Old 11-17-2015, 09:35 PM #1
Diesel_Dog's Avatar
Diesel_Dog Diesel_Dog is offline
Diesel_Dog is on a distinguished road
Diesel_Dog's Avatar
Ultimate lift and LR UCA alignment specs
i just installed a toytec ultimate lift and LR UCAs. Set the UCAs in the D position per the instructions, pulled the ball joint as far towards the outside as I could and took it in for an alignment.
I asked that they set the caster to 4 or more and then get everything else as close to zero as possible.
The results:
Caster L 3.5 R 4.0
Camber L 0.4 R 0.5
Toe L 0.1 R 0.07
Am I in the ball park for what to expect from the aftermarket UCAs? It doesn't appear that they adjusted the Caster setting on the UCA. Should I go back and ask that they get me more in the 4 range for the left side caster?
I'll note that they charged extra because it had a "Lift kit"
I plan to put 285/70/17s on a FN wheel Fx pro rims when the snow is gone. I would like to avoid any rubbing (or at least do what I can with the UCAs)
Thanks for any insight you folks can provide.
2015 | Trail (Canadian) | Toytec Ultimate Lift | SPC LR UCAs | FN fx Pro | 285/70/17 BFG AT KO2
[Sold] 1997 | SR5 | Auto | OME 883/890 | Toyo M/T 265/75/16 | e-locker | ARB Bumper | Warn M8000 |
YouTube Channel
Diesel_Dog is offline   Reply With QuoteReply With Quote
Old 11-18-2015, 07:47 PM #2
Diesel_Dog's Avatar
Diesel_Dog's Avatar
Maybe I should simply my question: is 4 degrees of positive camber over hyped? If someone has less, say 3.5, will one need a body chop, fender liner mod, and remove the mud flaps to run 285s?
YouTube Channel
Alignment specs post lift pokits 5th gen T4Rs 14 06-14-2019 10:17 PM
Help...Need info on 1.75 lift alignment specs GRN285 5th gen T4Rs 13 07-02-2017 06:13 PM
Lift and alignment specs CentcomPete 5th gen T4Rs 12 08-09-2016 06:38 PM
Torque Specs for Toytec Ultimate lift Kit bluebaron 5th gen T4Rs 19 11-21-2010 11:35 PM
