12-21-2017, 09:51 AM
#46
'12 Silver 4Runner SR5: 14+ facelift, CBI front, CBI Rear, Warn EVO 10-S, ARB Snorkel, Baja Designs 30" S8, Squadron Sports, S2 Rack Lights, King 2.5 Suspension, OME 899, 33" Cooper ST Maxx, Full CBI Skids, Metaltech Sliders, GFC Tent, ARB Awning
Xtremluck's 2012 SR5 Build Thread
12-21-2017, 10:02 AM
#47
Had a busy weekend! Decided to mount and wire my Baja Designs S2 Pro/Sport lights to my rack. Found side and rear lighting as a big gap for finding campsites in the dark on my last trip. These little guys were a perfect solution:
Will need to tweak the passenger side mount as the awning is blocking some usable light. Really wish I had some metal fab skills to create a custom bracket!
Really pleased with the side output, the S2 sports in the rear aren’t the brightest but they will be perfect as dust/fog lights. I’ll be adding bumper lights once I make a decision on what metal bumper to go for in the near future!
12-21-2017, 10:38 AM
#48
Hi X,
I like your use case of using auxiliary lighting for finding camp sites in the dark. Can you tell me more about your BD S2 side and rear lighting arrangement. How many pods total? How did you run your wire to each from your SPOD and does each light have its own switch or did you double up on some of the lights to one switch?
On the metal fab skills, I am looking into joining one of those co-op centers around the Bay Area that for a monthly membership fee, lets you use their tools and equipment and teaches you welding n' stuff. If I find a good one and join, I will let you know.
Cutty
2013 4Runner Limited | OPOR Sliders | BFG KO2 in 275/70R17 on TE Rims |Bilstein 6112/5160s and SAW 1.5" | Some RCI Aluminum Skids | SPOD | Gobi Stealth No-Rise | Aurora 40” and 6” Single Row LED Light Bars
12-21-2017, 02:32 PM
#49
Originally Posted by cutty01
Hi X,
Cutty
Hey Cutty!
So I have (2) BD S2 Pros in white (Flood/Work light pattern) on the sides. They are REALLY bright and I don't think you would need more than one on each side. For the rears I have BD S2 Sports in amber (Flood/Work light pattern). Their primary use will be as a rear fog/dust light.
If you need actual rear lighting I would recommend using S2 Pros in white (flood/work). My use case didn't require this as I will be adding rear backup lights with my future metal bumper.
Let me know what you find on metal fab classes. Maybe ill make my own rear bumper haha
12-30-2017, 01:10 AM
#50
Subscribed
@ Xtremluck
Came across your build thread and I've subscribed! awesome to see such a great looking 2012 SR5!
Id look into the thread below and contact the OP about submitting your build for 2012 silver
5th Gen Build and Adventure Threads
2012 SR5 Premium Magnetic Grey: KING Shock Coilovers with res // Total Chaos UCA & rear link kit // GOBI Stealth Rack + Rigid Industries lights // sPOD & Source System // 2014 TE Rocker conversion // C4 Fab Rock Sliders // Bandi mount w/ARB Twin Air Compressor & Rear Locker // Pelfreybilt HWM w/ WARN ZEON 10-S Platinum
12-31-2017, 12:23 AM
#51
Originally Posted by Alaska_4Runner
@ Xtremluck
Thanks my friend, really dig your build as well! Will see if I can get my build in there
01-02-2018, 08:59 AM
#52
Had a chance to ring in the New Year camping and hiking up in California’s Lost Coast. Even got to do a little dirt road and beach driving!
01-12-2018, 05:35 PM
#53
Finally installed my ARB air compressor paving the way for shorter air up times and possibly air lockers.
Picked up two great tools for this project. A hydraulic crimper and a butane powered soldering iron. The crimper is amazing and allows you to make solid connections with your ring terminals. Will never do another electric project without it!
The butane soldering iron is also handy as I park in a shared garage with no electrical outlets. This allows me to get my contacts to the right temp for proper soldering. I was using battery powered irons before and they can’t even compare in term of effectiveness!
Ok now off to Death Valley to test all of this stuff
01-26-2018, 11:06 AM
#54
Real Name: Jean
Real Name: Jean
After reading your Death Valley trip report (awesome stuff!!!), I would like to know your Rotopax fuel configuration. From the Chicken Rock video, I think you have two 3 gallons on the back, and two (?) 2 gallons on the side. Am I right?
I am looking to add fuel packs but those Rotopax are kind of pricey, plus mounting hardware. Also, I might add a rear bumper with swingout so jerry cans would be better in this case. Any other suggestions.
2016 Trail Edition Classic Silver Metallic with KDSS, sunroof
ToyTec BOSS lift, SPC Light Racing UCA, RCI sliders, RCI aluminum full skids, RCI Cat Guard, Eezi-Awn K9 2.2m, BFG KO2 275/70R17E, FN Wheels f(X) Pro, ARB Breather kit, Husky WeatherBeater Mat and Cargo, XPEL window tint, 3M wrapped hood
Build thread
Adventures thread
01-26-2018, 07:44 PM
#55
Thanks! I don't think you should mimic my Rotopax setup ;) I have a weird use case that limits my options due to a really low garage door. My current setup is:
(1) 3 Gallon Rotopax
(2) 3.5 Gallon Fuelpax
One 3.5 gallon Fuelpax is mounted on the side and the remaining containers are mounted on the rear.
When I get my rear bumper I will probably consolidate to just (2) 3 Gallon Rotopax mounted on the swing out. Carrying 10 gallons of spare fuel is overkill. Hope that helps!
03-01-2018, 01:49 PM
#56
Sorry
@ JohnTheLuck
I though I replied to this 🧐. I have (2) 3.5 gal Fuelpax and (1) 3 gal Rotopax mounted on the roof. A bit excessive yes but I’ve found it quite useful when traversing really remote terrain. (Ie. Driving around the North Rim of the Grand Canyon and traversing into Utah all off-road)
You’re probably fine with just one 5 gal jerry can mounted on your rear bumper for most situations though.
03-01-2018, 01:55 PM
#57
03-01-2018, 04:58 PM
#58
Real Name: Jean
Real Name: Jean
Originally Posted by Xtremluck
Sorry I though I replied to this 🧐.
In fact, you did respond to me just the post before !!! Thanks anyway.
Build thread
Adventures thread
03-01-2018, 05:19 PM
#59
Tap-A-Talk Mobile strikes again
03-05-2018, 02:08 PM
#60
After adding 200+ lbs of equipment to the front end it was time to switch to heavier springs. I was maxed out on preload on the driver side Icon coilover and was still 3/4” under my original lift height (23” hub to fender). So out with the old 13” 650lb springs and in with the 14” 700lb springs. A couple of pro tips from the install:
1. You need a wall mounted spring compressor for this
2. Make sure you disconnect your wheel speed sensor wire before trying to extract the coilovers. I toasted the passenger side cable when I stretched it out
Preload Before:
Preload After:
Restored Ride Height:
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
