Old 01-14-2016, 04:19 PM #1
biologistbarlow biologistbarlow is offline
biologistbarlow is on a distinguished road
Auto headlights not turning off
I have a new 2016 4R TRD Pro. Love it. But the auto headlights will not turn off sometimes. I know click lock fob twice, and sometimes that works but more often than not headlights do not turn off. I am probably doing something wrong but was curious if others are having issues... Thank you
biologistbarlow is offline   Reply With QuoteReply With Quote
Old 01-14-2016, 04:25 PM #2
adam.friedman.33's Avatar
adam.friedman.33 adam.friedman.33 is offline
adam.friedman.33 is on a distinguished road
I had the same issue. Never could figure it out
adam.friedman.33 is offline   Reply With QuoteReply With Quote
Old 01-14-2016, 05:06 PM #3
frustrating
thank you... it seems simple enough... I turn truck off, walk away, headlights turn off (after factory set delay). But it rarely does that! Frustrating... but I am grateful to count that as a "problem" in my life!
Old 01-14-2016, 05:16 PM #4
LawnDart's Avatar
LawnDart LawnDart is offline
LawnDart will become famous soon enough LawnDart will become famous soon enough
LawnDart's Avatar
If you lock it and walk away they stay on for 20-30 seconds. If you double click lock they'll blink and turn off. They're usually done that way as a safety feature so you have some ambient light from the vehicle, e.g if you were in a parking structure.
I don't own a 4Runner anymore.
LawnDart is offline   Reply With QuoteReply With Quote
Old 01-14-2016, 05:18 PM #5
Mine does not turn off. sometimes the double click will do it, but most times not... Hate to come out of a movie theater and see headlights still on...
Old 01-14-2016, 05:19 PM #6
LawnDart's Avatar
LawnDart's Avatar
Is your light stalk controls set to the default positions?
Old 01-14-2016, 07:56 PM #7
03_4x4Runner's Avatar
03_4x4Runner 03_4x4Runner is offline
03_4x4Runner has a spectacular aura about 03_4x4Runner has a spectacular aura about 03_4x4Runner has a spectacular aura about
If I pull into the garage at night when the lights are on in the auto position and do not close all the doors because I am taking things out the headights will not turn off until all the doors are closed but I assume you are having the problem when all the doors are closed.
03_4x4Runner is offline   Reply With QuoteReply With Quote
Old 01-14-2016, 09:37 PM #8
cyclist cyclist is offline
cyclist is on a distinguished road
Assuming you're using auto headlights? Or are the headlights turned to the on position?
cyclist is offline   Reply With QuoteReply With Quote
Old 01-14-2016, 09:40 PM #9
05Rrunner 05Rrunner is offline
05Rrunner is an unknown quantity at this point
My truck doesn't have an auto setting it has on or off that's a trail premium.
05Rrunner is offline   Reply With QuoteReply With Quote
Old 04-22-2021, 09:42 AM #10
Preciadoracing Preciadoracing is offline
Preciadoracing is on a distinguished road
Recently ran into this issue and one of the other things I noticed is that my interior dome lights as well as my door open on the dashboard isn't coming on also. Thinking this might be part of the issue but am not sure if there's a relay to check for this issue or if it's in the ecu?
Normally engine off. Doors open. Doors closed. Then lock would turn off the lights. If it's not registering Doors open this might be part of the issue. Am I the only one?
Preciadoracing is offline   Reply With QuoteReply With Quote
Old 04-22-2021, 10:51 AM #11
Iron_Will Iron_Will is offline
Iron_Will is on a distinguished road
man stop talking about these things...Ive got this picture in my head that 4runner is perfect lol
Iron_Will is offline   Reply With QuoteReply With Quote
Old 04-26-2021, 08:00 PM #12
It was my fault lol. Bad ground when rewiring aux DRL. Disregard.
Everyone double check your grounds 🤣
Old 04-30-2021, 01:32 PM #13
fourrunnerbill fourrunnerbill is offline
fourrunnerbill is on a distinguished road
My 2016 TE turns off the headlights after a short while but if I click the fob lock button just once they turn off immediately. For quick stops I rely on the auto shut off to see it work properly but if leave the vehicle for longer periods I turn them off and don't chance it.
fourrunnerbill is offline   Reply With QuoteReply With Quote
Old 05-02-2021, 10:17 PM #14
PCRIDE4RUNNERORG PCRIDE4RUNNERORG is offline
PCRIDE4RUNNERORG is on a distinguished road
Same here,
Sometimes lights stay on. Not sure which combo makes this happen. If you unlock and don’t open the door it locks again. If you park then not lock, I think the lights stay on. But I’ve seen where I swear it was locked but the lights stayed on
PCRIDE4RUNNERORG is offline   Reply With QuoteReply With Quote
Old 05-03-2021, 12:53 PM #15
skag1T skag1T is offline
skag1T is on a distinguished road
Same with mine. Have to turn the lights off manually.
Also, there is no low fuel and low windshield washer warning lights !
Doesn't bother me, but never seen that in a car !!
skag1T is offline   Reply With QuoteReply With Quote
Auto headlights lambohaha 4th Gen T4Rs 2 01-11-2014 12:43 PM
New Owner Headlights turning off randomly problem fblainen11 3rd gen T4Rs 2 11-19-2012 12:04 PM
Turning on Headlights with remote!? advent 4th Gen T4Rs 6 11-10-2011 04:08 AM
Auto Headlights aeathb 4th Gen T4Rs 3 02-06-2010 10:12 PM
auto off headlights not turning off dr.john 3rd gen T4Rs 6 01-22-2007 09:33 PM
