Old 01-11-2016, 12:12 AM #1
Cire2's Avatar
Cire2 Cire2 is offline
Cire2 is an unknown quantity at this point
Cire2's Avatar
Power Steering Whine
I've noticed a loud whining noise while making slow, sharp right or left turns. Has anyone else come across this? I'm not sure if it is my power steering pump or rack and pinion, and if I need to replace either or.
Any help would be greatly appreciated.
-Cire
Cire2 is offline   Reply With QuoteReply With Quote
Old 01-11-2016, 12:43 AM #2
03_4x4Runner's Avatar
03_4x4Runner 03_4x4Runner is offline
03_4x4Runner has a spectacular aura about 03_4x4Runner has a spectacular aura about 03_4x4Runner has a spectacular aura about
How many miles do you have? The best place to start is flushing/changing the fluid.
03_4x4Runner is offline   Reply With QuoteReply With Quote
Old 01-11-2016, 04:10 AM #3
96r50 96r50 is offline
96r50 is on a distinguished road
X2 on your mileage and model year. How old is your serpentine belt? If it's not the fluid or the pump it could be the belt starting to slip.
2010 4Runner Trail Edition
96r50 is offline   Reply With QuoteReply With Quote
Old 01-11-2016, 04:37 AM #4
Cire2's Avatar
Cire2's Avatar
Thanks for the quick response guys.
My 4Runner is 2010 TE with a Toytec lift. There is currently 50k miles and the fluids and belt are original. The fluid looks transparent.
It's a weird sound. It sounds more like a whiring sound and occurs only while turning at low speeds. Are there any internal filters that could be clogged causing low fluid to make it to the pump?
2010 4Runner TE
2015 4Runner TE-P (sold)
Old 01-11-2016, 07:35 AM #5
I haven't actually looked in there myself but I'd assume that there's the typical Toyota fine mesh screen at the bottom of the reservoir to trap any particulate that gets in the fluid. I'd be surprised if there was enough junk in there to clog it though. If your fluid is clear then it's probably still the factory fill. I'm at the same mileage/year with the original fluid and belt and no issues.
Have you done a visual inspection of the steering rack? Maybe the lift increased the tie rod angles enough to wear something out faster than usual? Maybe take off the skid plate and check the lines for pinhole leaks as well.
Old 01-11-2016, 11:05 AM #6
Cire2's Avatar
Cire2's Avatar
I'll inspect it further this weekend as well as flush the system out and respond with my findings. Thanks for the pointers!
2010 4Runner TE
Old 01-11-2016, 11:29 AM #7
wfo9's Avatar
wfo9 wfo9 is offline
wfo9 has a spectacular aura about wfo9 has a spectacular aura about
wfo9's Avatar
changing fluid is a good place to start with a whine... It's a closed system, so very unlikely to have debris... more likely air and cavitation.
wfo9 is offline   Reply With QuoteReply With Quote
Old 02-14-2016, 08:40 AM #8
Ledvette77 Ledvette77 is offline
Ledvette77 is on a distinguished road
Cire,
I just started having the same problem after off-roading yesterday. Haven't inspected in-depth yet but I was wondering if you came up with anything that might have been causing yours, or of course if you fixed it.
Ledvette77 is offline   Reply With QuoteReply With Quote
Old 03-17-2016, 09:23 PM #9
Briton Briton is offline
Briton is on a distinguished road
I've also been having the same issue. It's only at slow speeds, turning right or left. Fluid level is good, although I haven't checked it's coloring, and the belt looks to be ok. Both are original. It's a 2010 TE with 55k and change. Any help would be great. Hopefully it's nothing too costly.
Briton is offline   Reply With QuoteReply With Quote
Old 03-23-2016, 12:26 AM #10
latha024 latha024 is offline
Real Name: Britton
latha024 is on a distinguished road
Real Name: Britton
I was having the same issues. Last week I had the dealer do a full power steering service and it's completely gone. I think it was about $150 but the steering feels incredible. I'm generally not a believer in flush services, but this one was worth it.
2010 TE w/ KDSS - Huntsville, AL
latha024 is offline   Reply With QuoteReply With Quote
Engine Whine - mechanic wants to replace my power steering pump at 70k miles Mike2005v8 Maintenance/Detailing 7 05-02-2017 11:48 AM
Power Steering whine Brian1973 3rd gen T4Rs 4 11-05-2014 07:40 PM
cold start power steering whine twicepipes 3rd gen T4Rs 15 04-13-2014 10:26 PM
Steering whine Nelsonmd 3rd gen T4Rs 4 07-28-2013 01:10 PM
