Thread Tools Rating: Thread Rating: 3 votes, 3.33 average. Display Modes
Old 05-11-2017, 11:33 PM #1
b407driver's Avatar
b407driver b407driver is offline
b407driver is on a distinguished road
b407driver's Avatar
Installed: Rola low-profile mounts on 5th Gen
After having trouble finding whether or not 4x Innovations low-profile Rola mounting hardware would work on a 5th Gen (flipped upside-down), I finally got the info I needed from @Toytrpr that it would work. Bit the bullet on the rack ($143 shipped from AutoAnything), and finally got it mounted today.
As per many previous reports, it needed some touch-up work for holes in the (crappy) welds, so I sealed those up with some black gasket sealant. When joining the two sections, I used ample sealant on all male/female surfaces, as the 'stock' fit is pretty loose. Sealed all the screw holes as well, and vinyl-wrapped the fairing (satin black) to get rid of the logo and glossy plexiglass. The powder-coating wasn't as bad as I expected, but we'll see how it holds up. Made the mistake of clear-coating due to the flat black paint touch-up I did; although it looks good on the paint, it will scrape right off the powder coat.
I'm very happy with the mounts (not cheap, though); well designed product, and very burly. Brackets and all hardware are stainless. Flipped upside-down, it puts the rack a good 1 to 1.5" below where it would have mounted using the included brackets attached to OEM crossbars, and only about maybe 1-1/4" above the traditional low-mount as designed for the 4th Gen 4Runners.
Mounting was pretty straightforward, just had to decide where I wanted the rear compared to the shark fin. Decided to mount the rear bar behind it, keeping the basket closer to the rear for loading, and further from the sunroof (for noise).
For my modest uses it's going to work well, and glad I saved the $800+ on a 'real' rack. I'm out $221.
Installed: Rola low-profile mounts on 5th Gen-profile-jpg  Installed: Rola low-profile mounts on 5th Gen-rack-jpg  Installed: Rola low-profile mounts on 5th Gen-1_img_6092-jpg  Installed: Rola low-profile mounts on 5th Gen-2_img_6090-jpg  Installed: Rola low-profile mounts on 5th Gen-3_obliq-jpg  Installed: Rola low-profile mounts on 5th Gen-4_front-jpg  Installed: Rola low-profile mounts on 5th Gen-img_6088-jpg  Installed: Rola low-profile mounts on 5th Gen-5_img_0863-jpg
[1986 Toyota XtraCab, 1990 4Runner SR5, 2003 Seqouia SR5] 2016 SuperWhite 4Runner TRD Trail
ToyTec 1" TRD Spring Seats, both set at top perch (2" lift) | Wheelers/Eibach T-13 1.5" rear coils | Cooper AT3 275/70-R17 tires | TRD Skidplate KDSS mod (cutouts) | Smittybuilt BeaverStep w/grip tape | Rola Vertex cargo basket w/AT Low-Profile mounts | ARB Differential/E-locker Breathers | Rotopax 2x 2gal fuel, 2x 2gal water
b407driver is offline   Reply With QuoteReply With Quote
Old 05-11-2017, 11:33 PM #2
b407driver's Avatar
b407driver's Avatar
Not sure why that last one is upside-down, but it doesn't seem to want to cooperate...
Old 05-11-2017, 11:49 PM #3
kevinmai712's Avatar
kevinmai712 kevinmai712 is offline
kevinmai712 is on a distinguished road
I had the exact same rack on my subaru, one bad thing about that rack is that even tho you seal all the openings and what not, water still get in it and rust... also it fades quicky.
2015 Trail Super White, 3" Toytec with 5100 Blisten, Nitto Ridge Grappler 285/70R17, SCS SR8, Rigid Industries DOT/SAE Fog Lights, LED interior, XenonDepot Phillips 4300k HID, Gobi Ladder, Prinsu Design roof rack, RCI Sliders.
kevinmai712 is offline   Reply With QuoteReply With Quote
Old 05-11-2017, 11:53 PM #4
b407driver's Avatar
b407driver's Avatar
After spending an hour on sealing the holes, I can see how it would be easy to miss several, resulting in the myriad rusting issues. Also, the fairing mount holes are not so easy to seal, so we'll see...
Old 05-11-2017, 11:59 PM #5
"krax" "krax" is offline
"krax" is on a distinguished road
Looks like you could use those brackets with a Yakima or other basket. I dig the mounting solution.
"krax" is offline   Reply With QuoteReply With Quote
Old 05-11-2017, 11:59 PM #6
I also bought it from AutoAnything.com. I like the way it looked but it was on the heavy side for my subaru so i sold it
Old 05-12-2017, 08:34 AM #7
b407driver's Avatar
b407driver's Avatar
You probably could, though there's a pretty narrow margin for what width rack would work easily. Might be able to wing an adapter, but the more parts there are, the more there is to loosen.
Old 05-12-2017, 08:50 AM #8
(none) (none) is offline
(none) is on a distinguished road
Looks great. I really like the low profile with the stock rails, I'd like to do something like that as well. Stupid question though, why are you running the brackets upside down? Will it not fit the correct way? I'd figure it would be better to have the rack sitting as low as possible.
2016 Trail and half of an early 90s Ford Ranger
(none) is offline   Reply With QuoteReply With Quote
Old 05-12-2017, 09:15 AM #9
b407driver's Avatar
b407driver's Avatar
Brackets were designed for '03-'09 rails; if mounted 'properly,' the u-bolts likely will contact the roof, and there'd be little to no room to wrench. I thought about 'hanging' the rack in the u-bolt, beneath the upside-down bracket, in order to lower it another inch (putting it closer to the normal low-profile height), but the bolts/nuts would have been sticking up into the rack.
Old 05-12-2017, 09:16 AM #10
007Tacoma's Avatar
007Tacoma 007Tacoma is offline
Real Name: Mark the Common Sense Wizard
007Tacoma is just really nice 007Tacoma is just really nice 007Tacoma is just really nice 007Tacoma is just really nice 007Tacoma is just really nice
007Tacoma's Avatar
It looks really good, and it requires minimum effort? Win-win!
Edit: How is the wind noise and drag?
What is the weight capacity?
I'm 007Tacoma.
...well yeah... because we have a... 2007 Tacoma... no a 2008 Tacoma... no a 2003 4Runner er... 2015 4Runner Trail Edition
Check us out at TrailOrSail.com or on our YouTube Channel TrailorSailYT
007Tacoma is offline   Reply With QuoteReply With Quote
Old 05-12-2017, 09:50 AM #11
Redfisher3 Redfisher3 is offline
Redfisher3 is on a distinguished road
Thanks for this. Just bought a gen5 (1st 4runner) last weekend and have been looking at this exact rack.
Redfisher3 is offline   Reply With QuoteReply With Quote
Old 05-12-2017, 01:28 PM #12
Gotcha. Makes sense. Thanks!
Old 05-12-2017, 01:31 PM #13
UtahFox's Avatar
UtahFox UtahFox is offline
Real Name: Dave
UtahFox is on a distinguished road
UtahFox's Avatar
Real Name: Dave
Black duct tape to seal the joint? Or maybe red and call it a mod
2017 MGM TRD Offroad Premium: Husky Liners - Alpine SPS-110 TW
Some Pics from My Most Recent Mods & Intro
UtahFox is offline   Reply With QuoteReply With Quote
Old 05-12-2017, 01:39 PM #14
Toytrpr Toytrpr is offline
Toytrpr is on a distinguished road
I've had it in for about a month and no noise below 60mph. Once I go up to 70 mph I hear the drag and wind noise. I have yet to seal my joints and have I not put in the plastic tubes/ gaskets they provided. So maybe that will take care of some of it. Hopefully.
Toytrpr is offline   Reply With QuoteReply With Quote
Old 05-12-2017, 03:44 PM #15
r1verf3nix r1verf3nix is offline
r1verf3nix will become famous soon enough
@b407driver
what length did you buy the standard (48") or the extended (66").
r1verf3nix is offline   Reply With QuoteReply With Quote
Armor Tech Offroad low profile rola mounts Lenny33 5th gen T4Rs 40 04-20-2017 01:42 PM
FS: 4th Gen- Rola Roof Basket & Low-Profile Mounts- Ft. Worth, TX unevolved For Sale: T4R Items 6 10-11-2016 05:43 PM
rola rack low profile mounts jdmaccord6 3rd gen T4Rs 3 04-01-2012 11:38 PM
Rola rack light mounts RunnerRyder 4th Gen T4Rs 0 11-26-2011 10:11 PM
Have Rola Rack mounts? Clemsonfan15 3rd gen T4Rs 9 07-10-2010 06:23 PM
