01-04-2016, 06:40 PM
#16
Real Name: Brett
Real Name: Brett
Originally Posted by ST1FLER
Huh, had no idea. That must be on the other side of the island where the big fence is. Won't let us ovair.
Sorry for the smart ass comment. TBH ST1F I have seen some of your exchanges and still think you are baitin me. lol.
1988 DLX 22RE AUTO BLACK- "Granny" - SOLD
2003 SR5 SPORT V8- Build- "Pearl" You Tube 2UZ 120
2012 LIMITED V6 "LE Mae" 5TH GEN BUILD THREAD
01-05-2016, 04:34 PM
#17
Is that the 2011?
01-06-2016, 11:36 PM
#18
Real Name: Brett
Real Name: Brett
@ DannyLlama
I have MStudt Sway Bar Links so this configuration might look a lot different than what you have.
The lower bolt of the link sits pretty close, but they haven't come in contact with the coil overs. I didn't measure, but Sway Bar itself has almost an inch of clearance.
01-06-2016, 11:58 PM
#19
Real Name: Danny
Real Name: Danny
Originally Posted by 4RunnerAquasport
@ DannyLlama
Thanks man!!
Do you feel like the Sway bar links dropped your sway bar a bit or allowed for better fitment of the sway bar and coils?
2010 LE > TE Conversion, Fox 2.5 DSC Front W/ Camburg BJ UCA's Fox 2.5 Resi rear W/ Icons. Method 701's, Cooper S/T Maxx 285/70/17. Shrockworks sliders. LLama Tales
Dual Battery Thread
01-07-2016, 01:44 AM
#20
Real Name: Brett
Real Name: Brett
Originally Posted by DannyLlama
Thanks man!!
I refer to my default response, I have a lot to learn about all this stuff lol, but being adjustable the MStudt-Links definitely give you some wiggle room. The King reservoir brackets drop the ASB a 1/2" below stock as well. I just shuffled everything around until I felt comfortable with it. I wonder if this bolt (Arrow) could be replaced with one a 1/4" shorter. Maybe I don't have it installed properly. I haven't played the radio for a couple weeks listening for any errant noises under there. I beat the truck pretty good on the trails last weekend and nothing rubbed, banged or had catastrophic failure. So my installation work seems pretty solid. I'm going with
@ MStudt
Discos anyway in the hopes of some extra articulation. All this being said, this system has dramatically improved the handling on the pavement in the corners and on the hwy. The stock set up kind of wandered at hwy speeds. Hope this helps.
01-07-2016, 09:08 AM
#21
official vendor
official vendor
If you can find something that's 7/16 x 2-1/4" that should work. A 2" is a bit short, and the next size up for me is the 2-1/2" you have.
01-07-2016, 10:43 AM
#22
Real Name: Brett
Real Name: Brett
And there he is.... Thanks Mike! These Links are very well done sir. My ACE hardware here usually has whatever I need. Definitely going to try a set of your Discos soon tho!
01-07-2016, 02:41 PM
#23
Real Name: Brett
Real Name: Brett
Diff Breather ext.
Did my Rear Diff Breather yesterday underneath my dirty ass truck. Thank you
@ jgedmond
and
@ hoeftm2002
for the knowledge. I shorted myself on 3/8" fuel line, so I routed it up close to the underside of the bed (leaving slack for axle flex) and zip tied it in random secure areas and didn't cinch em very tight, just enough to keep the hose in place.
01-07-2016, 03:00 PM
#24
Real Name: Brett
Real Name: Brett
Torque Pro
I know this is an old tune for most of you. Did the Torque Pro app this morning. Thank you
@ JeremyB
Pretty cool stuff with the 2 different Trans temp sensors, Engine Coolant sensor and Coolant sensor. Found an old tablet I had laying around that will serve as my new gauge cluster- just got find a way to mount it in the cab. Tested the Converter sensor by hitting it with manual shifting and some rpms. It definitely registers changes quicker than the pan sensor.
04-09-2016, 06:39 PM
#25
Real Name: Brett
Real Name: Brett
Wet Okole and a Baja Rack
Got a couple things done yesterday. Wet Okole fit is top notch.
Hung my Baja Rack from the garage door tracks and pulled the Runner underneath, and lowered it right on to the brackets.
04-09-2016, 07:00 PM
#26
Any tips for installing the lower seat covers? I put mine in not long ago but getting it to go behind the plastic was quite difficult. Looks like you did a better job....I'm planing on re-adjusting mine again soon.
Stay quixotic my friends.
2015 TE, RCI Sliders, TRD skid plate, RCI TRD integration plate, Alu RCI transmission skid, KO2 265/70/17 E
04-09-2016, 08:28 PM
#27
Real Name: Brett
Real Name: Brett
It wasn't real easy, but I just fed the straps and buckles in their respective spots in relation to the seat, and then tucked it in like a shirt. The plastic valance around the seat is probably more pliable down here in Florida, mid to high 80s yesterday, so that may be one reason it didn't fight me. I'm tall and have long arms, so that helps as well. Good Luck!
04-09-2016, 11:05 PM
#28
Detour>>>>
Are those crabs traps I see....
All lobster traps are wooden, aren't they?
Best Regards,
Saker
04-10-2016, 12:40 AM
#29
Real Name: Brett
Real Name: Brett
Originally Posted by Saker
Detour>>>>
They are Shrimp traps sir. Never get used because of work.......
04-14-2016, 07:09 AM
#30
Real Name: Brett
Real Name: Brett
Shrockworks Front Bumper install
Finally found the time to install my bumper. Install was done by myself so a big Thank you
@ philsey
for the bumper removal. A few pics as to why I needed a bumper. These are the previous owners scars:
Reason: When someone does a Shrockworks search, SW is not the smartest search tag lol.
