Old 11-09-2015, 09:23 PM #1
rktroutbum's Avatar
rktroutbum rktroutbum is offline
rktroutbum is on a distinguished road
rktroutbum's Avatar
Removed Crossbars, removed caps too!
I wanted to remove the crossbars, so I did. I decided to leave the rear caps off. I did add little covers for the bolts. Does it look weird? I kinda like it.
Removed Crossbars, removed caps too!-img_0042-jpg
rktroutbum is offline   Reply With QuoteReply With Quote
Old 11-09-2015, 09:26 PM #2
OneEyedHito OneEyedHito is offline
OneEyedHito is an unknown quantity at this point
I need to remove my roof rack to have the silver arms painted flat black like they should come on the TRD pro....how did you get the caps off? Just pry them?
'04 V8 - gone a while ago....... :-(
'11 MG LE - Current
OneEyedHito is offline   Reply With QuoteReply With Quote
Old 11-09-2015, 09:39 PM #3
DesertCanyons's Avatar
DesertCanyons DesertCanyons is offline
Real Name: Dave
DesertCanyons will become famous soon enough
Real Name: Dave
replace the roof rack end caps
It's very unfinished for a car that has smooth lines everywhere else. It looks like it will be a dirt catcher too. I have the side rails and no cross bars and it looks good to me. See my Post in the "What did you do in your 5th Gen today, last page as of today. You'll see how I compensated for having no cross rails to haul lumber.
2015 T4R Trail Edition w/KDSS. Baja Rack flat utility rack, Baja Rack ladder, WeatherTech floor mats, Demello rock sliders. RCI skid plates, Falken AT3W LT285/70R17 tires, ICON Stage 7 tubular 2" extended travel lift, ICON Rebound 17x8.5" 0 offset alloy wheels, Baxter Performance remote oil filter adapter. Side exit exhaust, 2nd recovery hook on rear frame corner, DIY wheel well liners with 1/4" neoprene rubber.
DesertCanyons is offline   Reply With QuoteReply With Quote
Old 11-09-2015, 09:46 PM #4
Granth77 Granth77 is offline
Granth77 is on a distinguished road
Just looks like it's missing some pieces. I'd throw them back on if it were me, but it's your rig.
2014 Trail Premium (TRD "Faux"): Bilstein 5100's front and rear, Air Lift airbags, TRD Pro appearance conversion.
Granth77 is offline   Reply With QuoteReply With Quote
Old 11-10-2015, 12:12 AM #5
3wbdriver's Avatar
3wbdriver 3wbdriver is offline
Real Name: CJ
3wbdriver will become famous soon enough
3wbdriver's Avatar
Real Name: CJ
Oh that's gonna affect gas mileage......
2014 Trail Edition -
Build Thread
2015 Epic in my own mind trip
3wbdriver is offline   Reply With QuoteReply With Quote
Old 11-10-2015, 12:28 AM #6
Antman's Avatar
Antman Antman is offline
Real Name: Jeff
Antman is a name known to all Antman is a name known to all Antman is a name known to all Antman is a name known to all Antman is a name known to all Antman is a name known to all
Antman's Avatar
Real Name: Jeff
Yeah- sorry but that looks like crap.
Here's the correct way to do it:
DIY: Roof Rack Delete (w/ pics)
HERE FISHY FISHY FISHY!
Antman is offline   Reply With QuoteReply With Quote
Old 11-10-2015, 02:06 AM #7
05Rrunner 05Rrunner is offline
05Rrunner is an unknown quantity at this point
Did you notice any change in wind noise with the crossbars removed? The reason I ask is my truck is a 2015 it does not have any crossbars and it seems much more wind noise than my 13 which had the crossbars. Thanks for any feedback
05Rrunner is offline   Reply With QuoteReply With Quote
Old 11-10-2015, 02:37 AM #8
Tstoutlv Tstoutlv is offline
Tstoutlv is on a distinguished road
Just paint them while they're off. Super easy. I used the krylon fusion, or whatever it's called, that's designed for plastic bonding. I used the rustoleum bedliner on the rails. Looks good black.
Tstoutlv is offline   Reply With QuoteReply With Quote
Old 11-10-2015, 09:56 AM #9
WakeDreams's Avatar
WakeDreams WakeDreams is offline
WakeDreams is on a distinguished road
WakeDreams's Avatar
Looks good! Did you use Scotch Bright pads to scuff it or paint it as is?
2015 TRDP a.k.a. "Lucille Ball"
WakeDreams is offline   Reply With QuoteReply With Quote
Old 11-10-2015, 12:41 PM #10
rktroutbum's Avatar
rktroutbum's Avatar
I'm going to paint them black and reinstall them today. Thanks for the feedback. Dont just pry them off BTW. There is a post somewhere on removing the caps.
Old 11-10-2015, 07:24 PM #11
TPH4R's Avatar
TPH4R TPH4R is offline
TPH4R is on a distinguished road
TPH4R's Avatar
I used a lifter for a paint can / works great. Pull the cap towards you a little from the inside, slide lifter between the rubber seal and cap (on the outside) - then pry up gently.
TPH4R is offline   Reply With QuoteReply With Quote
Old 11-11-2015, 02:14 AM #12
I used a low grit sanding block. It's held up really well, did it about 7 months ago.
Old 11-11-2015, 07:24 AM #13
arelendsee arelendsee is offline
Real Name: Randall
arelendsee is on a distinguished road
Real Name: Randall
Guess I'm the only other guy who liked it with the caps off, but some valid points where brought up - dirt catcher, maybe wind noise and the fact that my wife hated it. It may be a more appropriate look for a Jeep Wrangler, which is designed with exposed mechanical structures - nuts & bolts, welded seams, etc.
I'm just deleting mine for now, the right way, with the delete kit, as was suggesred in Antman's reply. Although, be advised that some of the part numbers may have changed recently. I will wait and see if the parts department ordered the right stuff before posting a reply with the new numbers in the the Rack Delete thread, in case anyone is interested in doing the same thing.
arelendsee is offline   Reply With QuoteReply With Quote
HCF removed 810moto 4th Gen T4Rs 13 12-08-2020 04:59 PM
Has anyone removed 3rd row seats? 03_4x4Runner 5th gen T4Rs 2 06-08-2014 11:41 AM
ABS removed? rolling blackout Classic T4Rs 8 02-06-2012 05:05 PM
Has anyone removed this piece? SoCalBurt 5th gen T4Rs 8 06-15-2011 09:34 PM
Anyone Removed the Doors? kylebacc 4th Gen T4Rs 7 03-03-2011 04:42 PM
