Old 11-09-2015, 02:34 PM #1
Dalko43 Dalko43 is offline
Dalko43 is on a distinguished road
Scanner apps/tools for iPhones and Apple OS
So it seems that there are some very cost-efficient products you can get to read codes and check engine lights for the 5th gen 4runner, but as far as I know, they only work with Android-based apps. There was a thread on this topic, but I never saw anything for iPhones discussed:
Scan tool on the Cheap
Does anyone have any suggestions for scanner tools and/or apps that are compatible with iPhones?
Dalko43 is offline   Reply With QuoteReply With Quote
Old 11-09-2015, 02:41 PM #2
05Rrunner 05Rrunner is offline
05Rrunner is an unknown quantity at this point
Great subject , I'm intrested as well
05Rrunner is offline   Reply With QuoteReply With Quote
Old 11-09-2015, 02:56 PM #3
elg206 elg206 is offline
elg206 is on a distinguished road
Something like www.automatic.com?
elg206 is offline   Reply With QuoteReply With Quote
Old 11-09-2015, 03:10 PM #4
On Point's Avatar
On Point On Point is offline
On Point is on a distinguished road
On Point's Avatar
i was on the verge of creating a thread about this. I just downloaded an app called "OBD Fusion" for ios yesterday. It cost $10, but is the closest thing to Torque I have found. I was able to create a PID that will read ATF temp.
So far this is the best app for iphone I have found.
Car History from 1st to Present: -1997 Mustang V6 (Sold); -1999 Chevrolet Blazer (Sold); -2001 Chevrolet Silverado Z71 (Sold); -1999 Chevrolet Z28 Camaro (Sold ); 1982 Jeep CJ-7; 2014 Trail 4Runner
The creator of the "TRAIL" badge
http://www.toyota-4runner.org/5th-ge...blem-made.html
On Point is offline   Reply With QuoteReply With Quote
Old 11-09-2015, 04:12 PM #5
Does it require some sort of OBD plug-in or tool?
Old 11-09-2015, 04:25 PM #6
meder24's Avatar
meder24 meder24 is offline
meder24 is on a distinguished road
meder24's Avatar
The Elm 327 adaptor can be found for both iPhone and Android. I have used this with my Android for years now and it works flawlessly.
Plugs right into the OBD port.
If you want it done right, do it yourself!
meder24 is offline   Reply With QuoteReply With Quote
Old 11-09-2015, 04:41 PM #7
On Point's Avatar
On Point's Avatar
yep, i have the wifi obd2 plug. syncs perfectly
Old 11-09-2015, 06:31 PM #8
mace.'s Avatar
mace. mace. is offline
mace. is on a distinguished road
mace.'s Avatar
Wifi being the critical point here. Unless something has changed, iOS doesn't allow the use of Bluetooth enabled obd II scanners
mace. is offline   Reply With QuoteReply With Quote
Old 11-09-2015, 06:36 PM #9
Daohaus's Avatar
Daohaus Daohaus is offline
Real Name: Duan
Daohaus is on a distinguished road
Daohaus's Avatar
Real Name: Duan
that's what i thought as well, because i use the Carista app on iOS device and had to use a wifi enable OBDII dongle
Daohaus is offline   Reply With QuoteReply With Quote
Old 11-09-2015, 07:03 PM #10
On Point's Avatar
On Point's Avatar
Bluetooth can be used with this app
Scanner apps/tools for iPhones and Apple OS-image-jpg
Old 11-09-2015, 07:10 PM #11
On Point's Avatar
On Point's Avatar
Screenshot
Old 11-09-2015, 07:45 PM #12
Lester Lugnut's Avatar
Lester Lugnut Lester Lugnut is offline
Lester Lugnut has a spectacular aura about Lester Lugnut has a spectacular aura about
What trans temp is displayed?
Pan fluid or converter?
2015 2WD Toyota Tacoma Prerunner V6 SR5 1GR-FE 236HP VVT-i
2014 2WD Toyota 4Runner SR5 1GR-FE 254 HP Dual VVT-i
2006 Toyota Avalon 3.5l automatic 2GR-RE Dual VVT-i
1991 Mercedes-Benz 300-SEL M103
1975 Kawasaki 900 Z1-B
Lester Lugnut is offline   Reply With QuoteReply With Quote
Old 11-09-2015, 08:24 PM #13
alfonzo alfonzo is offline
Real Name: dan
alfonzo is on a distinguished road
Real Name: dan
Though I have little to offer on this, let it be known, I appreciate this info. Thanks to all on this forum who have helped me see the light.
alfonzo is offline   Reply With QuoteReply With Quote
Old 11-09-2015, 08:25 PM #14
On Point's Avatar
On Point's Avatar
Pan fluid
Old 11-09-2015, 11:29 PM #15
mo_mo mo_mo is offline
mo_mo has a spectacular aura about mo_mo has a spectacular aura about
Hardware:
iPhone
ELM327 wifi adapter
Apps:
OBD Fusion (I believe allows you to add customized PIDs)
I think only one of these worked...but I was to lazy to delete one and I'm not verifying PIDs at the moment
-AT Pan Temp:
Metric Units C
English Units F
Min Value -40
Max Value 325
Metric to English Scale Factor: 1.8
Metric to English Offset: 32
Module/Header: ECM
OBD Mode: 21
PID Number: 82
Priority: Medium
Equation: ((((A*256)+B)*(7/100)-400)/10)
-TC Outlet Temp: same as Pan Temp except equation C replaces A and D replaces B
DashCmd (wants more money for add-ons, no customized PIDs)
2014 T4R TE Nav KDSS Super White
Demello Hybrid Bolt On Sliders | Toyo Open Country AT III LT285/70R17 C | Ironman 4x4 Foam Cell Pro Stage 2 | Durobumps | Rago Molle Panels | Leather steering wheel cover | RCI Full Skids (Aluminum) | Drawer less drawer system and sleeping platform. | TRD CAI | RAV4 Sideview Mirrors: 87961-42D20 & 87931-42D50 | Blackvue DR650S-2CH | Cobra 75 WX ST with 4’ Firestik + Magnet Roof Top Mount | MXT275 Midland GMRS radio | 3M Crystalline: Front CR70, A-B CR50, B-Aft CR40 | RRW Leather Seat Covers w/Besond Seat Heaters| 3DMax Floor Mats and Rear Husky Liner | former LT265/70R17 C Duratracs
mo_mo is offline   Reply With QuoteReply With Quote
Issue with pairing 2 iPhones to Non Nav? BlizzardSR5 5th gen T4Rs 5 07-31-2021 03:48 AM
