Originally Posted by Hellamatic
Dude, a 275 is roughly 1/2" taller.
To be exact: LT275/70R17/E 121 R is 32.2 inches tall while LT265/70R17/C 112 S is 31.6 inches tall. What it means the truck with 275 tire will have 0.3 inches (7.6mm) higher clearance than stock size. It's nothing - you may get better result just by removing one fat passenger
For the look, difference - sorry I don't buy it.
I checked pictures on the forum from guys showing KO2 with both sizes on their 4R and I have to read description to see which one is on the picture. That extra 0.6 inch does not fill up wheel well to the extend that it will stand out. Some mud on the tire will do better job than the tire size difference.
On the other hand E load tire will ride more stiffer than C, so not only you will loose gas mileage but ride comfort too. I understand that if you rock climb or do real off-road (dirt road is still on-road by my books) than you will not care for the harsh ride, but if you drive your truck as a car, than I don't see any reasons why would you want to have it behave like in a conestoga wagon.
And finally - nobody mentioned it anywhere on the forum (as far as I saw it) if you put bigger tires, the stress on the entire powertrain is bigger. That means the engine, transmission, driveshaft and differential will take higher load than it was originally designed for. It's like driving uphill all the time. It may not be much difference now, but when you hit 300k miles mark the difference will be like
at home and standing on the road
waiting for a tow truck.
Now after I said my piece, OP can start a new "tire" topic - what the heck, one more will not make much difference here
