04-08-2019, 06:49 PM
#91
Real Name: Justin
Real Name: Justin
Originally Posted by Xtremluck
Forgot the diagram!
did you ever end up adding this?
It looks like you also need the support bracket (19)
and the retaining bracket (20)
2010 4Runner SR5 Magnetic Gray: Radflo / Icon + Metaltech / Total Chaos / Dirt King / SCS Stealth 6 / BAMF Sliders + Pelfreybilt Bumper / PRINSU / Indel B / 2014+ IS 350 Retrofit
2012 GX460 Premium Black Onyx: Stock af
04-08-2019, 10:29 PM
#92
I only got #17 and fashioned up some hardware/bolts that used an existing center support to stabilize that new piece which also attached to the headlights. Everything is rock solid now. I can try to take a pic this weekend or you're more than welcome to take a look if you're ever in SF.
'12 Silver 4Runner SR5: 14+ facelift, CBI front, CBI Rear, Warn EVO 10-S, ARB Snorkel, Baja Designs 30" S8, Squadron Sports, S2 Rack Lights, King 2.5 Suspension, OME 899, 33" Cooper ST Maxx, Full CBI Skids, Metaltech Sliders, GFC Tent, ARB Awning
Xtremluck's 2012 SR5 Build Thread
04-09-2019, 01:45 PM
#93
Real Name: Justin
Real Name: Justin
Pics would be great, I don't want to buy anymore parts at this point
I'd love to head over sometime—I'll be out east of the bay for the weekend, so I'll take a raincheck
04-09-2019, 02:01 PM
#94
How did you fit the dual compressor back there with the air pump?
I see that Schrockworks now sell a mount kit, but it is only for a single, not a dual.
04-20-2019, 10:05 AM
#95
I used a mount sold by 4x4labs
ARB Air compressor bracket for 5th gen 4Runner – 4X4LABS
04-20-2019, 10:07 AM
#96
Sorry for the really crappy and muddy pic. I circled in red the long bolt and nuts I’m using to secure the new center support onto the old support for the OEM bumper. The orientation of the pic is looking from the engine bay away from the truck. Hope that helps
04-20-2019, 02:14 PM
#97
Real Name: Justin
Real Name: Justin
Thanks! This is going to be very helpful. Just a bolt, a few nuts and what looks like some zip ties for good measure. This makes sense now. I was just overthinking the setup.
04-30-2020, 09:22 AM
#98
Originally Posted by infamousRNR
awesome build thread pete... looking at your photos from MOAB, reminiscing on what an epic trip that was! Where is the next trip for you?
Yes! That was an amazing trip for sure. Sorry I didnt reply until now man. Looking to head out to Utah to do a National Park tour mostly offroad once we are done with Quarantine!
04-30-2020, 09:27 AM
#99
Been a while since I’ve updated the good ole build thread. Lopped off the Gobi rack almost a year ago to add a GFC roof top tent!
Spent around 50 nights in it so far this year and it’s been fantastic
05-10-2020, 07:16 AM
#100
Been trying to chase down some steering knock when traveling on rocky off road trails for a long time. I noticed the other day while replacing my front swaybar bushings and endlinks that my swaybar may have been making contact with a suspension support brace I modified when I had to relocate my swaybar to fit my Icon CDCV 2.5 coilovers. After some research I found out that Old Man Emu makes a fitment kit that replaces this support brace with one that has much more clearance. So I decided to tackle the install last night.
As you can see by the silver wear marks my swaybar has been making contact (OEM on top and the replacement OME support bracket on bottom):
Here is a before and after picture once I was done with the install. You can see the swaybar now has almost an inch of clearance. Bonus points that I also gained some skidplate clearance back since I don't need to use bracket spacers anymore:
Now I need to hit some dirt to test everything out!
I hate to bring this post back, but I made an account here just to ask you about the work you did. Did this kit come with all the bolts to install? Or do I need to fond an m6 and the other hardware? All I need is that bracket just like you - as I am now running a new icon kit that just started rubbing the swaybar. I'm not confident in my welding/cutting abilities + plan on getting RCI steel skids soon to replace what I have , so if this bracket does the trick I'm going to hop on it.
05-10-2020, 10:22 PM
#101
It came with hardware but I believe I just reused my stock fasteners.
05-10-2020, 10:28 PM
#102
After just about three years of use it was time to rebuild my trusty M8000 winch. The clutch was stuck in engagement mode so i thought it would be good to disassemble and to clean. All the deep water crossings ive done over the years certainly took their toll.
Folks be kind to your winches! They need to work when you most need them.
05-10-2020, 10:43 PM
#103
Hot damn that is dirty! Muddy utah river crossings?
2019 ORP - KDSS, Dobinsons C59-302/GS59-700 front and C59-725/IMS59-50701 rear, Dobinsons UCA, DuroBump/Daystar bumpstops, Sonoran Steel High Articulation tracbar, Marlin Crawler LCA frame brace, OGS Lo-Key Bumper w/ Warn VR EVO 10-S, RCI Sliders, fully armored with RCI/C4/Outgear Solutions skids, Falken Wildpeak M/T 285/70/17, LFD SS-Crossbars, ARB breather kit (Rear Diff and Locker), ScanGaugeII, Anytime Front/Backup Camera, onboard ARB Twin compressor MORRFlate kit, and DD SS3 Sport fogs
05-11-2020, 11:15 AM
#104
I think its Utah, California, Baja Mexico, Oregon and Washington. All states where I've dunked the winch over the last three years. Going to add this teardown as part of my annual maintenance plan. Im fortunate enough that my bumper has enough space to let me do this without having to pull it off.
05-12-2020, 11:25 PM
#105
How you didn't make the list is hard to believe!!! Rigged I say!!! In all seriousness I think your rig is one of the more well thought out and appropriately built for what you do and enjoy. One of my favorite builds on here.
11 Overland 4Runner Builds That Will Inspire You - Trail4R.com
2016 Nautical Blue Metallic Trail | SCS | Falken Wildpeak AT3/W | Icon CDCV | Heftyfab Front Bumper | 4x4 Labs Rear | Shrockworks Sliders | RCI Skids | Warn VR10S | OGE Dual Battery System | sPOD | Katzkin
2013 Blizzard Pearl LE 4WD - SOLD!!!
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
