12-07-2021, 11:05 PM
#121
Xtremluck's 2012 SR5 Build Thread
Been really bad about updating my build thread. After many years of use my aluminum RCI skid plates needed to be replaced. They did an amazing job and took severe abuse over the years. However, their biggest flaw reared it’s ugly head eventually. Using OEM frame welded nuts to mount the skids eventually made it impossible to remount the skids. Each welded nut eventually failed!
So I ordered a new set of aluminum skids from CBI that has a much more stout mounting system. They have been great so far.
'12 Silver 4Runner SR5: 14+ facelift, CBI front, CBI Rear, Warn EVO 10-S, ARB Snorkel, Baja Designs 30" S8, Squadron Sports, S2 Rack Lights, King 2.5 Suspension, OME 899, 33" Cooper ST Maxx, Full CBI Skids, Metaltech Sliders, GFC Tent, ARB Awning
12-13-2021, 05:26 PM
#122
After about 5 yrs of service my Pelfreybilt aluminum winch bumper starting showing it’s age. Some small cracks appeared near the winch tray. It’s likely from side winch pulls that I’ve done in the past. It was probably ok but given how much I winch I decided to start fresh with a new bumper so off it went.
I facelifted my 2012 truck when I bought the Pelfreybilt bumper and because of that a lot of the front bumper cover mounts were original. Not a problem for a full replacement like the Pelfreybilt but a problem for just about any other bumper option out there.
So I decided to buy a cheap bumper cover off of Amazon and paint it myself. I wouldn’t call it a pro finish but it does the job. Given how little of the bumper you actually use it wasn’t a big deal.
Here it is all mounted up and cut. I had to buy some additional OEM bumper mounting points to make this all work since I didn’t do that when I installed my old bumper.
Next step is to transfer the winch and lighting to the new bumper. It never ends….
09-26-2022, 08:50 AM
#123
09-26-2022, 09:06 AM
#124
After almost 6 years of heavy use I decided to replace my RCI aluminum skid plates with a set with a better mounting system. The RCI plates held up fine but they mounted on welded frame nuts which eventually failed from all the hits. CBI’s aluminum skids use better mounting points.
Posting this late but here they are after 1.5 years and a lot of rocky trails. I’ve impressed there hasn’t been a ton of deformation given how hard I beat these things up. A testament to the great engineering behind them.
09-26-2022, 09:15 AM
#125
Here’s a fun one. I’ve always hated the performance of our headlights but took the lazy way out by just dropping in HID bulbs and going my way. I finally decided to fix this properly by retrofitting a MLED 2.0 BI-LED projector.
Opening this headlight was a BIG pain.
The output quality is night and day better. Notice the even light distribution in the beam pattern.
Let the end results speak for themselves. Slight embellishment from my phone’s auto exposure of course.
09-26-2022, 12:09 PM
#126
[QUOTE=Xtremluck;3761593]Here’s a fun one. I’ve always hated the performance of our headlights but took the lazy way out by just dropping in HID bulbs and going my way. I finally decided to fix this properly by retrofitting a MLED 2.0 BI-LED projector.
Very nice! looks like a huge improvement. Wish I had considered this before I change out for Alpharex
09-26-2022, 12:41 PM
#127
[QUOTE=comtn4x4;3761624]
One of my favorite upgrades for sure. It was relatively easy as well. The only hard part of it was opening the headlights. If I could do it over again I would just cut them open.
09-27-2022, 08:04 AM
#128
[QUOTE=Xtremluck;3761630]
How did you get them open?
I was going to retrofit GS350 projectors but could never get the housings open with a heatgun. I read that aftermarket versions like TYC are much easier to heat and open though.
09-27-2022, 08:38 AM
#129
Put ‘em in the oven!
I actually accidentally melted one housing when it spent too much time in there. If I could do it over again I would have just taken a dremel cutting wheel and just cut open the housing and maybe plastic weld it back together to save time.
10-06-2022, 08:58 AM
#130
Documenting the addition of 35s and all the cutting and pounding I needed to do to get them to fit properly. I went with BFG KO2s since they are probably one of the lightest 35” options and slightly smaller than “full size” 35s
Here they are next to a brand new 285/70/17 Ridge Grappler.
Needed to do some pretty big trimming
10-06-2022, 08:59 AM
#131
Here is the final product, I think it looks relatively OEM.
We will see how it does on a technical trail this weekend.
10-06-2022, 10:40 AM
#132
Looks real good! I am debating 34's on the next go around and hopefully it doesnt take as much cutting/hammering to fit.
10-06-2022, 11:50 AM
#133
That looks great! Do you happen to have some actual measurements for hose BFG's?
10-06-2022, 07:34 PM
#134
I think you will especially if you go into the world of negative offset and you are actually cycling through your suspension offroad. Toyota really didn't leave us with a ton of room there. I was actually hitting my inner fenders with 33s at full compression!
10-06-2022, 07:36 PM
#135
In that picture mounted on the wheel but not on the truck they stood at just about 34" tall. Mounted on the truck they are just a hair over 33.25". So again they are almost like a 34.5" tire.
