01-31-2020, 12:49 AM
#316
Real Name: Andrew
Real Name: Andrew
Originally Posted by Midnight_T4R
Hey, do you have the dimensions/ drawing available for this drawer system?
Unfortunately I do not have dimensions or drawings. I measured everything when I was building and wrote it down with a sharpie on the wood I was using. I made everything off the cuff!
08' Limited V8 (2020-Current)
17' TRD Pro (Sold: 2017-2020) - Update/Mod/Build/Adventure Thread
08' Urban Runner (Sold: 2010-2017)
02-15-2020, 07:50 PM
#317
Real Name: Terry
Real Name: Terry
$132.40 Storage & Sleeping
If you are thinking of going low end - this is about what it takes:
Carpet, padding and 2 sheets of 3/4" 4x4 plywood - $23 each.
(2) 2x8x8
(2) 2x3x8
Various turnbuckles, screws, staples.
Went with (2) tubs from Target instead of drawers - partly for weight, partly for ease.
Storage was pretty easy - used the usual tie downs with turnbuckles.
Removed seat cushions and sleeping platforms rest on the seat backs.
They were easy to build and annoying to figure out how to keep them secure and not shift/tip.
Storage Box - 53lbs
60% Sleep Side - 25lbs
40% Sleep Side - 17lbs
2016 SR5 - Wildpeak A/T3W 265/70R17SL or BFG K02 C Load 285/70R17; RSG Sliders; LFD Crossbars, Skid Plates & Hybrid Bumper; RCI Skids on Rear Diff, Lower Links & Shock Mounts; Engo SR10S Winch; Dobinson 700/701 IMS with 314/327 Coils +2.25" front +2.5" rear; Goat Armor; Redarc Brake Controller; Camping Hatch Mod; DIY Drawers & Sleeping Platform; Cheap 10" Light Bars in Grill; Front/Rear Camera Mod with Nav Input; Simple Nav/Comms - Garmin inReach Mini, iPad & Motorola FRS.
02-16-2020, 07:23 PM
#318
Real Name: Terry
Real Name: Terry
Bucket Toliet
And if you are sleeping in the truck, don't forget...
02-17-2020, 05:18 PM
#319
Real Name: Cas
Real Name: Cas
Made these a while back, never got around to posting photos. Used tons of inspiration from the site.
Whosoever is delighted in solitude is either a wild beast or a god.
02-17-2020, 07:08 PM
#320
Originally Posted by Anthocar
Finished product...minus paddle latches.
Sent from my SM-G950U using Tapatalk
What kind of carpet you use?, Im in the process of building one and need .25 thick carpet
02-17-2020, 08:13 PM
#321
Real Name: Terry
Real Name: Terry
Padding gives you the .25
Any of the cheap indoor/outdoor carpets at HD or Lowe's are so thin it almost doesn't count.
The thickness comes from the padding.
I used the pre-cut 6'x8' rug pad from HD - think it was $24.
Pre-cut 6'x8' pieces of carpet are also available and 1/2 as much as the stuff on the roll.
That's why I went with grey instead of trying to match the black OEM carpet.
QUOTE=SpaceBanana;3444454]What kind of carpet you use?, Im in the process of building one and need .25 thick carpet[/QUOTE]
02-17-2020, 08:21 PM
#322
[/QUOTE]
I was trying to buy automotive carpet to match it, but Ill go check HD out. Thanks!
02-25-2020, 04:23 PM
#323
::2010 Trail Edition:: ICON Front Coilovers w/Remote Resi's and CDC - ICON Tubular UCAs, ICON Rear Ext-Travel Shocks w/Remote Resi's and CDC - MT Long Travel Springs and Lower Links, 285/70 Goodyear Duratracs, Bronze Countersteer Offroad Type X, CBI Rear Bumper w/Tire Carrier, Shrockworks Sliders and full skids, Pioneer Z120BT, Rockford Fosgate Speakers and Amps, aFe Intake, Aux Battery set up, Roofrack by drabbits, SoCalTrail Behind the Grill Light Bracket
02-26-2020, 01:14 AM
#324
Originally Posted by 4ShoreRunner
Wow! That is a sweet setup!
Sent from my SM-N960U using Tapatalk
02-26-2020, 10:36 AM
#325
Real Name: Jonathan
Real Name: Jonathan
Here are pics of my setup which is able to sit above and retain the factory sliding tray.
Carpeted plywood is attached to a custom metal frame that bolts into the factory tie down holes. I mounted an ARB fridge slide to the plywood.
I've been debating something like this as I finally am considering a fridge. How are the front legs attached to the tiedown bolt hole?
One thing that makes me think twice about this is I sleep in the back when solo camping and this eliminates the flat floor.
2010 TE KDSS|275/70R17 Goodyear MT/Rs|Front Bilstein 5100s @ 2.5", rear Bilstein 5100s & 2" Icon lift springs|RR sliders|RCI skid plates|BudBuilt diff skid|Sonoran Steel HD rear lower links|RCI rear lower link bracket skid plates
02-26-2020, 12:22 PM
#326
Real Name: Jeremy
Real Name: Jeremy
That is well executed. those tie downs are essentially useless to me, so I'd like to do something similar..
'18 SR5 4WD, magnetic gray metallic, stock, RCI front skid, LFD cross bars, Pedal Commander, Accessorides Remote Start.
02-26-2020, 03:24 PM
#327
Each leg is simply bolted in utilizing longer hardware. The front feet I had to make a rubber spacer between the frame and the floor to make it level.
There is ~3" difference in height in that section of the floor so certainly wouldn't let you lay flat unless you tried to raise the rest of the floor where the seats are folded down somehow.
BTW - if anyone is interested and is in the DC Area this setup is going to be listed on the For Sale Thread...I sold the 4Runner in January.
02-26-2020, 04:16 PM
#328
Dometic is having a sale on their last gen fridges. They just came out with a new line but more features and such but if all you need is a fridge then the last gen stuff is a good deal.
Dometic Online Store - Clearance Items
2016 Nautical Blue Metallic Trail | SCS | Falken Wildpeak AT3/W | Icon CDCV | Heftyfab Front Bumper | 4x4 Labs Rear | Shrockworks Sliders | RCI Skids | Warn VR10S | OGE Dual Battery System | sPOD | Katzkin
2013 Blizzard Pearl LE 4WD - SOLD!!!
02-28-2020, 12:31 AM
#329
Any Dobinsons drawer users out there? Has really caught my eye because of the clean full-coverage panels and price point compared to other setups. I'd love to hear some feedback!
02-28-2020, 02:15 AM
#330
Real Name: Jonathan
Real Name: Jonathan
I saw that and grabbed one of them! 35% off was a great deal.
