10-06-2022, 11:23 PM
#136
Originally Posted by Xtremluck
I think you will especially if you go into the world of negative offset and you are actually cycling through your suspension offroad. Toyota really didn't leave us with a ton of room there. I was actually hitting my inner fenders with 33s at full compression!
I'm currently running summit raptors with 33's and no rubbing with just a fender liner move, bumper trim and removing mud flaps. So hoppefully not much more would be needed for 34's on the next go around if I go that route. a BMC I am sure, but hopefully not much more than that.
10-07-2022, 02:10 PM
#137
Real Name: Krister
Real Name: Krister
You may need to do some more massaging in this area with a BFH. Also, spray all that after with a rubberized 3M product.
The cutting only hurt for the first few inches I bet.
Sent from my SM-G996U using Tapatalk
Attachment 400231
2020 Tundra Limited Crew Max 4X4 - Tundra Build
2014 4Runner TE - rochmpr Build - SOLD
10-07-2022, 02:51 PM
#138
Attachment 400231
Yup, I will definitely need to hammer in the back of the fender well a bit. Going to be stretching out the suspension this weekend at Slickrock. So we shall see how it goes.
'12 Silver 4Runner SR5: 14+ facelift, CBI front, CBI Rear, Warn EVO 10-S, ARB Snorkel, Baja Designs 30" S8, Squadron Sports, S2 Rack Lights, King 2.5 Suspension, OME 899, 33" Cooper ST Maxx, Full CBI Skids, Metaltech Sliders, GFC Tent, ARB Awning
Xtremluck's 2012 SR5 Build Thread
10-08-2022, 08:07 AM
#139
Real Name: Krister
Real Name: Krister
Have fun there. Should be a great weekend
10-24-2022, 09:06 AM
#140
Alright spending the last couple of weekends repairing the damage from my last trip. First up was fixing my bent passenger side steering knuckle.
Pulling them off wasn’t too bad it just took a few steps to get everything detached and out of the way.
Compared to a brand new one you can see how bad it was bent.
While pulling off the hub I was really impressed how good the bearings were still after 164,000 miles. I’ll need to replace them eventually but they are still in decent shape.
Ok here is everything all buttoned back up I added the brake dust shield on later.
I’m not going to gusset them for now because I’m wondering if it’s better to have them bend vs. some other part of the front suspension break in a similar situation. After all I was able to drive out easily from this incident and 200 miles home
09-06-2023, 01:37 PM
#141
Nice build, why did you decide to go eaton locker over ARB?
thanks
I use to own a e90m3 6MT too
2018 SR5P+3rd row, 285 KO2, 5100+Dobinsons 300/505
09-06-2023, 07:28 PM
#142
thanks
If you read my Rubicon trip report a key reason of why I went with an e-locker is right there. Every person I know who has run an ARB air locker has had problems with it eventually. The system is much more complex and there are seals that can get compromised over time. Sure I lose instant engagement but the Eaton is super quick, much quicker than the OEM locker and it just works.
I bet you regret selling that E90!
09-06-2023, 07:31 PM
#143
thanks for the reply
I actually regret selling my e36 m3 not e90
