01-28-2020, 04:43 PM
#226
Real Name: Mark
Real Name: Mark
I am about to order a Kenwood DDX8906s with the Maestro adapter etc. After speaking with crutchfield they said that the usb adapter that is used to connect the factory usb to the new head unit is not Apple Carplay compatible. The head unit has wireless carplay so not a huge deal but I was hoping to keep the usb port in the dash to plug in the phone when charging and having the wired carplay connection. Then have a second usb in the glove box for thumb drives with music downloads. I attached a link to the adapter. It does clearly state that it is not compatible with carplay or android auto.
Metra AX-TOYUSB USB Port Cable Allows you to connect the factory USB port on select 2012-up Toyota and Lexus vehicles to a new car stereo at Crutchfield
Has anyone run into this or is anyone using the factory usb port for carplay?
2019 Trd OR Premium Silver, KDSS, Focal/JL Audio upgrade, all LED lighting interior, xtreme LED Pro low, fog, and high beams, RSG Rock sliders, Pro grille and valance, Bilstein 5100s at .85 w/10mm ome spacer.
1999 Limited Imperial Jade Mica. Still in the family. 275 k.
01-28-2020, 06:42 PM
#227
Mine works just fine. Just make sure you are using a quality USB cable.
2016 4Runner Limited
01-28-2020, 07:07 PM
#228
I used the adapter when I switched headunits. Carplay works just fine.
01-29-2020, 10:33 AM
#229
Real Name: Mark
Real Name: Mark
That's encouraging. From Crutchfield's comments and the notes on the adapter they have had some issues with compatibility. Do you know if you used that same adapter?
01-29-2020, 10:38 AM
#230
I also have the Metra AX-TOYUSB adapter and it works with CarPlay without issues.
Michael
2021 Pro Lunar Rock: RCI tranny/transfer case/tank skids, Victory roof rack
2014 LE Nautical Blue: 285/70R17 Falken A/T3W, FX Pro wheels, Fox TRD Pro suspension with Wescott lift, Dobinson UCA's, Metal Tech sliders
03-10-2020, 11:02 AM
#231
Real Name: Mark
Real Name: Mark
I am going to give it a shot. I spoke at length with a Crutchfield advisor and he said that the original factory USB's can be problematic with Carplay or AA because they only have the minimal circuitry and wire gauge to support just music file transfer and charging. Adding in the Carplay signal could cause issues where CP would not work depending on what you are trying to do. Seems like a blanket statement that may not apply to all vehicles. Will update after I install.
Thanks!
03-10-2020, 03:31 PM
#232
Thanks!
I got all my stuff from Crutchfield and the USB adapter was not listed as compatible. This seems to make some sense based on the advisor's comments. I ordered it anyway and again no issues with using it.
Michael
03-10-2020, 07:56 PM
#233
You will be fine as long as you are using a decent, quality cable. Don't use a cheap thin one. Carplay and Android Auto check for resistance from the deck to the phone.
For my work we had to check out some cable issues, using a PAC 10ft extension and different cables from Best Buy. Platinum brand failed but surprisingly Insignia branded lightning cable ran with no issues.
03-11-2020, 02:45 AM
#234
Real Name: Luke
Real Name: Luke
I'm on my 3rd cable for AA now. 1st one was too long (12ft) and always had connectivity issues. 2nd one, Samsung 6ft, lasted all of 2 months because was too thin and wear and tear got it. Just put an Ankoda from Amazon in last month, so far it's holding up MUCH better than either of the first 2. Although I'm still waiting on Ram Mount's wireless charging cradle so I can have Wireless AA!
03-11-2020, 09:36 AM
#235
I've been using wireless AA on my One Plus 3T for about 6 months now, and it's fine most of the time, but it can take significantly longer for AA and my head unit to recognize. Once it's connected its stable, but getting connected can be a pain...s o much so that I usually still plug in.
My battery also isn't what it used to be anymore, and it drains very quickly when wirelessly connected. I'll upgrade at some point to something that wirelessly charges, but since the phone hasn't slowed down any, and it still lasts a full day on a single charge, I don't want to spend the $$ to upgrade.
2014 Classic Silver TE w/ KDSS - The Waco Kid's Build and Adventure Thread
Wife's Ride: 2017 RX 350
Past Vehicle:2001 Dodge Dakota Sport 4.7L V8 Quad Cab.
03-16-2020, 11:17 AM
#236
Real Name: Mark
Real Name: Mark
I got everything installed over the weekend and I am pretty happy overall. The Kenwood headunit made a huge difference in sound. Loving the features etc.
Couple of questions.
1)when Carplay initially boots up I get some slight skipping or glitching in music play. It goes away eventually. Anyone else experiencing this?
2) When I plug into the factory usb port my phone (iphone 11) says this device is not supported. I honestly have no idea if I am connected through the usb or just wirelessly. It sounds good and charges so not sure if it matters. Any insight on this would be appreciated.
I may end up getting this and just replacing the factory USB port and rca port. I never use the rca anyway.
Beuler USBD-Kit Dual 3' USB cable extensions with dash mounts for a variety of vehicles at Crutchfield
03-16-2020, 03:26 PM
#237
1. Mine does this 1 -2 times within 15 seconds of connecting. OK after that.
2. I have iPhone 11 and no issues. Can turn WiFi off on phone and connect it using USB to see how it goes.
Michael
03-16-2020, 04:24 PM
#238
You may just need a firmware update.
03-16-2020, 04:50 PM
#239
My Kenwwod with wireless Carplay will do this when connecting/disconnecting the USB while already connected wirelessly. I think Carplay is just confused is all. It keeps working and running just fine.
Occasionally I need to plug the phone in to get wireless working. I think it mostly happens after the phone is rebooted and needs that wired connection.
03-16-2020, 07:28 PM
#240
Real Name: Mark
Real Name: Mark
Thanks. Sounds like it’s not unusual. Just wanted to make sure I didn’t have something strange going on. It works great after about 2-3 minutes.
Now I need to decide when I want to reflash the maestro dad gummit! I should have added more customization.
Great thread. Thanks to everyone.
