09-28-2018, 02:33 PM
#46
Originally Posted by ride16734
There is a remote starter that is plug and play type and you can add cellular app with receiver. It’s made by 12volt.solutions
Did a little research and its on sale for $349 now. Pretty much plug and play except for 2 wires to splice in. Video seems pretty easy to instal and vehicle remains running when you open door.
'14 4Runner SR5 Premium Bilstien 1500's, Airlift bags, 275 70R 17 Cooper AT3's,Power Stop rotors & brakes, Xenon Depot 9005 Extreme Pro LED, Morimoto H11 2Stroke 2.0, AEM dry flow filter, Magnaflow exhaust, Sprint Booster
'19 Tundra Limited CM, 2.5/1 Bilsteins 5600's, Cooper AT3 275 70 18 on Method NV305's
'12 Subaru Legacy Limited
09-28-2018, 02:57 PM
#47
I am thinking of going similar route. You might want to check with accesoride. I believe it’s the same harness and I believe it’s $249 and they are vendor here on the boards
09-28-2018, 03:08 PM
#48
Real Name: Jeremy
Real Name: Jeremy
If I'm not mistaken the 12volt solutions unit only works with the push button vehicles..if you have one no problem..otherwise, the accessoride unit is the best option, https://accessorides.com/collections...ay-g-key-start
'18 SR5 4WD, magnetic gray metallic, stock, RCI front skid, LFD cross bars, Pedal Commander, Accessorides Remote Start.
09-28-2018, 04:32 PM
#49
Real Name: Art
Real Name: Art
As I said, I need something simple - one button, maybe 2-way, that's it.
I see several Groupon deals with the Compustar CM-900 for about $150-160, maybe additional for the bypass module. Is this a discontinued model?
Also see several simple Avital deals around the same price.
With all these options, no way I'm spending $250/$350 for 12volt's and do the labor myself!
2013 TE KDSS ♦ Toytec 3-inch ♦ SPC UCA's ♦ Bilsteins ♦ 275/70R18 Duratracs on Addict XD798's ♦ Shrockworks engine skid ♦ Husky Liners ♦ ...Goodbye LR Defenders
09-28-2018, 08:28 PM
#50
Originally Posted by rigertoflip
Before I found this thread I bought a system from my local shop including installation, it gets installed Friday. They are telling me the engine will not shut off when I open the door (I think its a key vs push button start thing). Compustar - FT-DC3-LC
That model on regular key start vehicles it will not shut down, and there are t-harness available for it.
Best Buy has this model which will include a t-harness and installation. T-harnewss is available now for PTS and regular key. Remotes are upgradable.
https://www.bestbuy.com/site/compust...99287900050008
2016 4Runner Limited
09-28-2018, 10:30 PM
#51
12volt.solutions has two units. One for limited and one for keys with G stamp on it. Sr5 Trd etc. Non limited model will work with your stock key button to start your car and if range is issue, you can add cellular module for start and unlock the car using their app. Also G stamped unit will keep engine running when you unlock and open the door.
91 SR5 4runner, 97 SR5 4runner, 06 Sport 4runner,
18 TRD Pro 4runner Cavalry Blue(Toytec pro lift, Nitto Ridge Grappler 285/70r17, Rigid D-SS on Rago ditch bracket, RSG angled slider, Blackout emblems, led interior, fog and h11)
09-28-2018, 11:16 PM
#52
Official Vendor
Official Vendor
Thanks for the recommendations guys! We have kits for both the key and push start. Push start will shut down when opening the door. Key starts will stay running and allow takeover. Either one can be activated from the OEM remote by pressing lock 3 times and both are 100% plug and play. Longer range remotes or smartphone modules can be added to either as well. Let us know if you have any other questions and as always check out our section in the vendor area for a discount code.
Arthurm - for a basic remote start installed expect to pay anywhere from $200 to $400 including the parts, labor, bypass etc. And the groupon deals always sound good but often dont include the bypass which they will add another $100 or so on for. If you are comfortable doing the labor yourself its maybe 15 - 20 connections depending on options but you can definitely save a few bucks that way. Either of those you mentioned Avital or Compustar are both nice units as long as you stick with any of the major brands and find a reputable installer you’ll be good to go!
10-01-2018, 10:52 AM
#53
Before spending any money, go out to your T4R and depress the lock button on your factory key fob 3xs w/in 5 seconds. A valet accidentally demonstrated to me that I had remote start. Dealership searched and said I did not. I then stumbled upon the answer that I did and how to trigger it.
10-01-2018, 12:50 PM
#54
Real Name: Chris
Real Name: Chris
Is the kit you sell the same kit that 12volt sells?
10-01-2018, 01:01 PM
#55
nice
I was planning on doing this for my 12 4runner. Then I had the idea to do it for my fifes Lexus. They want to charge me for it. its called an enform remote and you have to subscribe to something to use the function that's on the car.
10-01-2018, 03:42 PM
#56
What year/model do you have? Would love to find out if my 2018 does this.
10-02-2018, 10:10 AM
#57
All Quicksands are 2016 TRD Pros (see my pic <--)
01-19-2023, 01:45 PM
#58
Originally Posted by Jeremy556
I added the OEM remote start after the fact. It is all plug and play as far as wire harnesses, but probably more involved dash dis-assembly than most people would be comfortable with. You will still need to take it to a dealer to program it to the engine immobilizer.
I think it took me about 3 hours to install.
I purchased a factory remote starter for my 2013 4Runner. May I message you about the install?
01-19-2023, 07:02 PM
#59
Sure. I installed it in like 2013, so I have forgotten most of the details.
01-31-2023, 04:09 PM
#60
On the Accessorides version for a push button start 2021 TRDP, I'm just confirming there is still no bypass for the door killing the engine?
2021 TRDP
