01-17-2016, 02:23 AM
'16 Limited - Wandering Issues?
New to T4R coming from an old '00 Ranger. Excited to join up!
Picked up a new '16 Limited last Sunday and experienced something completely new to me...wandering (per a few searches).
Issue
Essentially, the truck continuously sways left and right at highway speed (65mph+) on a good freeway here in the bay area when driving dead straight. There is minimal (expected) wheel play and it tracks pretty well.
Solution?
After searching, I found it could be two things given the new tires: tire balance, tire structure themselves. I also found that for older trucks it could need be: tired rotation or the tire wear is uneven.
Request/Next Steps
I intend to bring it to a local dealer given the warranty, but does anyone have ideas on what I should bring up?
Thanks in advance!
*Note: I have driven trucks before and towed in wind, so I understand there is expected sway and steering play.
[RIP] '00 Ford Ranger XLT
'16 LE: Metallic Gray; SSO Rack, FN (X) Pro Wheels, Falken AT3W Tires, ALL RCI (Aluminum) Skids, SDHW ABS Sensor Covers, Molle Rear Panels, ArcLight Red Light Mod, Ironman 4x4 FCP Stage 3 (2.5"/2"), RCI Sliders, BudBuilt Hidden Winch + Smittybuilt 10k WInch, AGM
Coming soon...lighting & Platstidip
01-17-2016, 02:44 AM
Swaying
Does the highway have slight grooves in it. I experienced a similar problem at high speeds that is the result of the tires. It even does it on a new cement highway with small parallel lines in them. My tires were Yokahamas. Changed the tires and it went away. You mentioned it wasn't tracking, but this an similar tracking problem that I experienced.
01-17-2016, 03:08 AM
Real Name: Dave
Real Name: Dave
Wander off course
There doesn't appear to be any play in the steering that I've noticed in my 2015 with 4500 miles on it. But if I look away for a second the car will steer itself off course. I find the car wandering out of the lane when I'm distracted. I've learned to keep my eyes on the road and not look away for more than a second.
2015 T4R Trail Edition w/KDSS. Baja Rack flat utility rack, Baja Rack ladder, WeatherTech floor mats, Demello rock sliders. RCI skid plates, Falken AT3W LT285/70R17 tires, ICON Stage 7 tubular 2" extended travel lift, ICON Rebound 17x8.5" 0 offset alloy wheels, Baxter Performance remote oil filter adapter. Side exit exhaust, 2nd recovery hook on rear frame corner, DIY wheel well liners with 1/4" neoprene rubber.
01-17-2016, 10:23 AM
Real Name: Um, Phil?
I had this problem when new, for several months actually.
From reading this forum, this was quite common. The solution was to get an alignment and have the caster set to as near +4 deg as possible.
It was like magic. That was 2010, been great ever since.
Fortunately, my Toyota SM knew exactly what I wanted, and why. Your dealer may push back on the 4 degrees, telling you that "it's already in spec". This has been discussed on here multiple, multiple times - same symptom, same fix.
Google search this forum for "caster" or "castor", you'll see. Don't rotate, don't swap tires, don't do anything else until you first get the caster set.
And get a printout from the alignment so you can see what it is.
2010 Blizzard Pearl SR5/P - traded
2018 Superwhite SR5/P ... IS350 retrofit.
02-07-2016, 05:22 PM
I just got back from a windy road trip and had to search to see what others had experienced regarding wandering. My last vehicle was a '09 Tacoma TRD double cab, and there is a drastic difference between it and my '15 4Runner SR5 Premium. It surprised me because they are so similar in many ways.
I'm going to go to my dealership and ask about the castor setting, because my last long drive was ridiculous. Not enjoyable at all.
I'll post my results.
02-07-2016, 07:30 PM
When my 14 was new it wandered. The dealer aligned the front for free and it is fine now. The toe in was slightly off.
07-03-2017, 10:40 AM
4 runner wandering
My 2016 is wandering exactly like the rest in this thread. Did the +4 deg of caster put excessive wear on your tires? Did it cause the tires to rub the inner fender splash shields? Any help would be appreciated.
Reason: Combining questions
07-03-2017, 10:51 AM
Caster does not affect tire wear, but more caster isn't always better, either. It's not necessarily a cure-all for all "wandering" issues, which can have a variety of sources.
Not directed at the OP, but honestly, I don't know why there's generally so much voodoo associated with alignment. It ain't rocket surgery.
2016 Trail Edition w/KDSS - Super White - Toytec - Eibach/Bilstein - Kumho 275/70-17
07-03-2017, 11:28 AM
* You don't necessarily get to 4* always, but no.
* No, but oem sized
07-03-2017, 11:44 AM
My 4 runner is a 2016 stock SR5 with 5000 miles on it. The OEM tires were flat spotted from sitting on the lot so I replaced them with Toyo Open Country HT. Vehicle wear can't be the culprit, so I am trying as many avenues as possible to get this truck to a point that we want to keep it.
11-30-2017, 02:06 AM
16 FourRunner wanderer
My 16 Four Runner had issues with wandering from day one. Was a new build. Toyota checked pressure in tires and said they did not see problem. It was realigned and rebalanced. Still had same issue. I liked the vehicle but it made driving to much of a chore. The other issue I had with it was I had cloth seats and they were wearing out so fast on the edge of drivers seat. The black cloth was turning gray. If the truck did not have the front end issue I was gonna have leather put in but felt like it was a losing battle. I traded it in on a 17 F-150 Lariat which drives and tracks beautifully. Ironically gas mileage is about the same. Wish they would bring the Fj Cruiser back!
11-30-2017, 09:58 AM
Banned
Banned
you could have saved yourself from having to drive a ford if you just got it aligned
11-30-2017, 10:47 AM
Hopefully you don't have the highway vibration that is inherent in so many F-150s... my '13 had it and so do a lot of the new ones. What's bad is there is no cure:
https://www.f150forum.com/f118/vibra...e-read-395499/
2012 Limited, 4WD, Classic Silver Metallic
2018 TRD ORP - Sold
2006 Sport Edition - Sold
11-30-2017, 12:22 PM
I'm going to post my recent experience with my just-delivered 2018 in the event other new deliveries have a similar problem.
Given my experience with my new 2010 (posted earlier in this thread), and the fact that the '18 also wandered about on the highway, I was sure I had the same problem with caster setting.
My dealer agreed to check alignment. On the rack, the tech checked air pressure first, found >50# all around. It was delivered this way. I should have checked it, but assumed a new vehicle would have been checked.
Back to 32# ... problem solved.
11-30-2017, 01:04 PM
Real Name: Tom
Real Name: Tom
I had the wandering problem with the 2015 SR5 that I used have. It was like this from the get go. It was both 50+ lbs in the tires and alignment. I found the over inflation. It helped but it was still all over the road. Took it back to the dealer. They checked the alignment. Said it was out and adjusted it. Night and day difference. The 2017 TRD ORP I have now tracks solid.
