11-13-2015, 03:04 PM
Super Moderator
Super Moderator
Tire size opinions wanted
I have a 13 TE with a 3" Toytec lift and I'm going to put a set of Black TRD 17x7 rims ( already have in garage). I just don't know what to do with tire size and wanted some opinions. I'm going with BFG AT KO2's. I can stay stock size in a C rated (265/70/17) or move up to 275/70/17 "c" or go to 285/70/17's in an "E" rated.
Whats you thoughts/advice please ???
I've always ran BFG ATko's but was also wondering about the GY Duratracs in comparison , anyone make that switch , and why / thoughts ??
< 2016 Classic Silver TE w/KDSS >< Bone stock at the moment >
Reason: tires
11-13-2015, 03:13 PM
Real Name: David
Real Name: David
I believe the 275's are also only E load. I am running the BFGoodrich KO2 275/70/17 on TRD pro wheels with a 3 inch lift and I regretting not going with 285/70/17. I don't mind running E load, its nice knowing the tires are super strong and airing down wont cause much damage. If you have the room to fit the tires you might as well get 33's and have more clearance off-roading.
2006 T4R Sport 4WD V6 - Bilsein 5100 Shocks, Toytec 2.5" lift front coils, SuperFlex rear coils, Toytec front diff drop, Icon sway bar relocation block - BFGoodrich AT KO2 275/70/17 - Spidertrax 1.5in wheel spacers - DDM 6k low beam headlights & 6K dually ditch lights - Scion FRS radio - Custom rear sway bar end links
Build Thread http://www.toyota-4runner.org/4th-ge...ld-thread.html
IG: Davy180
11-13-2015, 03:14 PM
Moderator
Real Name: Greg
Moderator
Real Name: Greg
11-13-2015, 04:11 PM
Did a super moderator just ask that question and a moderator smack it down?
Crazy.
'01 SR5 3.4 V6 4WD
'04 SR5 4.0 V6 2WD
'07 Tacoma 4.0 V6 4WD
'06 Sport 4.7 V8 4WD
'10 Limited 4.0 V6 4WD
11-13-2015, 04:20 PM
Crazy.
255/85/17 my opinion...
2018 TRD-ORP Classic Silver w/KDSS
2015 TEP Super White w/KDSS
2010 TE Magnetic Grey (Gone but not forgotten)
2006 SE V-6 (Gone but not forgotten)
1996 SR5 4cyl 5 speed (Gone but not forgotten)
11-13-2015, 04:35 PM
Sounds like a generic 'feedback' question to me. I realize everyone likes to throw out the 'use the search function' on these kinds of threads, but some simple feedback is certainly warranted here as well.
11-13-2015, 04:40 PM
Real Name: Richard
Real Name: Richard
Bigger is always cooler.
11-13-2015, 05:03 PM
Real Name: Justin
Real Name: Justin
265s just looked ridiculous with the lift. Honestly, I wish I went bigger than 285s.
2010 4Runner SR5 Magnetic Gray: Radflo / Icon + Metaltech / Total Chaos / Dirt King / SCS Stealth 6 / BAMF Sliders + Pelfreybilt Bumper / PRINSU / Indel B / 2014+ IS 350 Retrofit
2012 GX460 Premium Black Onyx: Stock af
11-13-2015, 05:25 PM
Originally Posted by 1engineer
Love the one you posted on changing tire size, I read it again and again. Has me thinking stay P rated in stock or P275/70/17 for the 1.75 front getting tomorrow. 95% of my driving is pavement and the C rated are 7-8 pounds extra per tire. The small lift is already extra wear and tear on componets. Why make the engine run harder to turn C rated, and the gearing issues you mentioned. Like the Firestone Destination AT2.
2022 TRD OR Premium Nautical Blue as of 12/21/21. Bilstein 5100 front .85, 5100’s rear with Cornfed spacers.
Traded-in 12/21/21: 2015 Trail Nautical Blue w/KDSS, 1.75 Bilstein front, 1" rear confed with Bilstien. 275/70/17 Destination AT. Running Boards, Bug Deflector, Cross Bars, Weathertech.
11-13-2015, 06:34 PM
Tires
Yes... perhaps some harmless immediate feedback.
I went with 275/70/17 C load in a Cooper. No big hit in the weight department or rolling resistance. Big gains in stability over the P rated IMO. Tires were the first thing I did and nose dive under breaking essentially disappeared. Boss Toytec up front and SAW with Bilsteins in the rear.
Beauty is in the eye of the beholder I guess. I like my setup. Not much Off-roading in these parts. Everything I do is down at the beach running Democrat Point to fish and surf… a sand buggy. Other than that it’s a marina and Home Depot mule. A good looking mule though.
2015 Trail | Attitude Black | Toytec Boss Front @ 2.00" | Camburg UCAs | Icon Shifters | Weather Tech | Cooper AT3 LT275/70R17 - C Load. | Sway-a-way Rear Springs 1.5" | 5100 Rear Dampers. | Spiders 1.25
11-13-2015, 10:25 PM
37x13.50"
2012 4Runner Trail Edition....None more black
Hellamatic - Build Thread
11-14-2015, 12:38 AM
How do you use your truck. Do you offroad much? In what conditions?
I would lean towards a 285, but if you are only on hwy and dirt roads... smaller would be fine.
Duratrack is a good tire for mixed use.
11-14-2015, 12:49 AM
34x10.5. I'm considering picking some up to put on my stock wheels and run them in the winter. They're only 33.5" diameter according to BFG specs, so they probably measure out to 31" or so.
11-21-2015, 01:30 PM
Real Name: Jordan
Real Name: Jordan
What PSI are you running for normal pavement driving? We have the exact same tires. My tire pressure dash light came on this week with 32psi in each tire. I put 34psi in each tire and the light is still on. Anyone know how to reset? Toyota says 32psi for the stock 265/whatevers.
'01 Silver T4R Sport Edition 3.4L 4x4 - Old Man Emu 3" Lift with Diff Drop Complete from Toytec - BFG A/T KO 265/75r16 - FOREVER MISSED
'06 Silver T4R Sport Edition 4.7L V8 4x4 - Old Man Emu - Front: 885/NC Sport Shocks, Rear: 895/NC Sport Shocks - Diff Drop - BFG AT KO2 275/70r17 - Spidertrax 1.25
11-21-2015, 02:31 PM
Real Name: David
Real Name: David
I just checked my cold tire pressure and it was 37. I haven't touched it since I have my tires rotated and balanced so that's what they set them at. The door says 32 psi for stock tires so the light shouldn't come on if it's set above that. Is the light solid or flashing? The light should reset while driving, you might have a bad sensor.
IG: Davy180
