Old 05-13-2020, 08:09 AM #106
Xtremluck's Avatar
Xtremluck Xtremluck is offline
Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold
Xtremluck's Avatar
Originally Posted by sn_85 View Post
How you didn't make the list is hard to believe!!! Rigged I say!!! In all seriousness I think your rig is one of the more well thought out and appropriately built for what you do and enjoy. One of my favorite builds on here.
11 Overland 4Runner Builds That Will Inspire You - Trail4R.com
Thank you my friend! One of the benefits of building your rig over years as you go on trips. You get something tailored to your exact needs. Build, test, iterate...rinse and repeat. The truck is continuously evolving but I think I have it pretty dialed now.
'12 Silver 4Runner SR5: 14+ facelift, CBI front, CBI Rear, Warn EVO 10-S, ARB Snorkel, Baja Designs 30" S8, Squadron Sports, S2 Rack Lights, King 2.5 Suspension, OME 899, 33" Cooper ST Maxx, Full CBI Skids, Metaltech Sliders, GFC Tent, ARB Awning
Xtremluck's 2012 SR5 Build Thread
Xtremluck is offline   Reply With QuoteReply With Quote
Old 05-13-2020, 08:19 AM #107
Xtremluck's Avatar
Xtremluck's Avatar
After a couple of years using a National Luna Dual Battery isolator my secondary battery was in pretty rough shape. Our smart alternator wasn’t giving me enough voltage to properly charge the 55ah AGM battery. So I opted to add a DC to DC charger with solar capabilities. I now have an almost indefinite supply of electricity while camping!
Old 05-19-2020, 08:49 AM #108
Xtremluck's Avatar
Xtremluck's Avatar
This quarantine has me busy knocking out so many projects on my list. Finally took apart my winch after three years of field use to rebuild it. The clutch lever was stuck in the engaged position and now I know why.
Fun fact: I was able to completely tear down the winch without removing my bumper. I guess the Pelfreybilt crew did one thing right. All better now and I even added a wireless winch controller.
Had some extra time on a Sunday so I added extended braided brake lines in the rear in preparation for some suspension upgrades coming. Didn’t catch the brake fluid fast enough and now I need to spend some time to repaint my axle. Oh well...
Old 05-19-2020, 01:11 PM #109
sn_85's Avatar
sn_85 sn_85 is offline
sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold
sn_85's Avatar
How are you liking the Redarc BCDC? I'm running a Blue Sea ML-ACR and have been having issues with maintaining full charge on my batteries as well. I added the Arclight voltage booster to help give my AGM batteries a little more juice but it seems like my aux battery isn't able to power the fridge for as long as it used to. I can get maybe a 1.5 days out of the fridge where I used to get about 3 days out of it.
I recently picked up the 25A BCDC and going to redo my dual battery setup. Are you still running a solenoid as well to help isolate and link the batteries or did you switch completely to DC-DC? Ideally I'd like to link the batteries especially when I need to winch or run the air compressor and I know you can run an isolator along with dc-dc charger but that might be overkill and add complexity.
2016 Nautical Blue Metallic Trail | SCS | Falken Wildpeak AT3/W | Icon CDCV | Heftyfab Front Bumper | 4x4 Labs Rear | Shrockworks Sliders | RCI Skids | Warn VR10S | OGE Dual Battery System | sPOD | Katzkin
2013 Blizzard Pearl LE 4WD - SOLD!!!
sn_85 is offline   Reply With QuoteReply With Quote
Old 05-19-2020, 03:50 PM #110
Xtremluck's Avatar
Xtremluck's Avatar
Its one of the best upgrades I could have done. I thought of a voltage booster but ultimately decided against it since so many folks seem to get mediocre results and some even have additional problems with those things. I deleted my battery isolator even though you can technically use it. It wasn't worth the over complication for minimal benefit IMHO.
I use my winch and air compressor quite frequently and never really had a situation where I drained my starter battery. Even with long extended winch pulls. Although I usually insert breaks so the winch can cool down so maybe that helps with power consumption. If you need to jump start your rig just carry a set of jumper cables. I usually have that and an external lithium ion battery starter as backup in my kit.
Old 05-19-2020, 04:40 PM #111
sn_85's Avatar
sn_85's Avatar
Awesome, thanks for the insight!!! Yeah the voltage booster was just a temporary solution and honestly I don't want to mess too much with the OEM electrical system. I'm currently running group 35 agm batteries for both starter and aux but with a BCDC I could potentially run lithium in the future which would be nice.
Old 05-20-2020, 08:56 AM #112
Xtremluck's Avatar
Xtremluck's Avatar
Yup, Im thinking the same thing. Unfortunately, the engine bay isn't really lithium friendly because of heat. If I could do my dual battery project all over again I would have run my house battery in the passenger compartment and it would be lithium. The high capacity, weight and ability to drain to zero is so money.
Old 08-03-2020, 09:08 AM #113
Xtremluck's Avatar
Xtremluck's Avatar
Well after about 40,000 miles of hard use my Icon CDCV suspension was due for a rebuild. I wanted to try something different so I opted for a KINGs custom setup through Filthy Motorsports with a softer spring in front. Went from a 700lb spring to a 650 and this setup is night and day better than the Icons off-road.
Had a quick trip over the long July 4th holiday weekend to break them in. Glad I made the change the hype is real.
Old 10-27-2020, 02:49 AM #114
perf0rmance perf0rmance is offline
perf0rmance will become famous soon enough
Have you ever checked the number of clicks you have on your kings?
What are you settings for the front are rears on the adjusters?
perf0rmance is offline   Reply With QuoteReply With Quote
Old 10-27-2020, 09:44 AM #115
Xtremluck's Avatar
Xtremluck's Avatar
I have them on a pretty soft setting right now. 3 clicks in the front and 5 clicks in the rear. It seems to be a pretty balanced ride.
Old 01-03-2021, 09:55 PM #116
Toyota72 Toyota72 is offline
Toyota72 is on a distinguished road
Sorry just saw the alert for this. The part is not in the pictures and it's a full replacement of your original OEM support. It will definitely work on an SR5 w/o KDSS with Icon 2.5 coilovers (That is my current setup)
Glad you discovered this product I’ve ordered it. I have the Icon lift and the shop that installed It dropped the radiator support brackets with 3 Shims on the front and back Sides of the brace which looks sketchy to me. Have you seen that done before?
Also considering going with the CBI front skid which I believe requires complete removal of the OEM radiator supports is that correct?
Thanks!
Toyota72 is offline   Reply With QuoteReply With Quote
Old 01-07-2021, 07:22 PM #117
Xtremluck's Avatar
Xtremluck's Avatar
Thanks!
Ive definitely have seen that before because I did the same thing initially. The factory labels them as front suspension braces so in my mind they play some sort of structural role. So I wouldn't be hot about removing them and that was the reason I paid up for the ARB brace.
Old 05-26-2021, 10:48 AM #118
Xtremluck's Avatar
Xtremluck's Avatar
After years of using ATRAC and my winch to get up more technical obstacles I finally caved and bought a rear locker. I was originally going to take it in to an axle specialist for the install but I love a good challenge and decided to DIY. It’s definitely not an easy project since Eaton’s documentation is sparse but after a lot of research I was able to figure it out.
We are planning a backcountry tour of the Sierra mountains this weekend so I wanted to QA test the locker a bit. Works as advertised and makes getting up stuff a little less sketchy.
Old 07-20-2021, 04:57 PM #119
Hindsight 4Runner Hindsight 4Runner is offline
Hindsight 4Runner is on a distinguished road
Might have missed it, but how did you get away with the hatch ladder and drivers side table? When I installed mine, the folks at CBI told me it wouldn’t work. Either the table or the ladder but not both.
Do you have any clearance issues?
Hindsight 4Runner is offline   Reply With QuoteReply With Quote
Old 12-07-2021, 10:55 PM #120
Xtremluck's Avatar
Xtremluck's Avatar
Sorry for the super late reply on this. They used to offer it as an option with the table. Although I would say there are definitely some clearance issues from swing arm flexing into it. Nothing major just dont expect to have a pristine finish on your ladder if you really hammer on your rear bumper.
Vegas: 2012 Trail build thread Vegas 5th gen T4Rs 157 12-13-2018 08:56 PM
>BUILD THREAD< The4kbeast's 3rd-Gen 2000 T4R SR5 (Highlander Edition) 4x4 Build The4kbeast 3rd gen T4Rs 285 07-25-2018 09:37 PM
STRRAYNGE Build Thread! Or, I should say, After Build Thread?! Pic Heavy STRRAYNGE 3rd gen T4Rs 24 02-11-2016 10:46 AM
1998 T4R Build Thread/Rear bumper build 4running11191 4running11191 3rd gen T4Rs 3 09-19-2014 07:07 PM
