixed it with MIL-SPEC RTV from work that was going to be thrown out because of expiration date. Put it on the threads instead of Loctite. You also have to scrape some factory stuff off. Somebody made an article with a title of something like Roof Rack Delete.
Then my son said it was a lot easier finding the 4Runner when he comes out of school with the rack on it, so I put it back on. When I went to put the original bolts back in, whatever they used for thread sealant was NOT like Loctite, kinda shit to be honest. I assumed I had to clean that crap off, I used a set of wire strippers on the 10 gauge slot and gently went around.
05-11-2022, 08:11 AM
Anyone here not remove the aftermarket roof rack to apply a sealant? I have a Prinsu full length rack on my 5th Gen, put it on about two months ago, and I’ve been noticing after any heavy rain my front seat belts are cold/wet. They we soaked after the rain we got this past week. My last resort is to put the whole rack off. I’m hoping to at most maybe loosen all the bolts and add some sort of seal to it.
Was there any sealant that really worked for anyone?
Also, anyone find any issues with the back leaking? I haven’t noticed any, YET. I just don’t know exactly where to look at if the back holes were getting water in them, whereas the front obviously has the drain in the seat belt area.
05-11-2022, 11:59 AM
See thread below for sealant recommendations;
Sealant for Aftermarket Roof Rack?
Sorry to hear people are having leak issues with their racks. But appreciate knowing to check the front seat belts after a heavy rain to ensure the sealant is working or not.
